AV Input Issue (distorted screen)
Old 01-14-17, 11:29 PM
LCC
LCC's Avatar
Default AV Input Issue (distorted screen)
Hello
Issue is with a 2016 ES 350. Wanted to know if anyone else is having issues with their AV Input. I've tried several sources and cables. Cables are good when tested on other tv's, etc. I've pretty much narrowed it down to the car. The picture is pretty much like an
analog tv analog tv
with bad antennareception. Sound works perfect. I'm hoping its me that's doing something wrong but I think something might be wrong with the car, which I hope is not the case. Also tried both settings on the car, ntsc and pal with the same output. Pics to follow. Please advise. Thank you all.
Old 01-16-17, 09:04 AM
Pacific13
Pacific13's Avatar
Check carefully the ground of all the circuits and paricularly the plugs. It is also usefull to use the same ground for the source (car body).Make a shield with alu paper on the cable, this shield must be connected at both ends. Try and revert.
BotoxBoy
ES - 6th Gen (2013-2018)
14
03-30-17 01:37 PM
LCC
01-15-17 02:47 PM
alir1983
20
06-27-15 02:44 PM
isam250
01-16-13 11:51 AM
ddcruise
IS F (2008-2014)
06-12-12 07:58 AM
Quick Reply: AV Input Issue (distorted screen)
