- passenger window
- Looking at getting an LS430, need advice
- Finally got a LS430....
- LS430 with a history of oil leak repairs
- shock & Strut Assembly
- 2004 LS430 can't fill gas in. Can't figure out what it is...
- Engine Coolant Temp Hot - Troubleshooting
- lets see all the half aero kits
- Undercover - Replacement Grommets?
- Plugs for DVD player?
- what would it take to hydrolock the car
- opinions on replacement key to open trunk
- What is causing stabilizer bar links to break?
- Timing Belt Done by an Indy
- Troubleshooting advice
- Knock Sensor Hack - Stage 2+ Top-mount Single-wire
- didn't realize how lazy I'd become (bucket washed today))
- Clean your sunroof drains!
- Found an obd2 scanner that works!
- Hoping to take the plunge
- Finished installing my Toyota OEM option COMPLETE lip kit on the LS
- smart key if not detected / wonder if this works for us
- Help...steering wheel shake
- Bubbles on leather dashboard (Custom Luxury)
- Seatbelt won't retract
- Evaporator Core Leak
- Cheap LED third brake light
- Mirror anatomy
- 2003, 70k miles, base model. $8000?
- Damn VSC / CEL - but no communication at OBD
- headlight Low beam stop working sometimes, is it the bulb or the ballast?
- LS430 Auto Insurance (modified car)
- 2005 LS430 A/C and Jerking Issues
- Dragrace LS430 vs e55 found on youtube in Russia!
- 2001 LS430 UL Air Suspension ECU / DTC Codes
- Cleaning seat belt
- What do you think of this wheels? Euroline 18 inch small dish
- Briarwood
- Junkyard trip this weekend
- Tanabe NF210/Strut Questions
- Timing Belt Planned - Napa kit being used
- LS Taillight Issues
- LS 430 questions
- Switching fora,LS 1st gen to 3rd gen
- Ls430 expectations
- who has dropped all insurance other than liability?
- Automtive magazine requested op-ed on aftermarket parts - need input
- Datasystem
- First dent!!!
- What is error code- P1346 and P1349?
- O2 readings 01 LS430 UL and exhaust leak? Or what...
- Exhaust manifold Hole?
- New GPS need to remove the surround
- I was lost but I have found redemption.....
- Levinson Amp Repair-Factory Radios
- Need help! Stripped timing belt tensioner assembly bolt.
- Picking up a 2005 later this week!
- 2003 60K miles $8000?
- Where to tap a vacuum from the engine for a valce exhaust. 3uz-fe
- 2001 Lexus LS430 performance exhaust system?
- 2001 LS430 Fuel Gauge Bad?
- 2004 UL rear air strut PN 48090-50110 vs 48090-50130
- Accuracy of on board computer for gas mileage
- Seat Cover Options
- 03 LS430 - Running Engine With Valve Cover Off
- low tire pressure light not turning off or initializing when button pressed
- Front Passenger Power Window and Door Lock stop working
- Can new trans fluid cause clutch to slip ?
- How do you polish cloudy headlight lens covers
- Considering 04-06 UL
- Beat sonic installed with pioneer double din. (Picture) button not working.
- Some LS430 owners (Shakes his head)
- Cracked Radiator
- 2001 LS430 - 100K miles, $6k?
- How to replace cam seal
- Good Deals Found - Looking to Buy
- Trunk lid hard to latch ****
- ls430 engine won't rev past 2k rpm + fuel smell
- the size of the trunk never gets old
- Vaistech Aux Unit for Flash Drive
- Oil pan thread worn?
- Mark Levinson speakers
- 2005 UL Door Lock Intermittent Operation
- '06 LS 430 potential purchase pricing?
- Pictures of back of Nav System (01-03)
- How to make horn sound when locked using remote
- Replace shifter slide cover
- Steering wobbles
- Question about center pillar trim removal and install
- Land yacht xing
- 04 LS 430 Rear bumper cover
- SRS light staying on
- Drivers side door check?
- 05 Gold LS430 w/ BeatSonic Equipped
- Style 95 Wheels
- finally did my plugs at 118.5k
- tie down trunk lid?
- Tints and wheels
- Navigation hatred
- Anyone running M35 19" Double Spoke wheels ?
- Early and Facelift Smart Key
- 2004 LS430 trunk release under left side dash does not work?
- Selling my LS430 Ultra
- Beatsonic on non-nav non-ul does not retain steering wheel volume control
- Briarwood + saddle + navi found
- 2005 Creampuff Burgundy LS430 w/carfax
- Ultra Racing Sways & Understeer
- New question on steering wheel covers
- Rain sensor diagnosis
- 430 UL Rear Seats into non UL
- 2004 LS430 Maint. required soon light goes on when I start the car
- How low can I go?
- Android Stereo into LS430
- 430 Celsior in Australia
- Need Beatsonic installation manual
- Question with rear seat belt?
- Just some pics
- How to measure wheels for replacement
- Non-LED Brake Light Bulbs
- Radio/CD changer removal "4 bolts and its out"
- No Lexus service history
- Steering Knock Solution
- Is the rear seat belts all the same 01 - 06?
