- New tires soon but gotta ask yalls opinion on something.
- Side Window Visor Installation
- 02 ls430 actuator motor screw...see image
- Mufflers?????????
- engine concerns
- New to here... (but not new to Lexus)
- 02 Navigation Problem
- ls460 rims on a ls430
- sunshade bouncy - any way to stabilize?
- ANYONE NEAR ROCHESTER NY TO LOOK AT A CAR ls430??
- Datasystems controller
- Recent additions to the Mark Lev.
- $117 for an oil change
- question about stock intake box
- Air rides issue
- Front seat removal - need help
- 2004 LS430 wheel alignment data
- Should Sirius Receiver Be Grounded ?
- Ordering body kit source for 02' Ls430
- LS430 '02 Bright Red Speedo/Tach Needles
- My First Mod......
- Help with wheels fitment
- 01-06 LS430 window visors part number.
- Pulling the air sus. fuse?
- Looking for hood bonnet
- Need help identifying part behind rear seat
- Wheel question, will 245/35 20" affect the way my LS430 drives?
- Wheel offset and tire size confirmation please help
- Smartkey system fixed itself?
- Wiring harness
- NAVI error question
- weird question about climate temp setting
- Now a PCS sensor?
- Height Sensor - 2006 LS430
- 03 LS430 UL Navi problem need help!! plzzzzz
- Is there a way to stop all that beeping?
- Correct rear A/C filter for 2004 UL
- Navi issuse,,,need help
- Window Visors and Chrome Door Handles
- Need an inexpensive parking sensor source
- oem absorber 48510-80307 vs KYB GR2
- 02 LS430 Power door lock problem
- Option to Customize LS430 Functions
- Do the heavyduty extensions really work
- detector invisicord and blendmount for ls
- Maintainance Required Error/Check PCS Error :-(
- 05 vs 99 Waterpump interchangability
- 245x35x19 tire on a 19x10" rim
- Motorola DROID - send phonebook / contacts
- ls430 stock bags
- Does customization impact resale
- will 17" 01-03 wheels fit 04-06?
- Hood Release Cable installation
- Air Purifier
- code p o 440
- Dings. It never fails to happen!
- HELP! Suggestions on Airsuspension controller for 03 LS430 UL!!
- Increased Tire Size?
- Looking ls430 parts
- DRL's not working
- 2004 LS430 Radio work no sound
- Doors lock when I open trunk.
- Replaced o2 sensor - now mpg stinks!
- Opinions on tire size
- Anyone have a pic of LS430 with 20" Volk GT?
- sl2i installed but have a quick question
- Tilt Steering Does Not work
- HELP PLEASE! Lowering ls430ul...
- Replacing my 430 chrome grill
- 2004 LS430 auto tran rear gear oil
- Wheel Fitment Question for LS430
- on/off air switch
- YouZealand SS Kit vs Tanabe NF210
- Super Glue on wood finish WTF?
- Black Cherry Pearl???
- 2001 LS430 timing belt change
- lower springs or coilover
- ASC680 Air Contoller ride
- Considering a CPO '06 LS w/15k mi
- Gas Issues
- IM back what you guys think?
- Zaino!
- How do you reset the "maint reqd" message?
- Mint ls430 in florida
- Headlight Restoration on the budget.
- Change ashtray to cell phone holder
- data systems wiring harness
- Awesome handling from my ls430 upgrade.
- a/c takes a while to blow cold air
- Hi guys, New here but like to hear some sugguestions.
- Tail light Failure warning
- 19 tires questions
- Flashing Orange "AFS OFF" light on dash. '05
- DICE iPod integration.. DON't Like it!
- 60k Mile Service Upcoming
- New to CL, my LS 430 UL..
- All I want is less sway........
- Could this be a Problem to my Ultra Air Suspension??
- Saved By Replacing My Radiator On Time !!!!
- air suspension conversion
- God hates my bumper... it's true.
- Goodyear Comfortred TOURING
- Lexus Link Error Message
- Crazy tranny problems, fluid pouring out around dipstick!
- torque specs
- VIP Presentation
- re-program smart key
- Flat Tire
- Maintenance at 14k miles? What to do...
- Fog light rewire??!!
- Post-Cat O2 Sensors in 05 LS430
- Auto Stick mode do you use it much or not
- Best online place to buy OE rims?
- maintenance reminder
- Looking to buy left fog light and frot parking sensor
- Is it normal for the parking sensors to be faulty one day and work the next?
- 2004,2006 LS430 or 2007 LS460
- Samrt key disappear in the car
- Do you think a Lexus Warranty is Worth it on a UL 430?
- I got a LS...finally!
- New to CL intro (yeah... another one :-)
- Just doin a minor update!
- No adjustment to rear camber?
- steering vibrating when drive on "some" highway speed over 70/mph
- Just bought an '01 LS430 guys
- Wheel Question
- front wheel hub removal
- Navigation map updates, want to sell your older one cheap?
