- gas needle sticking!
- i need suggestions..............
- Will this fit my GS 300 94 ?
- Power Folding Mirrors
- Oil drip
- Fog light glass
- Engine check light
- 1st Gen GS coupe .
- what is this missing part?
- Single Exit Exhaust 1GS
- new member.. well to this section anyways.. 97gs, have ?'s
- My 95 GS
- Can anyone identify these wheels ?
- looking for local shop in SOCAL to do headgasket repair
- Bad power window switch
- Finally getting a GS3
- new wheels new pictures!!
- Stock amp question
- GS300 a Classic?
- HELP - Lost brake pad anti-rattle clip!
- New to jzs14's
- New wheels on the Aristo
- What exhaust do you have on your cars ?
- anyone have this front lip on their car?
- Help!!!!
- Broken antenna on GS 300
- gas gage needle does not light
- Oil change.... 5, 5.5 or 6 quarts?
- Battery drain
- Mel & Joe from NYC (Tri-State 147's)
- question on gauge cluster
- Just some recent pictures
- Doors stuck.. Any ideas?
- Can someone tell me the name of this hose?
- gs300 swap cost
- question on air filters
- supra tt wheels question
- ALTERNATOR question
- overheating help
- Exhaust Smell / Failed Emissions
- anyone got on g-spider wheels?!
- Turbo timer on a gs300
- Transmission cooler line location
- Reducing overall car noise? Sound deadening material? Good idea or no?
- Need your input
- Uploaded some pics
- How to fix your seat and not break the bank ;)
- rear lights turn off when braking
- gs300
- first gen gs300 cut off when driven
- Brake Line Question
- 2 tone convert to 1 tone?
- Damnit!! How do i removal the interior panel from sunroof/moonroof
- new set of rims
- rim newbie here
- car wont crank
- got JDM on the track?
- Tires need advice
- Heat Valve motor?
- Aristo badge emblem whatever
- body help!
- Jdm 3 piece spoiler instal help
- now introducing the lexo!!!
- any CD changer??
- Stock radio troubles "HELP PLEASE"
- Outside door handle broke AND Child Safety Lock is on?
- Pictures of my Aristo
- speedometer acting up
- Supra TT front brake swap on my JDM Aristo
- Threw some new shoes on the GS
- 94 gs300 radiator replaced, can't find replacement for sensor
- carbon wrap
- nakamichi removal and aftermarket install.
- stock radio help
- ebay HID
- After Market Grills?
- Eibach spring drop?
- Wald Executive body kit?
- looking for a 93 gs wiring diagram
- 2jzgte vacum source issue.
- Need help
- I need help guys
- How to override 2004 GX470 Nav ver6.1
- Fishing pole on the back of my 1gs3???
- What is the name of the tan interior? 1996 GS300
- Question!!!!!!
- How about these wheels
- L.E.D. corner lights..
- MINI Photo Shoot
- Side Skirts....
- handbrake?
- coolant leaking need help!
- GS Speakers stoped working
- Brake Pressure/ Soft Brakes
- HID Issue, NEW to GS
- what oil should i use??????
- My Intro
- 1st gen gs300 transmission fluid
- how-to on a fmic install?
- Its Coming Along Nicely......
- Battery Guage Question
- lower control arm bushing trouble
- Custom GTE spark cover - just need an emblem
- gs300
- 1jzgte gs300
- My 1st gen G introduction
- 97 gsr for my 94 gs300
- 94 gs-300
- wiring problems
- 93 GS300 brake pedal falling
- Do you really know what is installed on your GS?
- power steering
- Lower control arm bushing
- rear control arm
- HELP!!! request
- Window Motor
- driver side lower suspension arm
- power steering hose
- ls400 maf upgrade?
- Car is overheating and no heat
- selling my aristo asap 6k!
- driver door lock trouble
- 93 Front Caliper Replacement
- I might get kicked out... but it is worth the chance.....
- Aristo conversion question
- jdm bumper question.
- My window wont go up!!?!
- stock amp
- Torque converter 1U&2J interchangable?
