- 2012 Lexus IS250 rear bumper help!
- Oil Consumption / Occasional Rough Start
- Lexus IS250 Tungsten Pearl front end help
- Is this aimgain?
- Front lip install help!!!
- Help repair scatches to my IS350 leather seat?
- finding a rear spoiler
- No electrical power, weird. Please help!
- Clarification on TSIB for Cold Start Rattle
- 06 Lexus IS250 Help! [Looking for plastic cover over oil filter housing]
- What wheels for a black onyx IS350?
- headlight does not turn on lights On lexus is 250 2008
- 60K Mile service cost $$
- Car died, won't start, fuel pump?
- 2009 lexus isx50
- Installing 2014 ISx50 F-Sport seats in a 2007
- Car didn't start this morning, but battery is okay...
- Will Stock Tires Rub On Lowered Car?
- Headlight Adjustment Broken
- Help! Car won't start, power steering dead, electrical system flickers on and off
- Painted Lobster Claw Wheels
- tapping footwell lights..
- Couple noises/things going on
- DRL/ hi beam fuse
- Anyone have a DIY on how to wire the LED headlights?(searched prior)
- Stock Ride height with Morgan Racing coilovers?
- Do Lowering Springs Require Suspension Mods?
- Can you get your defective headlights back?
- Good Seat Cover
- 2006 is350 won't start
- New to the forum
- Plasti-dip or wrap the front lip and prep needed?
- Replacing 2006 Headlights
- 2007 IS250 Carbon Build-up Warranty Extension
- 150k miles valve cover gasket changed
- Remove Plastic Shield under Wipers
- Sewell prewired LED headlights
- HELP! broken sensor. What is it? and part number?
- F sport wheels on AWD & fuses
- After Battery died nothing but tranny issues
- installing bar light? whatttt!!!!
- IS 220D / Check VSC / Motor Light / DSC Light
- How to get rid of engine whine
- IS350 Brakes on IS250
- Caliper Decals
- Burning Oil??
- Potential ECU swap out for more gains?
- Is this normal for sport dead Pedal?
- Exhaust leak on 2008 IS250 AWD
- Aux to USB converter question
- IS350 chirpping sounds
- overheating
- Should I buy
- No GPS signal after ML DVD and VAIS Bluetooth Install
- How To Change Out DRL Bulb??
- Bluetooth Not Connecting On '06 IS350
- question about wheel fitment
- Difficulty removing fog lights
- Stock but error code?
- Timing chain cover gasket leak and tranny service
- Transmission Problem 07 is250
- HVAC Diagnosis
- Youtube Build Video(s)
- Aftermarket Windshield Fit Issues?
- Need Advice on Headlight Washer Cover
- Transmission flush at 166k on an IS350
- Check VSC IS250 2007
- Help!!!! ["check system"]
- Window trim/ tape fix
- Pimp my Lexus!
- Is250
- Help ZLA didn't work
- Reman axle shaft
- Wheel spacer for IS350
- What do you guys think of this floor brace?
- 2012 LED Headlights Questions - High Beams, DRL
- 2010 front bumper replacement
- Removing Factory Amp (Non-ML)
- Shall I service or replace my car??!!
- Headlight auto mode fail
- Where i can order front door trim panel cover IS250 2007?
- Heated/Cooled Seats Malfunctioning??
- Illusion Red Powder Coated Rims + Molded Diffuser + Spoiler
- Help! Nav Touch Screen Going Out!
- Lexus IS220d side/wing mirror assembly
- Rear Bumper Hit While Parked
- Where can I order OEM windshield?
- anyone ordered parts from luxury mods?
- What's up with my windshield??
- Where to get FlyAudio for 2IS?
- 2007 IS250 New Projector Headlights
- Dyno Video of My Supercharged IS350
- Vais IVIC-5DR (Android Integration System)
- Question about spare on my AWD w/ 19's.
- First car - Lexus IS250 Silver
- New IS350 to me, weird question
- 2012 LED Headlight upgrade - 2010 IS350
- 2007 IS250 AWD Wheels and tires
- What Rims Do I Have?
- Is250 alternator plug help!!!!
- 2009 IS250 Nav Stereo
- Help! Is250 f-grill for 2012 + low beam bulb + spoiler
- Help please! Facing lifting my 2006
- Suddenly stopped running
- HELP 300h used car buyer
- seibon ts carbon fiber a replica of ings side skirts?
- AWD vs RWD steering rack
- Front End suggestions please
- Another gearbox issue but with a twist
- IS250 opinions
- Disconnecting passenger airbag, really need some help!
- Weird screech issue with 07 2IS - HELP!!
- Cracked Windsheild
- Help me with some wheel questions please
- Servo motor 2012 is250
- Aux Problem
- Check VSC/ AWD, ABS , TC lights on
- need help 4 constant 12vdc on acc
- Changed battery - now radio/AC won't work
- Failed smog with Fsport intake
- Wits end pesky VSC, CEL, trac light .
- Turning on AC at idle causes RPMs to jump around eventually stalling the car
- Transmission shifting hard 5 to 6
- Rear height sensor bracket broken and seized/frozen
- Wed wheel hubcentric ring question crossposted
- Whaaat, 3IS conversion on an SC400?