- Lexus LS vs BMW 7
- ipod
- Extra insulation?
- Rear sunshade squeaks when its hot
- need help in selecting width and offset...
- Preparing to Install Aftermarket Subwoofer & Amp in UL - Need Some Confirmation First
- normal or sport which will last longer?
- Mpg??! Ls430
- Who has white LS430 w/ black interior?
- New Lexus Owner - remote key problem
- Finding my first LS! What do you think?
- I'm back in the game with a new LS!
- Just picked up my first LS!
- crazy thought anyone use beaded seat covers?
- Update for Dajap's LS430
- 04 ls430 5-speed automatic?
- I Thought my Car Was Broken - I Was Wrong
- Replacement plastic screw rivets-need source/part numbers
- 430 Engine Miss
- Shift indicator light replaement
- Does LS430 have seatbelt tension reducer?
- v-led drl led question
- Ground Wire attachment Location
- Brake Issue?
- What to expect from an LS430 with 170,000 miles
- Does leaving an iPod hooked up to SL2i run down the battery?
- New Member! White 04 UL
- Engine Idle Low
- Leather seat question...
- tire pressure sensor on the rears?
- Run Rite Engine Snake?
- so what exactly is leather
- Navigation harness picture needed really bad
- 2004 Nearing end of 100K Warranty
- How Did I Do?
- Installed Vais Tech, but still have to hit "I Agree" on annoying nag screen
- Stupid question: Does the 430 (2006) have an aux input?
- LS 430 grill
- High adjustment
- How to remove DS wiper arm?
- another going from UL to coilovers thread; my turn
- Enging braking?
- Need Help
- VSC Light came on! HELP
- LS Enjoyment!
- Cost for Dealer to Repair Steering Column Retract / Extend?
- just saw a 06 ul w/ pcs for sale,, fyi
- i missed my 430...........
- Pros and cons of driving in ECT Power mode (posted in SC section as well)
- Is the LS430 the second fastest Lexus?
- ANybody try buying LED aftermarket TailLights...
- Differntial Fluid
- Sick to my stomach- ruined weather stripping! BE CAREFUL!
- Remove Calcium Deposits on Windshields
- Anybody running 21" wheels?
- Moonroof Problem
- 2004 Ls430
- Time for another battery?
- Changing O2 sensors bank 1 and 2 for 02LS430 HELP!!!
- Tint questions
- WTB: LS430 wheels!
- 22's or 24's on an LS430
- Picture request
- Snow setting in the rain....
- Blown speaker/speakers with the ML system.
- CL archive page from Jul 2001,
- year of manufacturer, need help
- Can U upgrade a non navigation ls430 to navigation easily"newbie"
- Lost both Smart Keys
- Chrome trim on rear bumper.
- whats the best place to buy OEM parts...
- Where to place decal on front windshield?
- What to pay? '04 with 30k miles?
- The dealer I went to uses 5w20 oil on all of its Lexus cars
- transporting car cross country
- LS vs. the competition
- The LS I want to buy has an airbag light on. Should I pass?
- Chrome Wheels in Winter?
- Driving without smart key?
- Top engine cover(s)--leave them on or remove them
- Time for new tires
- What's next after your LS430: Poll
- How to know if amp out
- Hello from San Diego
- Red Caution triangle
- amp install- tapping rear fuse box or ML amp
- Fresh Oil... Removal Advice?
- Set air suspension height to high, safe to jack car?
- Occasional chime when driving, nothing on display
- opinions on turanzas
- 90 k service went well
- Need help with wheel selection
- How do we feel about exhaust? rumble or no rumble?
- When it Rain it Pours
- Throttle body + MAF cleaning
- Suspension 2001 and 2004 year
- New Member 06 LS430, Chrome Wheel Question
- Vaistech VML Installation Details for 2004 LS430 Modern Luxury
- Mirror folding motors.
- Too late for Synthetic Oil?
- 05 w/ 53k miles just had side mirror break and now smartkey died
- Thinking about a portable GPS - where do you mount it?
- footwell lighting...
- LS AC Seat question...
- Stinky AC
- Bluetooth Question
- I need lexus owners opinion (sell or not)
- First Trip in the LS430
- LS 430 - Front Passenger side Door Lock
- Where's the thread on tightening the console lid hinge?`
- Lexus Platinum Extended Warranty--question
- Dash check warning lights ls 430
- DVD Options for my LS
- has anyone ever used this for touch ups?
- Need lighting help!
- removing the beverage cooler
- Ls430 UL on Megan coilover
- Looking for LS430 info
- 01-03 ls430 headlights and taillights??
- Not for the faint hearted!
- air ride suspension converstion to stock question.
- How Do I Remove Interior Wood Trim Pieces to Install Console Ashtray Alternative?
