- Navigation Alternative?
- P0002 code 2007 is350
- Transmission problems P2757
- 2012 IS250 driver side headlight has a reddish tint to it..
- Question about climate control
- 20” Wheels on IS250, Rubbing issue and fix
- Missing crossmember ?
- 2008 lexus is250
- Door lock
- YOUR Muffler Delete? Did it cause drone?
- Aftermarket intake PIPE?
- Door unlocking Actuator issue 2011 IS 350
- Weird headlight bubbles
- Automated Vehicle Recognition System Identification Label
- Need Video Input and Screen Bypass module
- Need Fly Audio Navigation card
- Best bang for buck exhaust mod?
- 1 piece aluminum drive shaft?
- Factory backup camera guide lines?
- Tyre Size affecting TPMS?
- Yaw rate sensor
- Looking for stereo upgrade recommendations
- 2020-04, open highways = improved MPG's (+3 MPG)
- Square Tires on Staggered Wheels for AWD
- 07 is250 AWD front shaft
- 3p controller mount build!
- *Help* Rotten Egg Smell When Going Full Throttle
- Slip Indicator Warning Light on after switching Rims/Tires
- Lexus IS350 & IS250 Most Common Maintenance Issues Explained!
- 4GR tuning. (IS250)
- Need help replacing driver mirror glass
- Fumoto Oil Change Valve - Anyone use it?
- Updating 2008 IS250 Navigation?
- Where to buy is350 emblem?
- Car won't start unless the engine is cold...
- Slight Vibration at Idle when A/C Off
- Touch up paint? Where to buy?
- Have to replace cats in my 07 IS350
- What $50 just bought my IS350
- ISF Wheels on IS250C will it rub on bumper or fender?
- Opinion on tire size for new wheels
- Corroded Side Mirrors Pushing Out & Cracking Plastic Housing
- Help getting passenger door open after lock actuator change
- Have y'all done WINDOW TINT yourself?
- Thinking of buying a 2007 IS250 with 97k
- Smart Tap CF18 Turn Indicator Module
- 245/40/18 Square on IS350?
- Dash "R" light + Reverse camera dont turn on
- Wheel Fitment
- IS220D Limp mode until warmed up
- Wheel fitment (Lexus is350 2006)
- Passenger window opening mysteriously
- Carbon Shake - Why only after Engine warms-up?
- 2006 vs 2010 reverse camera
- Lexus IS350 - transmission, wrong TC can I put a different TC in transmission
- Hand Cranking the eng. to close valves - How To?
- need to replace IS250 steering rack
- IS250 second Rev limiter?
- OEM Trunk Lid Spoiler Q? 2007 IS250
- 2010 IS250 rear liner
- Code P0453
- IS 250 - 2012, signal on radio issues
- 07 Base radio display buttons will not lights
- [Post pics✓] OF YOUR INTERIOR!
- Help Wanted: Load IS2 Parts into our system. Get paid and get discounts.
- [Post pics✓] Have you vinyl wrapped your EXTERIOR?
- Mobile1 and Penzoil Platinum Synthetic Oil
- sticky dash issues
- Does a 2014 midpipe fit a 2006 is250 RWD
- PCV Valve Question - 2007 IS250 RWD
- Is there a way to fully disable or remove immobilizer system on 2IS
- Is350 vland
- Trans fluid leak?
- Exhaust
- The Tesla Display Video install -with AMP and DSP
- Un-wrap Vinyl Wrap - Lexus IS350 '06
- Puddle lights
- Is it possible to remove manual tranmission without removing driver's side manifold
- Center console for a 2007 Manual IS 250
- Is it possible vinyl wrap dashboard in leather?
- One Oil Type for RX450h & IS250
- IS220d Fuel leak issue, can't identify part name or number
- New 2007 IS350 owner + wheels and TPMS question
- 2IS wipers not working in intermittent or auto mode
- Do these look legit and what would u say they are worth
- OZ Racing Nova 2
- 2006 is350 Mods
- Having a Door Actuator problem I believe (2011 IS350)
- Grinding noise on new brakes
- Preferred Alignment Shops
- P0390 help!
- "Check Air Conditioner" notification after alternator replacement
- sunroof wont close
- Please help Trunk lift support 2007 IS250
- 07 rwd is250 transmission question
- How do 18x9.5 +35 squared TE37 look on 2nd gen is?
- Will IS300 Seat brackets work in the 2IS?
- Car won’t start after replacing alternator.
- Fortune Auto 500 Series Coilovers? Opinions?
- 2013 Auto Tran on 2006 IS
- P2714 - Pressure Control Solenoid "D" Performance or Stuck OFF
- Urgent coilover clunk/pop noise
- Paint/sway bar question
- Denso alternator part number???
- Are my headlights auto leveling
- Steep learning curve
- 2006 IS350 Headlight Help
- Anybody change their own Tpms sensor
- Is250 won’t start
- 2007 Skid ECU on 2006 IS350
- Where is the actual part number for RA62 manual transmission?
- Best Aftermarket Headlights?
- Techstream for VLANDs: Anyone near VA/DC/MD
- manual trans shift boot problems
- To my fellow enthusiasts
- Looking to buy a Aimgain Kit
- OEM gen 2 axleback exhaust
- How many miles before the junkyard?
