2007 GPS "Freezes" GPS "Freezes"
Old 03-05-17, 01:24 PM
tjo2
tjo2's Avatar
Default 2007 GPS "Freezes" GPS "Freezes"
When it's ~50 degrees outside (or colder), the directions function on my 2007 RX400h GPS won't work. When I go to put the address in, the section of country area on the display goes blank. Then, a message comes on the screen that says theres no location data for that area. You can't add the country section back. If it was a previous address, I can select it from the history & it always works fine. The map always tracks me fine. Sometimes, after 20-30 mins of driving it will begin to work but, only if it's close to 50-never when its colder. The service dept has no idea what it is. But... says for $1100 they'll replace a chip board & that "should" do it.
Old 03-07-17, 01:50 PM
mdbrown
mdbrown's Avatar
Electronics tend to work better when cold so I would be surprised if it's a control board. I'd be more inclined to believe it's the GPS drive mounted down where the jack is that is malfunctioning. It may be a condensation issue or perhaps the grease on the worm gears that control the head getting too thick at low temperature. It works after a while because the interior of the vehicle warms up... without physically checking the vehicle out that would be my guess.
Epixx
02-12-23 03:58 PM
jdanielca
07-11-18 09:45 AM
MacG2014
ES - 5th Gen (2007-2012)
01-20-15 02:00 PM
Mcubero
10-23-14 01:33 PM
hfrozen
11-22-06 06:43 AM
Quick Reply: 2007 GPS "Freezes" GPS "Freezes"