- Are cats and manifold one piece on 06 IS350?
- What color is this?
- 2006 IS250 Audio Issues
- Audio off Nav Radio Problems
- High RPMS/ TRANSMISSION
- Aftermarket Amplifier
- Where Can I Get Catalytic Converters CA Legal??
- After Market Navigation
- Ultra Sonic Blue Mica vs Ultra Sonic Blue Mica 2.0
- Driver's door leak
- Lexus IS 220D 2006 - Daytime running lights
- Help!! Wheel alignment- Rear toe adjustment control arm
- What oil is in my car?
- Replaced Battery. Touchscreen not working now
- 18x9 or 18x10 all around?
- Is this an ISP Mode wheel?
- ECM Part number
- TPMS on new wheels
- 60,000 Mile Service
- Trunk lid switch melting onto rear bumper... Part # confirmation needed
- FS threads go in the classifieds only
- 90k mile service for IS350
- IS220D Fuel pump question (non-starter)
- Need Torque Converter and CV Joins
- Lower Oil Pan replacement DIY help
- First Car, Should I buy this Salvaged 2010 IS350?
- Tire pressure PSI
- No more oxidized headlights!
- What should I do?.. Opinions please!
- IS350 Serpentine Belt
- Slight rubbing when turning
- Big gas mile per gallon.
- Is IS300 wheel going to fit over IS350 front brake?
- Would you get a 2IS again or go for 3IS?
- are yellow HID fog lights legal in california?
- Fan Replacements
- Door not unlocking but locks.
- Instrument cluster noise on start up?
- 3IS Conversion Question: Styrofoam Bumper Support
- Rear tire wear on inside, is there a fix for major negative camber?
- Air Bag light issue with 06-10 IS250 !
- Check awd
- Seat heater
- What size tires are you running on 19's lowered on H&R
- AUX Port Troubleshooting
- My beauty on Power magazine
- Need help on what tire size to get for 2008 IS250 AWD?
- Intake system messing with sensors...
- Anyone having noise issues after dash replacement?
- Engine Rattle
- How to get to Bank 2 Sensor 2?
- Any updates on IS airbag recall???
- Vibrating Steering
- Front Windscreen wire stick on Japanese import Lexus IS350
- Wed wheel tpms issues?
- Code P2004 popping up on IS250 2009
- Transmission going bad on IS250?
- Sparkplugs
- Joe Z where you at man?
- Polyurethane vs ABS Plastic
- Help! 06 is 350 headlight
- How many have had failed alternators?
- Ease of changing plugs in an IS350 and what plugs?
- LED bulbs for headlights
- Seeking advice for first time Lexus buyer
- Bagged AWD is250 Wheel fitment Questions.
- Help me get the right diffuser
- Audio not working after heavy rain storm
- Won't Go Into Gear
- Rear differental leak
- tire recommendations
- Part Number for passenger front low beam bulb
- Bad alternator-Need help identifying ground
- 2011 IS250 AWD key fob won't open trunk or passenger doors
- Cabin filter air flow?
- PS Anthracite Gray
- First Lexus - IS 220D 2006 - Couple Questions
- Resonator delete is350
- '07 IS250 Driver's Headlight Problem
- Adding A2DP Bluetooth to IS 350 with GTA Car Kit
- Help [me choose performance mods]
- Picking up IS250 Tomorrow - Newbie Questions (Already read FAQ)
- Nav update slowness
- ETC Power on/off for IS250 AWD !
- DRL on 2006 IS250
- Midpipe swap
- Trouble with OBD Evap Test
- Injector Tick
- cooling seats don't seem to function
- Help. My '08 IS350 doesnt start
- Major Transmission Leak HELP!!!
- Metal shavings inside CAI--damage engine??
- Anyone buy Ebay side skirt extensions?
- Upgraded Navigation Unit from 2006 non-ML to 2011 Nav Unit
- Formula to convert lighter wheels to HP??
- Problem installing grille on 2011 IS250
- Navi screen digitizer seller recommendation
- Rim and tire size question
- Push To Start Not Working At All
- Moon Roof Help and Guidance
- having trouble fitting in polyurethane ings sideskirts
- DIY instruciton for front end disassembly?
- 08 IS350 Headlight Question
- Whiteline sway bars for IS350?
- Headlamp upgrade
- Replacing Stock Rims
- Fog Light Not Staying On
- Coolant Boiling!
- IS250 Failing to start sometimes
- Clear Door Lenses for 2007 IS250
- What happened to all the aftermarket navigation units?
- Aftermarket Headlight Bulb Thread
- HELP! 2009 IS250 front exhaust pipe rusted through
- 2009 IS250 Rear parking camera while driving
- Rear Window Spoiler!
- 06 IS 350 - Rear Wheel Hub Removal Question
- New V VISION body kit.
- do i have to take off that small factory front lip to install front rep vertex lip?
- Squeaky seats & Rattling interior
- Coin dropped and lodged inside the center console area
- Frame damage?
- Which Wald Replica Spoiler for Molding?
- FXAuto
- DIY Stuff- Orange Trim- interior
