- Philips Hid Ballast mounting
- VERY very lo beams how do i fix
- Lights
- Evasive loose HID connection
- HID Conversion kits
- One piece headlights for 1st gen LS
- 95 es300 Hid installation
- tail light relay
- Upgrading to HID (involving Self-Leveling Motor)
- Colored Housings for HIDs?
- Strange Lighting Problem?
- Clearing Corners
- Removing moonroof / map light panel for one-of-a-kind / first ever on CL mod?
- 96LS warning light on cluster
- xenon depot 6500k hids
- 2004 ES330 HID Lights.
- New Lighting Mods Done
- Looking for single OEM HID bulb OR suggenstions on good place to buy 6000K online
- adjusting fog lights
- Headlight Aiming
- Fog light problem
- info on aftermarket HID SAFETY issue
- high-mounted stop light bulb replacement
- backlight light mod
- what about these 6000k hid bulbs
- led headlights.will lexus follow
- LS400 HID/Halogen
- LS430 Mirror Puddle Lamps
- Sylvania Silver star 9005ST
- What do you guys think of these?
- Ladies and Gents.....The GS Retro is done!!!!
- HID laws in Florida
- OEM HID auto leveling system
- HID question
- reaiming headlights on 94 ls400
- Projectors?? hook up?
- My own ECE Bosch (E46) Retro on my ES300
- New GS retrofit
- q45 projectors already installed from japan??
- HID High Beams
- retro help - removing headlight glass
- sc300/400 new body style fog lights
- Aftermarket HID vs. OEM Lexus HID's ???
- Need help adjusting Headlights UP w.HID
- ES300 bulb replacement
- HID bulb interchangable?
- Has anybody ever had Hi/Low HID kit installed (95 LS) ?
- 9006 to OEM HID ballast adapter?
- HID kit help
- Whoa HID Overload!!! HEhee
- GS430 Clear Corners
- Does any one have HID Fog?
- Holy smokes! Look at this GS retrofit!!!
- OEM HID Housing install to NON-HID GS
- M6 reverse light application
- GS400/GS430 HID Cut-off Line Picture!
- 2001 Lexus GS Aftermarket Lights
- anyone know how to read schematics???- (for drl mod)!!
- Looking for 92-96 ES300 Headlamp set
- Ballast mounting?
- Foglights on GS430
- Please help me on HID stuff. (for IS300)
- HID Swap on LS400
- 98 GS tail lights....help?
- Need verification help: Are these real E39's?
- HELLA Ballast compared with PHILIPS Ballast.
- es300 rear tail lights
- HID headlights
- relay? corroded and rusted on my aftermarket HID
- Yellow OEM foglights
- HID flickering
- HIDs?
- Fuses
- SC400 E39 retrofit Completed
- Yellow fogs
- what can I do?
- guys, need help on certain bulbs
- LED Replacement Bulbs
- I put in my hid's....bulb didnt fit, i made them fit (aha) BUT...
- H3 Fog Bulb Keeps Burning Out???
- Can you help please
- Help with Hids
- hid kit help
- 9006 hid on gs300
- 9006 HID on a GS300
- HID Headlights
- Why is it so hot
- 6000k burn in time?????
- Has anyone?
- anyone done the fog mod and had it work normal in auto mode???
- Piaa H3C
- GX 470 Headlight
- HID's in Taiwan
- who has sc300, with yellow fogs?
- Help Please!!!!
- Fog light mod on a gs
- HID cuts off sometimes... help..
- Healight has a foog look *Help*
- HID? Dumb Question
- Where can i buy philips 6000k dr2 bulbs
- Which Wedge bulbs are you guys using for your SC?
- Hacker in the HID forum! (hidforum.com)
- Which H3 Bulb will match Silverstar?
- HID housing power socket
- Small orange lights ( I dont know what they call them)
- Adjusting and aligning new headlights in SC
- Angel eyes turining differnet colors?
- Superflux leds?
- Mounting the Ballast in The 400
- Connecting the Ballst
- Reflectors or Projectors???
- whoever said the 9LEDs matched 6000Ks perfectly
- Whats The Best HID Bulb for the sc300??
- Which light buld should i buy?
- Which projector to use?
- xenon hid headlamps
- ES300 HID RetroFit Pictures/Questions
- Weird headlight assembly or not ?
- City lights, fogs, and rear lights won't turn on!
- Hid
- Has anyone bought from jus4bulbs@yahoo.com?????Hey
- burn in period for HIDs?
- Difference between D2S and D2R?
- Changing HID bulbs for 1998 LS400
- Removing the projextor
- Leveling Motors
- LED light bars for turn signals?
- Fog light problem... WTF!!!!