- i need rims
- has anyone tried....
- Looking for pics of RCA's installed.
- Sliding Pin to Torque Plate are seized...
- Fog lights not working :(
- Nakamichi Subwoofer Question?
- Bent Rim
- One Piece / Two Piece Headlamps
- gs300 auto trans question
- aftermarket grille
- Lean and Mean
- FIND: LCA Bushings
- Just in case anyone is curious how an RCA works
- condensation in tail lights
- A few teaser pics...
- what cars are in your driveway???
- Oh no electrical problems
- Big Day for my Car today
- Wheel fitment
- Specs on my MPG
- Chrome Badges???
- Just replacd the head gasket and now car wont start
- An odd request for you GS guys
- question on Tune-up
- Help!!!!
- Question: Check Engine & Traction Control Light
- engine swapping
- Key wont turn
- Fuses
- Funny GS300 pic I thought I'd share.
- behrman aero
- tein bushing help
- lower control arm woes
- Changing Spark Plugs on 1995 GS 300
- Intermitting O/D Off light blinking
- 1jz running on aristo harness
- Got some new rims but they need adapter! How will it look?
- Anyone ever figure it out?
- Custom Interior
- Fuses box location
- Replacing head gasket on a 2jzge looking for tips
- Need wiring pinout for alternator
- no antenna movement!!!
- JDM aristo on 20`s
- happy to get my Lexus back
- Best engine retailer? I need a GTE motor.
- Slammed on 17's
- beef up gs stock engine
- no heater/ac ??
- For guys with in-dash gps
- Interchangable Suspension Parts: Parts that work on our chassis.
- New Radiator Question..
- Motor Mounts?
- blower motor wont work, 12v outlet not working, stock amp unpluged.
- Coilovers Setup
- inserting a new radiator
- quick radio question
- O2 Sensors Location
- alternator fuse
- other Oil leak
- Spray paint?
- I love my GS
- OEM Navi for 1st Gen GS
- OBD I vs OBD II 2jzge any differences?
- Clean OEM Rims for 93 GS
- LED tail lights
- aristo 3 piece wing
- Diagnostic port
- New to CL
- Suspension: 2nd gen adjustable arms and rear camber question
- Would it be tacky/ricer if I rebadged my Gs with the new emblems?
- having audio problems
- Leaking Cam Seal? or Leaking Head Gasket?
- Engine Swap 911 Help please!! I will pay money!!
- Thinking of Getting a 94 GS300
- Toyota Aristo upgraded Fuel System FAQ
- Bypass Factory AMP easy way
- New to Club Lexus
- someone with thech plze help!
- 1st gen shifter replace
- Aristo Front Bumper ??
- Looking for 1st Gen GS300 Fender flares, anyone?
- 93 gs300 manual swap
- 1993-1997 1st Gen GS CLEAR Headlight lenses in GLASS
- mkiv supra control arms and tie rods
- front lip
- selling the gs...
- GTE Sputtering/Detonating - Please help me figure this one out..
- vis cyper/adl admiral style front bumper
- Speed Sensor Compatibility?
- SC300 seats fitment?
- Body Kit suggestions
- aristo vs gs300 headlights.
- acceleration feels better after...
- Project Failure Analysis
- Looking to custom make my 93 lexus gs00 headlights
- gs turbo question
- New Guy & PCV removal
- UZS143 AWD front clip
- Turbo on stock GS
- Car won't start from the turbos?
- I don't know what's happening
- some1 please help me!
- P0161 Check engine Light
- a white day in nyc...
- anyone done to clear center tail light?
- GS300 TEIN HA Full COILOVER SUSPENSION
- 95 gs
- Think about it for a second
- This GS300 2jz-gte + 6spd
- Another new guy
- noob to CL
- 20" on first gen rims offset questions
- Dose anyone know what or where this wire goes?
- window pulley and cable lines
- gs300 vs supra?
- lag?
- No sound from speakers, amp unhooked
- Reat Window Installation
- Where is the rear 3rd brake light plug?/?
- transmission upgrades
