Help removing front door panel LX470
I tried to remove the front passenger door panel, but after removing all the visible screws and the screw under the door handle, I was able to slightly lift the panel up and away from the door, but there seemed to be something holding the panel to the door around the power window and door lock panel. I tried to remove the panel, but I didn't want to force it. Has anyone removed the panel? Thanks for any instructions you can provide.
