Need suggestions on an amp
Originally posted by onelasttry
I should come in here more often
Autotek is extremely too much for stock speakers. any autotek. It isnt because they have a lot of power. It's because they are built for subwoofers, even their 4 channel amps are beefy on the low end. tends to overdrive mids.
A few suggestions would be PPI, AMPLE AUDIO, Soundstream, US AMPS (---- and Alpine.
These are all exceptional mid amps. You can either run a 4 channel or a 2 channel. If you ever use the fade button, and fade to the rear or front, you will want a 4 channel because in 2 ohm stereo using a 2 channel you cannot fade. If you are not interested in the fade button and just like to hear it and dont care, a 2 channel amp will be much cheaper and put out the same level of sound.
P.S- once you remove the factory head unit, the changer will be dead.
[BAutotek is extremely too much for stock speakers. any autotek. It isnt because they have a lot of power. It's because they are built for subwoofers, even their 4 channel amps are beefy on the low end. tends to overdrive mids.
[/B]
[/B]
Since when did an a/b amplifier favor a certain type driver? I don't even know how to debate with you, your comments simply make no sense. Do you think that a 100watt Autotek amplifier will produce significantly more power than for lower frequencies than will a 100 watt USAmps amplifier? Do you think that Autotek amplifiers are incapable of producing higher frequencies? Please enlighten me.
southernjo
10-15-06 02:47 PM
