- CEL with 2 codes
- Battery Light high Rev
- Side skirt question....
- Exhuast Tips
- Scraping/Grinding/Whirring Sound when transmission is engaged
- Running on Spare tire.. Performance Increase, dependable for Snow and Rain?
- 2008 IS250 vs 2008 GS350 vs 2006 GS300
- Is Evasive Motorsports legit?
- how wide can i go? (tire setup)
- Changed the fuel filter
- Find your service records.
- New owner 2009 is250
- Lexus is250, AWD, 2008, Coolant problem
- Which techstream
- is250 reliability?
- Fiberglass bumper crack help?
- Problems since recall of passenger airbag
- Need Help!! [vsc, abs and traction control lights on after replacing wheel hub]
- what do these codes mean & what should i do ?
- ESPRIT Premiere Japan Front Bumper with 3IS Front Grill
- Need new D4S bulbs
- 2006 IS350 jerk after complete stop
- Beeping traction after removing steering Column
- Need Exhaust Help
- Trim moldings going bad
- Remove armrest
- Front End Damage: 2006 IS 250 AWD
- 2006 IS350 daily driver and cruiser
- HELP!!! Turn signal indicator flicking
- New alternator, battery light on, charge ok
- low oil presure 06 lexus is250 please help!
- ISF steering ECU Mod
- Enkei Raijin 19" Tire Fitment Sizes?
- SPC Camber Arms and Ball Joints: Will they fit AWD?
- Replacement headlight housing and front grill
- Tighten your coin tray!
- IS250 Recommendation
- VSC, ABS, BRAKE, TRAC Warnings On, Speedo not reading!
- Lexus IS 350 Issue.
- Need help with injectors
- Crashed is350, need opinions
- Fsport big brakes on is350 question
- DIY paint lip or send to shop?
- 3IS Steering wheel on 2IS?
- Fuel Leak Help
- Panel lights on, no A/C no PS
- Stop engine keep radio on?
- Review: IS250 IS350 Amazon/eBay pre-painted bumper
- Performance Mods
- Extremely Bad Gas Mileage
- Is the IS350 the right car for me?
- Battery and brake pads replacement question
- Lock car while running?
- So Cal local looking for 3is bumper install.
- My midpipe leaks
- lexus IS 250 Exhaust
- "11 IS350 fuel rail recall...make CEL turn on?
- Air inlet fasteners?
- Troubleshooting (2008 Lexus is250) car wont start
- Radiator Cap Broke. Piece fell into housing
- IS250 Carbon Build Up Issue
- 06 Lexus IS350 code p2714
- Headlight Problems
- Card holder
- new to the is world looking for audio system upgrade info
- 2006 IS250 112K Miles
- P0430 and pending P0420
- Strut removal issues.
- Code P0606?
- 2IS 18" F-Sport Wheel Lug Nuts
- Headlights fluttering
- Toyota coolant and prestone ?
- Inner Fender Well
- 2IS battery failure warning signs, before it fails (15mo battery)
- Buying my first Lexus IS 250
- Hood struct/shock leaking
- 2008 IS 350 high idle, power windows, memory seat malfunctions
- New battery install review
- rear parking sensor sound signal activation
- Trunk back seat door
- My custom Vland Headlights build
- Visual Engine differences between IS250-IS350 (06-13)
- 07 IS250 Walnut Sand Blasting
- Locking center differential
- 2008 IS250 Non Nav Parking Brake Wire?
- Dead Board or just a great Car?
- Questions on upgrading premium stereo audio on a budget
- IS250 AWD 2012 changing miles to km
- 08 Lexus IS 250 awd rim and tire specs
- Looking for a diffuser
- Aftermarket 17" wheels on a 2IS
- Is250 sr what does the sr mean?
- 07 skid ecu in 2006 is250(an info i cant find out)
- Cosworth Panel Air Filter 68% OFF
- 2007 is250 p0016-19
- Lexus IS250 AWD 2006 Bank 2 sensor 2
- IS 250 Does the intake manifold cold start injector clean valves?
- P1072 p0175
- 2007 IS350 Code P0017, Crank/Cam Position Correlation
- WA JDM LED HID Fog lights for 2006 Lexus is350
- Leather Vinyl wrap sticky dashboard on 2IS?
- 2008 Lexus IS250 Awd rear axle vibration?
- Air conditioner amplifier replacement
- Heater blower not working as it did yesterday
- How to adhere something to dash without damaging it?
- rear fog lights diy?
- buying a 2006 is250 with 200k
- Looking at new to me IS 350c....service history and questions
- OEM remote starter for IS 2012 AWD
- 2006 IS250 RWD engine tries to turn over but won't start
- Any good window visors?
- Intake filter help
- swapping f sport springs out for oem
- How to disconnect subwoofer in IS250?
- Push Button Replacement/Issue
- build to get going
- Bad alternator or bad serpentine/drive belt?
- I have a 08 IS250, Can I replace the radio & cd changer with a OEM nav?
- Wheel Fitment Question
- Any AWD IS 250 is non snow/ice areas?
- 2019 IS-300 Navi/Radio Info/computer randomly reboots
- 2006 Lexus IS250 Transmission Shift Solenoids
- 2006 is350 RWD [what is best way to remove engine?]