- Need help. I blew something!!
- Dash LEDs
- 1995 SC 300 H3 Fog replacement
- H4 Hi/Low kit for 95 LS. Any benefits ?
- Condensation Problem
- Piaa H3 Gt-X Vs Piaa Spark Blue
- Where Online
- searching for philips ultinon
- confused about this custom HID kit i bought.. help please
- need good hid's
- HID retrofit for 96 LS??
- xenon mods
- repairing 94 LS Deer Impact damage.
- Anyone know much about DDE Halo Lights?
- HID conversion
- Replacing the 2nd light on the main Headlight
- Installing Hella Supertones
- headlight bulbs
- Piaa Bulbs
- how do you adjust headlights
- projection headlamp conversion kits?
- 01 430 DRL questions
- Awesome HID Retrofit featuring a first gen 3000GT
- HID's 95 Sc300 Tutorial w/ Pics!
- Philips Bulb question
- Buying Replacement 6000k bulbs?...
- HID questions for ES300
- LED's for turn signals??
- HID bulb vs. HID kit
- Tiny light bulbs inside heated seat switch REPLACEABLE?
- sc300 map/dome light bulb part #s
- Reconnecting HeadLamps
- Clear Lenses
- same OEM HID bulb, different color?
- MY climate control backlight doesnt work.. wonder why?
- IS300 Projectors and HID retrofitted on SC300/400
- Headlight accents!! COOL LOOK ON YOUR CAR!
- how much effort to retrofit D2R bulbs into the stock GS halogen headlights
- 2004 Lexus LS430 LED Tail Lights
- JP Tail Turn Signal Testing + LED vs Incandescent Bulbs
- ANYONE tried replacing the LEDs in their Dash?
- RE: H.I.D. Installation -MANARAY HELP!!
- Headlights!!
- Bulb Out
- Problem: 4500K to 6000K bulbs
- Xenon Depot 8000K
- Headlights/Turn Signal
- LEDs - Wedge Bulb options (2GS & 3GS) comparison
- Daytime Running Lights Module
- Removing Headlights on GS300
- RX330 HIDs, too low?
- Done HID foglight on your GX??
- hid costs
- Catz HID replacement bulbs
- Rear Door Panel Lights Not Working?
- DRL and HID question
- Is there anyway to convert Hid bulb H4 ->9006?
- RX330 HID Matching
- hid bulb, it only take one shot to...
- GX's have projectors? Chance of Retro?
- clear fog lamps and new lights for rear spoiler
- projectors
- Hmmm..what's going on with my foglight? and more...
- Hmmm..what's wrong with my foglight?
- Hid Harness Missing *Help*
- 97 style wing needs brake light wiring?
- Puzzling Tail Lamp Problem
- 99 gs400 head light wiring
- LS400 tail light bulb housing rusted.....
- nice resource for bulb types
- Need help w/ light pods
- Problem with adaptive headlights
- factory HID problem
- Shifter Light?
- Help please
- Q45 Projector Mod???
- 94 LS 400 HID Install
- changing HID bulbs
- hid problem need help
- Lighting Upgrade with my SC4 and questions
- Did anyone swap out their stock HID to 6000k or higher? (GS)
- I need to find
- Can Anyone Help
- Post pics of your beam pattern
- FInal shots of my retro....E39 color modded for my 1995 ES300
- H7 6000K HID kit from XenonDepot
- Sc430 Hid
- E39 projector?
- My 6000K HID Bimmer 5 Series retros on an SC
- 2000 ES Headlamp Removal
- McCulloch HID'S
- Sc dome light bulb size?
- 9-LED lights for 1st gen GS?
- Please help me get back to stock
- Whooaaa look what came in the mail 9led 194
- projector fog light
- My new M5 projector retrofit on my 1995 Es300!
- What Kind Of Bulbs Are These??
- GS300/400/430 "DRL LEDs" advertised in Lexstasy.com are really "Parking Light LEDs&qu
- Piaa Super Plasma GTX no Match for 6000k
- phillips 6000k Ultinon
- need advise for getting a HID..
- Size of projector
- High Beam Adj?
- Phillips 6000k kit from xenondepot
- Key Ignition Light (GS) bulb swap to LED....Lots of pics
- SC HID ballast mounting areas
- Installing Phillips Ultinon Kit 9006
- so lets talk Q45 mods!!!
- Tired of Weak Trunk Light
- Different types of SMD LEDs (#194)
- 19 LED Bulbs -> Turn Signals IS3
- SC300/SC400 Footwell Lighting
- piaa super plasma led wedge
- Polarg M6 help...
- Adjusting the headlight aim
- Converting to LED
