DSR-1 and Maestro AR integration questions.
I have a 2014 IS350 AWD without Mark Levinson and without Navigation.
I can use the Maestro AR and the RF DSR-1 to bypass the amp instead of summing three high level outputs after the amp for a cleaner signal to my aftermarket amps because it's non ML/NAV.
Do I need to leave the OEM amp in does it get removed it since everything else would be done thru the DSR-1 other than amplification?
djc102987
RX - 4th Gen (2016-2022)
12
05-04-23 02:25 PM