- LS 430 2001 needs two oxygen sensors
- Ac stops cooling suddenly
- Twin Turbo 3uzfe (Discussion)
- How to wire fender turn signal light
- 2004 LS430 Power steering and air went at same time?
- DIY LS430 Steering Wheel Centering/ ZERO STEERING ANGLE POINT
- Need help------ Exhaust help
- What did I found today on aliexpress for the LS430
- ABS brake bleeding
- Can excessive outside temperatures cause actuator failure?
- Wing mirror not unfolding
- Rear visor hooks
- Car started but wont accelerate
- VAIS Tech help request
- Cylinder 3 misfire (P0303) T/S Assistance
- Fender help
- Steering wheel locks up on hard acceleration
- My first ls
- Passenger side rear proximity sensor problem.
- Tail Lamp Question
- Did suspension updates, and this came on
- Is my car about to go downhill?
- Leather care
- Insights on LS 430 Prices ...
- Check Sonar Message
- Distorted View on driver side mirrors?
- How did your LS 430 timing belt look?
- rear left upper control arm
- Looking for advice on Air Suspension Conversion
- 2002 Base Purchase
- Suspension noise likely not caused by the usual suspect (LCA bushings)
- handicapped placard
- how to stop driver's seat from adjusting?
- Anyone done complete suspension overhaul?
- Need advice- 2006 LS 430 jerks when stopping and new ECM
- FS items belong only in the marketplace
- Steering wheel vibration lasting 1-2 mins only?
- Paint, buff or what?
- I need a medium sized favor
- wheel refinishing
- Bought my first Lexus 06 LS430
- Opinions on Platinum Blue Metallic LS430!
- Mismatched Optioned LS 430?
- 200,000 posts on this forum
- low volume in nav system but other volumes okay
- Car still not fixed after body shop repair
- Engine starting issue
- what does this mean? 02 sensor?
- '05 LS 430 Console ashtray conversion kit
- After Market Backup camera
- Inside cabin air filters. for 2004 LS430
- Diy: Replacing rear air struts 2001 ls 430
- Driver Seat Turning Pink on Seat and Back
- Crankshaft position sensor location?
- Car stalling out with warm engine
- 2001 LS430 wheel spacers
- Engine oil for LS430
- Had a flat, looking for better tools
- 17X7.5 or 17X8 Rim?
- MRR HR3's on LS 430 - rubbing issues
- Feel any difference with a different tyre size?
- Lexus TRD LS 430
- Replacement Perf Leather Dr seat cover
- VSC/Trac questions LS430 05’
- Electrical symptoms, maybe bad battery or spike?
- LET ME KNOW!! - What Brand & Grade Oil + more Questions
- DIY LS430 VSV (VACUUM SWITCHING VALVE) for EVAP cleaning / replacement procedure
- Wheel lock key
- Rattling, diesel like noise upon accelerating
- My shop nightmare
- what is this wire?
- muffler parts diagram help
- Wix Filter
- Car Just Overheated Bad: Is the Engine Done?
- 2001 LS430 rattle steering column area
- Clicking sound from rear of vehicle?
- po430 and tid code thinking O2 sensor?
- rear wheel centering
- Aftermarket Android headunit for non-navigation LS 430
- Back in the saddle
- They wouldn' rotate my tires!!! ARGGG
- Questions: Updating 2001 LS430 to 2006 LS430 Navigation
- What role does your LS play?
- New LS owner
- How about this 2005?
- Ls 430 speedometer wrong readings
- Potentially a new owner on a low mileage ls430,what are the proper steps to look for?
- Looking for a reputable mechanic/shop to do a PPI in the Tampa, FL area
- Car does not start? Need help!
- Looking for a UL Ls430
- Key plate - how important is it?
- Need help fast
- PS Reservoir Hose size ID
- Time to change my timing belt (again)
- Tire pressure warning
- Side Mirror Fix?
- 04 LS430 Audio Distortion
- What to look for when buying an 2005 base with 111,000 miles
- Torn perforated leather
- Passenger's side door mirror intermittent bug
- Trailer Wiring Harness Causing Electrical/Electronic Issues???
- sunroof opened while driving
- Vais SL3B-L SoundLinQ3 INSTALL HELP
- BT45 set-up/settings help
- 2005 LS430 Possible Alternator Problem
- Adjusting Camber ?
- Exhaust Y pipe options?
- 2006 LS 430 Motor Mount
- Anyone replace a high pressure power steering line?
- A/C Temp
- Total Transmission Capacity ?
- 2002 Tire pressure
- Nav screen issue
- Exhaust drone noise
- LS430 as a work car
- Does not always Crank at first try
- 2004 Ultra-Luxury?
- LS 430 Going forward in neutral and reverse after solenoid change.
- AC blows warm 1st time car is driven for the day, once restarted works fine
- drop time a lil help please
- Check VSC light on when car moves
- Moisture in Headlight Assembly
- Rats nest and chewed wire
- 2005 LS430 Po442 Code
- 2003 Lexus 430 CD player error
- Replaced Battery, Now bluetooth acts up
