- steering rack and inner tie rods
- Vaistech kit
- IS350 Front Driver Sits Lower Than Passenger Side?
- 2014 IS250 Engine Replacement
- 3is fog light scoop/cover
- Transmission clunk && steering wheel squeal
- Buying used tires?
- question on rear sun shade
- Wheel bearing going bad?
- Road Magnet Springs
- In search of an IS 250 AWD to buy
- F-Sport
- 2010 IS250 - Weird Engine Sound After Cold Start
- Plastic window thingy
- Carbon build up IS250?
- Cheap wheels and tires combo?
- (CDN) Mileage Very Poor.
- Replaced Alternator now car won't start. Help!
- 5th Lexus, first IS...
- intro
- Tire Size Question
- Best yet cost effective option to have iPod connection with factory stereo
- Rear doors Speaker no bass?
- Does anyone know the color of the IS F-Sport grille insert?
- Torque vs. hp "feel"
- will isf/f sport gear knob fit on is250 (2007) AT
- Rusted through mid-pipe, Exhaust
- Bodykit Question
- Dumped Justin Beiber
- Post your car before the IS! =)
- Car after IS350?
- Muffler tip fell off :(
- Audio issue
- Seafoam IS350
- Basic tire question and suspension
- Converting an '09 Front Bumper onto an '06 IS350?
- Buying my first Lexus/Introduction thread!
- Power mirrors
- lip kit options
- Wheel/tire fitment
- Buying 2009 IS250
- Replace Front + Rear Seats
- Car wont start
- Cutting Cats off of '06 IS250
- Moronic Question [How do you pause the CD player?]
- Did/Does color matter
- Is a/c fan problem
- What kind of gas and from where?
- CEL, TRAC control off and CHECK VSC
- '07 IS350 CEL code P0137(O2 Sensor Circuit Low Voltage)(Bank 1 Sensor 2) Quesions!
- Cold air intake with heat shield.
- headlight for is250
- is250 MT lagging
- Preventing Rust on Brake Rotors?
- VSC Light After Passenger Lowbeam Replacement
- NAV screen protector installation?
- Grill options for IS350 '09-'10
- Is350 exhaust leak??
- Help with VSC on after LMS supercharger install
- HELP VSC is turned off
- Replacing factory halogens with oem LED's
- fog light help....
- 350 fsport
- Car suddenly wont start
- That guy who's new but now has an issue (headlight flickers) 1st post
- Can somebody help point me in the right direction with this noise? I have video
- Cosmetic maintenance questions
- 2008 IS250 Exhaust Pipe Leak
- OEM filter for IS250
- Total Loss
- please help!!! 2008 is250 brake light out
- Invidia Axel Back (Video Install)
- Interior Gas Smell Only at Rest
- IS350 Drag Time/Dyno Time/Performance Thread
- 2013 IS250. Possible To Change Front/Rear Pads Without Removing Calipers?
- What would you do? Purchasing IS 350
- PPE owners
- 4000K-5000K LED bulb color/temp?
- 11-13 chin lip question
- PTS Joe Z Full Catback Exhaust System Installed
- Headlight bulb stuck to harness
- Need Advice on IPHONE/IPOD Integration for NAV
- Converting is220d to petrol tank differences
- engine won't start
- Need some advice for my '06 IS250....
- JoeZ intake???
- Aftermarket HU Question: TYTO-01 for 2011 Lexus IS250?
- High milage is350s
- oil change questions.
- Linking seats to memory
- Lexus IS 350 side skirts
- Caster bushings in lower control arms cracked?
- Loud ticking from engine?
- Anyone with raw Rep Wald Spoiler?
- 2008 IS 250 Touch Screen not working, help!
- Selling your car on Craigslist. Post VIN?
- do we need camber kit for new shoes
- Need Advice on Headlight Issue
- Car alarm/Brake issue, In dire need of help.
- PPI out of state
- Is250 rear wheel bearing and hub problem
- A/C not cooling
- Will this fit?! ISF Interior Swap help!
- Where to buy 2011-2013 OEM headlights?
- Bluetooth issues
- Trading '08 250 for '12 350
- What's the next move
- Temp guage off set
- How to turn off CHECK AWD message?
- Aftermarket Wheels 18' Help
- Help with the heat is250
- What is this noise??
- Pot holes caused 2 flats, need new spare
- 350z HR??
- IS350 Rotors
- F-Sport intake help
- SARD Body Kit
- 2008 IS250 AWD Y-pipe leak
- Varrstoen ES2 - 18 or 19?
- Help! Window Trim
- Problem with 2012 Sewell Lexus LED headlight
- Help with new CV joint
- IS250 AWD wheels, income tax ballin'
- Troubleshooting Help! 2007 IS350
- is there a way to put side blinkers on my is 250?
- What PCV valve?
- Power windows switch not working
- Navigation Rear View Mirror!!
- Just bought a '12 IS250 - HELP!
- How much would you pay ?