- 2IS IS350 Aluminum Radiator
- Reverse camera black screen
- 2012 IS250 F-Sport Headlight bulbs LED ? (6k temp color)
- Bought a 07 IS250
- Lexus IS350 2nd Gen Transmission adventure
- 08 is250 radio & climate not working
- Code from obd c1241
- Check System—TPMS
- IS250 Year 2007 USING ADVICS CALIPER FOR IS350
- Need help! [what is smallest spacer that works for volk ce28’s?]
- Kazz Sports Grill
- Have some doubts, about getting used IS350
- 2IS trunk with Uppababy Vista stroller?
- my window is off track, any ideas?
- AC Compressor locked
- 2008 IS 250 Trying to Program 2nd Smart Key
- Tranny replacement or Selenoid replacement
- 2IS MOSTPLUS Tailights = Vland for $230 with Amazon Prime
- I'm at a crossroads with my 2IS350 :/
- cleaning dashboard 2006 IS 350
- 2011 is250 center console
- Brand new battery is dead.
- Navigation screen making funny lines, and goes black sometimes
- Upsized wheels - next step?
- Black Trim Piece in the bottom of the Glove Box coming off
- VLAND Headlights fuze
- Help: How to Reset CHECK VSC LIGHT ON A 2006 IS250
- Do I need new tires? What is the best tire choice for 2007 lexus is250?
- 2012 Swapping 18" to 17" help
- 18" Wheel Offset
- All-season Tire recommendations for IS350.
- Back Bolt on Intake Manifold
- I need help on servos
- 2011 IS350c map dvd replacement
- Help please!!! 02 sensor pigtail
- A-Pillar Airbag Clip (Part #)
- IS250 on standing mile
- oil leak from oil pan
- Painted ebay bumper? Anyone tried them?
- High pitch noise engine bay
- Strange Headlight Issue
- 06 IS250 Wont Crank
- Heater blowing cold
- Car is blowing cold air when idle but operates normally when accelerating.
- Need help Transmission filter and gasket
- Just put on Michelin Pilot AS 3's
- 2006 IS250 Dead Amp
- Disable TPMS? 07 IS250
- Looking for a 2nd or 3rd Gen IS350
- Keyfob not required for Homelink to work??
- What packages do I have?
- Do all 2IS have auto tilt wheel?
- Steering Rack
- Has my alternator failed?
- A/f sensor bank 1 sensor 1 and 2 help!
- Glossy Black OEM Wheels or Keep Them As Is
- Rattling noise inside cabin
- Thinking of selling
- Please Help! ABS, Brake Light, VSC, P/S lights on.
- 07 Lexus IS250 wont start. Help please.
- ETC switch not working - 2006 is 250
- 2006 is350 oil leak between engine and transmission
- 07 is350 rear diff
- passenger map/visor light not working
- Factory hid headlight problem
- 4 Gallon tank for air ride?
- 2008 IS 250 AWD turned 11 years and 101K miles
- Differential , Need help , grease ? or oil leak ? Don’t know
- High mileage 2nd gen '06+ IS350 worth it?
- Meatiest Tires on Stock Wheels
- 2011 IS250 AWD abnormal tire wear
- Temporarily lost power to interior?
- No Audio at Ignition only !
- Headlights for base model is250 2010
- Carbon buildup issue?
- Clunking noise from rear pass tire under acceleration
- Clutch kit Options & Flywheel Thoughts
- Slow Acceleration After losing control of Car
- Any 2009-2013 owners have sticky dash/door panels
- 2011 nav headunit work with an 06
- CEL not working
- 06 Is220d Radio losing signal.
- Lowering the IS350 and BC BR Coilovers
- Wheel fitment!
- Fuel Pump for Lexus IS250 2009 $1200 OEM legit?
- Transmission problems, any advice is appreciated
- Buying 07 IS250 76k Miles Good?
- IS 2nd Gen Alternator Bolt Torques
- 2006 IS 350 I'm looking at shows oil consumption...
- DIY repair info site, ALLDATADIY.COM $13, 12mo
- IS300 (06/2013) Roof Rack Recommendation
- A great way to greet the new year!!
- New battery new alternator- no power no start
- Matching Color to IS350 Nav Dashboard?
- Someone got into my car
- Teach me how to fish....
- 07 IS 350 Loud Brake Squeaking
- Weatherstrip for camera hole on trunk garnish
- Lexus is250 rattling sound
- Black F-Sport seats on fleabay if anyone is interested
- Replacing license tag assembly with reverse camera IS 250 07
- 07' IS350 p1072 p0175 running rich bank 1 and 2
- 2011 IS250 Common Problems
- Does Facelifts matter?
- CR2P wheel setup
- Third gear and reverse lost on same day, 06 IS350
- Navigation and buttons around it dont work? Black screen
- Check vsc light on - no check engine or traction light on either! PLEASE HELP!
- Battery and alternator change car won’t start
- Cylinder 1 2008 is250
- Scosche ITCLS01B on 2011
- LED Fog Lights From Amazon
- 06 is250 ECU pin out/diagram
- How Late is too Late
- Temp gauge position during cold weather driving
- Please help IS250 startinfg problems
- Engine undercover (aka splashguard) picture request
- Torque specs, Intake manifold?
- 2008 Lexus ISF - No Sound From Radio
- Does your IS350 sound louder on cold acceleration?
- Steering Rack Bushings?
- New IS350C owner
- Replacement side mirror glass - missing part?
- jerky up shift at low speed (10~15), is it time to change transmission fluid?
- Recommendations for budget bucket seats?
- Front Bumper Question
- Best Way to Replace a OEM Subwoofer for a 2007 IS250
