navigation upgrade
navigation upgrade
well after countless hours working with RMMGS4, we've finally got something that is presentable. I can't say that its "done" because what project ever is. There's always a little something that can been added or tweaked. Anyways before I get on to the pics, the system goals were.
1. Pioneer Naviation
2. DVD playback
3. Aux input for digital camera or game console
4. keep it looking like stock
Also keep an eye out for a thread from RMMGS4.
https://www.clublexus.com/forums/sho...threadid=86618
We did our cars at the same time and the system design are similar. While mine is simple, his is a bit more complex.
2. DVD playback
dvd playback
the buttons on the left are from my nak headunit. the top on toggles between video inputs. I'm still trying to find uses for the other buttons. Once I do, I'll probably relabel them.
aux input
i don't smoke so the ashtray is removed in favor of an auxilary set of AV inputs. Also behind the speaker grille is the navigation guidance speaker/IR. I needed to use that because I didn't go with a Pioneer monitor. The monitor is from accele. 7" widescreen and very very bright.
Northern California Regional Officer
I'll be posting soon Jawnthen !
Plus atleast 3 other mods in various forum sections.
Edit: Just posted in the Electronics forum: https://www.clublexus.com/forums/sho...threadid=86618
headunit in stock cd changer location
the stock changer was ditched in favor of a 12 disc put in the trunk. The glove box now holds the brains to my Pioneer DVH-P7000R DVD head unit.
faceplate relocation
with the headunit in the glovebox, I need to put the faceplace somewhere else. homelink was removed (planning on moving it to the sunvisor...) Thanks to Gary Cho for doing the solder work to make an extension cable for the faceplate.
how it was done....
well a lot of wood cutting, fitting, sanding, painting, sanding and more sanding. Had to put a small fan on the monitor to keep it cool.
Very nice installation! I wanted to put the Valentine 1 concealed display unit in the same place where you put the radio faceplate but I use the homelink so I haven't decided exactly what I'm going to do yet.
WOW!!!
INCREDIBLE, absolutely INCREDIBLE are the first thoughts that came to my mind... i WISH i knew someone around where i live that could do that... i dont have NAV, but i want it soooo bad, and im not the biggest fan of the factory nav... if i lived out in cali, i would beg u to do it for me (for $$ of course)... but congrats and looks sweeeeeeeet.
