DynAudio Amp Question
Old 05-30-03, 02:07 PM
Percy
Moderator - Electronics Forum
Percy's Avatar
FREE is always a good word, especially when it comes to audio!
You'll do fine with the setup.
Percy
Old 05-30-03, 02:14 PM
tmasta
tmasta's Avatar
THANKS! cant wait to try it out.. too bad my car is at lexus cause they scratched up my body kit! BUT thats a whole other story. thanks again percy
Tony
Old 06-04-03, 07:07 PM
tmasta
tmasta's Avatar
percy,
one more question.. if i bridge the first 4 channels what setting do i put on the amp? (in terms of # of channels) thanks. i believe right now i have it set at 5
T
Old 06-05-03, 07:41 AM
Percy
Percy's Avatar
T,
Make sure the selector is set to "4" on the 4-5-6 selector. Inputs 1, 3, 5 and 6 will be for the 4 channel selection. On the output side you'll see markings "bridged" towards the bottom. 1 and 2 will form one channel while 3 and 4 will form the other. 5 and 6 are hooked up normally.
This is all from memory... scarry!
Percy
Old 06-05-03, 10:34 AM
tmasta
tmasta's Avatar
all from memomry! hahah u SHOULD work for mc! thanks once again!
T
Old 06-08-03, 08:34 AM
tmasta
tmasta's Avatar
hey percy.
i tried the bridged set up with the 4 channel switch on and it would work for about 1 min then a loud noise came out from the speakers and it would cut off.. no music and the cd player wouldnt even run. of course the tuner wouldnt work also. i was scared i blew my speakers some how, but when i would turn off the HU an turn it back on it would work for another minute then the same result.. any ideas? i doubled checked the wiring and it was correct.. all settings the same as the previous set up except for the switch to 4 channel instead of 5. thanks in advance!
T
Old 06-08-03, 01:18 PM
Percy
Percy's Avatar
There should be two other switches other than the channel # selector. What are they set for? (under the glass). One should be set for "out" and the other is for sub control in that it redirects the signal. This may be causing the problem...
Percy
Old 06-08-03, 01:34 PM
tmasta
tmasta's Avatar
hey percy,
i just checked and both are set to out. and the other 2 switches r flat. i dont know if this helps at all but when i was installing the sub the installers had a problem because the sub playin the full range, it ended up they configured it to use the crossover on the HU instead, the people at mc told them that was the way the amp was design. still stumped
T
Old 06-08-03, 03:33 PM
Percy
Percy's Avatar
T,
If possible, give me a pic of the Mc amp as it's setup now. Something is amiss...
Inputs are at 1, 3, 5 and 6? Outputs 1/2, 3/4 5 and 6.
Percy
Old 06-08-03, 04:29 PM
tmasta
tmasta's Avatar
i will try to take a pic asap. i wanna try this set up!.i used the set up according to the +/- next to the word bridged on the amp. i believe + on channel 1 and - channel 2.... etc for 3/4 or vice versa on the polarity. and same for 5/6. i hope nothing is wrong with the amp. ive sent it back 3 times. one tiem installers thought it was broken because of.. long story.. so i'll try to get the pic soon. thanks again
T
nzmar
05-16-16 08:54 AM
Baybarea
19
08-11-07 02:07 AM
vwynn
07-20-07 08:29 PM
pimpin gs
06-02-07 03:54 PM
kmn5
02-28-01 12:32 PM
Quick Reply: DynAudio Amp Question
