93 sc400 NAK system, sub/amp need LINE OUTPUT CONVERTER?
Old 08-24-03 | 08:16 PM
Taka's Avatar
Taka
Default 93 sc400 NAK system, sub/amp need LINE OUTPUT CONVERTER?
I posted some questions about sub/amp installation on Lexus Electronics section (https://www.clublexus.com/forums/sho...&postid=657539) but I wanna get some feedback from sc ppl so post again here.
I remember that 933005spd said somwhere that you dont need a line out converter..I can use the FRONT LEFT OUTPUT(A6 in the harness) + SIGNAL GROUND(A12) and I guess FRONT RIGHT OUTPUT from HU to make RCA connection??? or should I just get LOC like AudioLink PowerLink II and simply connect to my AMP? I'm still confused about this. I thought the wires coming out of the HU is low level. The converters are meant to convert your factory speaker wires into Low Voltage outputs right? if I use the LOC, is it the same quality? or you can use this LOC as RCA adapor?
btw, my amp doesn't have line level inputs.
any suggestion is welcome
bzw
Performance & Maintenance
13
12-01-16 10:15 PM
bzw
12-07-15 01:52 PM
bacardi
02-15-13 07:35 AM
Lex*Toy
04-10-06 04:54 PM
CamryRR
SC- 1st Gen (1992-2000)
11-08-01 10:55 PM