- IS Gas Cap Replacement
- Why am I getting good gas mileage? (Ik that sounds crazy)
- You boys ever driven a Mazda 3 6mt (2015+)?
- Need help with foglight
- Fitment Question
- Is250 2008 pros
- Transmission fluid
- 2010 IS250 AWD mechanical issues
- 2011 questions
- Battery Icon appears and hard to steer car
- Bought an 06 IS 350
- Bought 2010 IS250
- Junkyard Dashboards
- Drone from IS250 AWD stock system
- Lexus IS 250 radio
- Swapping the Resonator
- Post-cat O2 sensors
- Transmission Fluid Flush
- CRC Intake valve cleaning review
- Help on finding parts location
- New is220d owner, fuse box help
- Used rubbing alcohol on a ebay mesh grill... some paint came off
- A Civic Type R owners Impression of a 2nd Gen IS350
- Part number identification
- Aftermarket Exhaust Help! - Hole in rusted mid pipe - RR Racing’s Invidia?
- 2010 IS250 No start
- To IS-F or keep the 2013 350
- Whining sound, kind of like pissed off cat
- Best Starter Mods I Can Do Myself?
- 2006 Lexus IS250 Engine Splash Shield (Undertray)
- Car keep pull to the right
- Dealership has agreed to replace dash & door panels
- Trouble code p2118
- gramlight 57dr 18x9.5 +38 fitment on lowered is350???
- 2008 Lexus is 250 awd wheel/tire sizing
- Help me pros
- Subwoofer hookups
- Ac relay location
- Pinout for steering switch
- Engine rattle,scratching
- Just bragging a bit, lol
- Is 250 2008 Nav
- 2IS front grill emblem
- TPMS issue
- Car doesn't start or crank
- Noise coming from back right please help
- Power door lock wires don't match - replaced doors
- Is220d coolant spraying engine bay
- Differnce between US Spec and Candaian Spec rotors
- Trunk won't close, trunk actuator going bad?
- Proud owner of a 2007 lexus is250 rwd.
- TPMS light on but TP is ok
- Interior lights? BRIGHTEST BRAND?
- OE Bumper cover clip part numbers
- Fair price for 06 IS350 no tranny.
- Afs (not working after bulb change)
- Buying a salvaged IS 350
- Which 08 2IS mesh grill should I buy?
- Out of warranty door panels becoming sticky
- Joe-Z Intake pipe rubber clamps
- 3IS Intake Pipe
- AWD aftermarket wheels
- Restored my IS headlights
- Car in "limp mode" according to stealership
- PLEASE HELP!! Power Steering/Battery Problem
- What is the best rear sway bar? Is it easy to install yourself?
- 2012 is350 revving on its own
- Transmission issue and flush/drain questions.
- Leaks :/
- Struct bracket arm - please help!!
- Simple mods? What are you're favorite simple mods?
- Resonator or muffler delete?
- IS250 Transmission judder issue
- Headlight bulbs to plug in bulbs
- Smart Access Handles
- Zero Throttle Response!! PLEASE HELP.
- Soft Brake Pedal
- 2008 IS350 Credit card key question
- PS light BREAK light no codes. RR Racing tune?
- latest 2006 is350 navigation map?
- Alternator or something else
- 07 is250 cylinder 4 misfire p0304
- High mileage oil residue
- Aftermarket headlamp assemblies
- What's your Average Fuel Mileage?
- Rear View Mirror Always Displaying North
- Diagnostic Codes B1421, B1424, B2281
- How to remove adhesive glue?
- Bad week for my lexus
- 250 spark plugs
- HELP! Please
- AWD Delete?
- Headlight bulb - back from the dead?
- Transmission Flush
- Wrecked my is350 :(
- 09-10 Front lip on 06-08 bumper
- Will these headlights fit my 2010 Is350?
- Is this an OEM IS-F Sway Bar?
- HELP: I swapped battery terminals on Battery... and now screwed!
- Selling 65mile PREMIUM is350???
- My IS350
- Automatic shift knob solutions?
- Girlfriend melted my clutch!
- Odd Temperature reading climate control
- Loose Shifter IS250 MT Help
- Headlight Wiring Problem.
- Transmission Oil Change DIY
- Giudance on Cam and Crank Sensor Codes
- 2006 IS250 AWD Pulled codes P0014, P0021, and low oil pressure
- Transmission Issues
- 2007 IS350 w/ 145k Miles
- Getting Serious about an 08 IS250
- Spoiler bolt on
- Cranking but not starting
- 2006 IS 250 Transmission Replacement (2010 Trans)
- Lexus IS 300 2010?
- Will F-Sport Rims/Tires Fit my 2010 IS250c 18"
- Disconnected battery now radio lights won’t work
- LFA replica wheels, still available?
- wheel and tire size
- Takeda Stage 2 CAI Fitment in 2013 IS250
- Is350 won’t start
- 2010 IS250C Steering feels like it flops in parking lot tight turns
- How difficult is a DIY brake job??
- Is350 Broken Radiator Cap w Pics
- Brighter Headlights
- 3rd gen steering wheel in 2nd gen?
- VLAND headlight baking open and mods
- DRLs dont work no more
- Expensive sound?
- Green start led, diags pass... wont start. Ideas?
- Thinking of getting an IS