- '07 IS350 w/ 19" RC350 F-Sport Wheels
- found this today, Tanabe cat back, someone should get it while you can
- The big noise from RL parking brake!
- WTB and For sale posts go in the classfieds forums, not here
- Is my early manufacture-dated '06 IS350 a sealed trans even with these drain bolts?
- Ebay 2013 OEM Navigation: why is it different than all others?
- 4GR-FSE Injector Size??
- IS350 transmission pan leaking
- Driver's side vanity mirror light and outside rearview mirror light not working
- Lip kits
- Starting concern
- Headlight replacement please help!!
- Wheels Help needed 9.5j all round
- Engine Cover clips and bolts.
- Bad experience with Nigel-JDM
- Had an AWD is250 now want RWD have some ?'s
- Bad gas milage
- Different top speeds on the same 2G IS model..THE HECK!?
- Satellite XM Radio Unit Compatibility
- The Black Nav of Death
- Stupid question re carbon build up
- 2011 Lexus IS250 windshield washer pump
- Custom interior door upholstery
- Transfer case problem
- New tailights from S Korea
- Navi & TPMS Questions
- See picture: is that 18" or 19" wheels ??
- roof drip molding install
- Power steering failing when cold
- Trade In Quote
- Trunk Spoiler
- carb legal catalytic converters for 2006 IS350
- Cooling Fan Help
- 2006 Lexus is250 steering rack recall??
- IS350 Navigation Help
- Should I get a different drop in filter?
- dash squeak with video, please help...
- WTB And FS go in classified forums only please
- IS250 MT Flywheel options
- help with side mirrors and fogs
- Need help with bumper lip
- Aftermarket HID Headlights vs OEM
- IS250 awd w/ hr springs + 19s
- Help! '06 IS250 AWD transmission problem
- brake Questions
- how to buy from lexon
- Bearing issue
- help [Will my car pass a smog check with only a Joe z intake? ?]
- Anyone drive with ECT PWR in S Mode, set to 6?
- Window Switches
- Aftermarket Fog Lights from VIPmotoZ
- low beam lights
- What is this?
- Idling Issue?
- Lexus IS 350 Seat Repair
- Front LCA Bushing
- Pic request: subwoofer and air suspension trunk set up
- Is350 awd Front camber plates?
- 19x8.5 235/35/19
- VSC light after hitting curb
- Aftermarket HID Headlights and HIDs
- IS350 Acceleration smell
- F-Sport Short Shift Kit for 250 6MT
- Happy Lunar New Year
- 2009-10 F-Sport Grille with RX Emblem (w/Pics)
- IS350 Transmission Fluid Leaking...
- Headlight hid is not working
- Audio system doesn't have any sound
- What kind of Maintance do you recommend?
- Got my Flyaudio/ChinaGPS/Roadrover today, but...
- Just curious [why buy an isx50 instead of an IS-F?]
- 255/40R18 tire on 18x8.0" wheel?
- IS-C fender
- Female Seatbelt Receptor Jammed/Paint Repair
- BC Coilovers + F sport rear sway? IS350
- Back in a 2IS.....350 this time :)
- Motor Oil Question
- MyRide Rear Diffuser
- keyless entry wont lock or unlock by touch
- Navigation Screen Fix
- will RC350 F Sport 19" wheels fit on 2nd gen IS350?
- Need help finding the AFS fuse on 07 is250
- Front Bumper Fitment
- wald black bison replica front bumper for 07 is350
- Buying a 250 with 100,000+ miles
- '06 IS250 AWD P0500 error code
- Lady ran over a tree.
- Do I have to worry about TPMS with new Tires?
- Is350 injectors in the is250 engine
- Check vsc. Check system. Check engine. Traction off.
- Oil leak 06 is350
- NAV disc
- Power seat mods
- Michelin PSS vs A/S (Which is better)
- Help: it looks like the paint on all my OEM wheels has faded
- Need help with sourcing fog light replacement for 2011-2013 ISx50
- IS 350 Manual Trans
- IS250, removing the battery hold down.
- TPMS question
- Successfully added a USED key fob to my 07 IS250
- Headlamp wiring difference in 2009 vs 2012
- 06 IS250 VVT sensor (cmp)
- Which years have USB or AUX in for iPod/iPhone?
- Will these wheels fit on an 06 RWD is350?
- Headlight/Ballast Repair in LA? (updated 2016)
- Question regarding Axelback + midpipe
- Is the Joe Z intake still available?
- Getting an extended warranty
- Any ex-audi A4 owners here ?
- Stock OEM rear sway bar size for 2010 IS250 rwd
- Headlight change over **Help**
- F Sport intake questions
- All Weather Floor Mats
- is350 wont start crank and stop instantly HELP..
- need help my car won't start is350
- Check Engine light came on & (check vsc /traction off ) please help :(
- Does it matter where you put gas?
- Low Engine Oil Lite
- Water got into the fog light assembly and now the inside of the assembly is yellow
- Piston Ring Failure
