DSP Wiring question
My AudioControl DM-810 finally arrived after a 3 month back order.
For those of you that have installed DSPs, did you pull the signal from the output of the head unit prior to the amp, or from the output after the amp?
I have a 2016 ES350 with the premium 10 speaker system (non ML)
The plan is to power all speakers off of an Alpine PDX-V9 amp (except the center channel)
Sub will be replaced and door/dash speaker will be replaced as determined after the DSP upgrade.
Thanks for any assistance.
Ratchey (01-11-17)
Thanks. Once I got the DSP the instructions stated the same thing. I got the DSP wired into the amp yesterday. That was a lot of wires to cut and splice.
My build thread is here https://www.clublexus.com/forums/es-...o-upgrade.html
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/1000x563/80_gpboak0_0fc9a0c7c18663cbae516c4e61b67ea03036a406_538814c2316111bf48d7cbb92b08f1e9f5744eea.jpg)
Use the pdx 1.400 for all your mids and the v9 for all the tweets. That way it's easier to tweak later on. My setup is fully active. I'm using 2 jl hd6004, 1 hd 1200.1, helix dsp pro, 3 way hertz Mille front, 2 way Mille rears and 2'12s Mille subs. Let me know if u need any help. I'll be glad to help
ArmyofOne
04-26-19 04:41 AM
