- low beam out - replacement?
- Rust on Brake Rotor?
- Help identifying a lemon IS
- Car won't start: fuel pump?
- IS 250 Cutting out / Not starting
- Can Only Align Toe?
- 2IS DIY How to Change AWD Front Axle (Passenger)
- Passenger side tweeter rattling
- 2010 IS350 Roof Spoiler install questions
- Foolish alarm question?
- 2011 cluser swaped to '08 - can't turn traction off now
- 60,000 mile maitenance
- Reccomended LED Headlights?
- New IS250 Member!
- Wanted: Door Lock button pad
- Can you identify this plug?
- Navigation DVD drive won't insert DVD
- long shot: GS Artisan trunk spoiler look-alike for IS?
- IS250 Dead navigation
- Newly Purchased CPO IS350 - Warranty Void
- What is this?
- lower control arm bracket/bushing
- h11 d4s headlight swap
- Foglights Independent from Headlights?
- IS250 2006 DTC code P2120 & P2121
- just got a 2013 is 250 cpo! anything to be aware of?
- High Mileage IS350 5w20 VS 5w30
- Frozen touch screen
- 90,000 miles service but new engine
- 2010 IS250 LED Headlights Questions
- High beam and horn not working
- road magnet springs awd is250
- isf 2008 wheels
- Horsepower/torque curve
- 2006 IS350 ML Nav Question
- Changing ATF in '09 350
- Headlights with Daytime Running LEDs
- 07 is350 no audio or sound from speakers
- No sound from front door speakers
- Line out converter
- Chrome wheel cracked! Swap/trade/buy?
- pulse, rattle noise under car
- Front Wheel Noise when turning
- 2011 is250 rough shifting?
- "Protect" mode lit up on sub's amp -- No Bass
- rear struts
- AWD to RWD
- Tire AWD is250 215/35/19 too small?
- Stock rear toe control arm adjustment?
- AutoDip vinyl paint
- Daytime Running Light Suggestions?
- Air Suspension help!
- New Lexus owner's first issue - Keyfob
- 2 different part number for d2 air struts?
- 78works taillight code error
- Lowered with Staggered Wheels and tires.
- Replacing/Programing new TPMS sensor into is250 2007
- Old leak, I hope...
- how bad is the rear wheel drive i350 in the snow? how bad is the rear wheel drive I
- F-sport exhuast price?
- IS350 pinging
- V12 is250 anyone know of this?
- is350 2006, is this a good deal?
- Oil leak after carbon buildup csp
- Weird problem with display controls
- Suspension/DRL Questions
- New Lexus Owner
- a question about the mesh grille?
- How much oil do you Add?
- OCI and Ticking Engine
- iPhone 6 Ain't Cooperating With My NAV System
- Need Help!!! [Trouble fitting aftermarket carbon fiber hood]
- 2006 Lexus IS 250 navigation
- Possible Oil Leak?
- Anyone know the thread size for 2008 IS250 tow hook ?
- help with diffuser.
- Is it a good car?
- Spark Plug Question
- Best website for viewing lexus parts diagram?
- 2011 IS350 F-Sport Engine Ticking Noise
- IS350 Nav issue
- Which Aftermarket Lip Kit Are You Using?
- 2013 Navigation into a 2012 is 250 possible?
- Question about Selling
- Alternator problems maybe?
- Is my car totaled?
- Picked Up '08 IS350 (Pics)
- Audio Quality: USB or Bluetooth?
- Headlight 2013
- Goodbye 2IS!! It's been a good 6 months
- Passenger low beam completely dead, please help
- What Oil Filter Are You Using?
- Passenger Window Switch
- LED Parking lights for 2007 is250 best suited for OEM HIDs
- Lexus cars
- LBJ done in 3 months?
- Considering a 2011 IS 350
- Help me identify this part 08 Is250 awd (Pic included)
- dashboard replacement
- 06 IS350 -- No bluetooth audio
- Installing led drl
- Turned on car this morning. Battery light on dash?
- Issue with Bluetooth --> FM --> Bluetooth
- Air suspension Aws is250
- IS250 for ES350.
- New IS owner with some questions about the car, and the forum
- iPod/iPhone hook up
- 2015 update on lowered AWD
- Video: My IS350 w/GS350 F-Sport Front Bumper Conversion
- Need some input [After changing my brakes and wheels studs, all dash lights came on]
- Carbon Build Up ???
- Navigation version
- Help/Advice Needed!! Uneven rotor wear!!
- Help!!!! [can the F emblem be inserted in the steering wheel]
- Wanted: Clear Courtesy Covers
- installing spoiler
- HKS exaust with Secondary Cats Removed
- Is350 19 wheels
- Just got a 2012 IS 350
- Computer MPG, How Is It Calculated?
- Vertini's on 350.
- Tire Time...
- How Cold is your AC?
- Door Panel and Console Removal
- is350 in winter?
- is250 resonator delete
- Cracked windshield
- Couldn't rev past 4500rpm
- Likes/Dislikes for those that have owned for 3+ years
- How-To Tuesday: Melting Dash? This Is the DIY for You
- DRL LED Conversion Help
- Newer Headlights and Tail Lamps
- Noise when I turn and slow down
- Price of used IS250 at dealership increased by $3,000. Confused?
- rx 300 wheels on an IS 250?
- Just got a free nice upgrade!
- Trunk Protection Liner Question
- P0340, p0345, p0365, p0390
- Stretching Hankook Evo2 tires?
- Pic request matador red mica 2is with white wheels
- IS 250 Problems??
- DRL issue
- 2007 is250 engine noise
- It's been real CL 2IS forum....
- 2008 IS350 - My car wouldn't start
- ISF Steering Computer Transplant Question
- A/c issue
- Modesto Area owners!!
- What is the value of my car? How much should Insurance pay me?
- speakers issue in the "is 250 2007"
- From Ecstatic to Pissed in 24
- Broke my rear window by mistake
- 2008 IS250 Shift Shaft Seal! Can't get out! HELP! Leaking! Mechanics PLEASE
- IS 250 buying help please!
- What color should i wrap my is350
- How to Tell the Difference Between Halogen Capsule vs. HID Headlamps for 06 IS350?
- Is350 two cutoff lines on stock HIDs
- Re-plasti dipped the IS250
- JUN-TW front strut bar?
- Opinion on buying springs
- stuck silicone
- LED lighting
- Help Installing Subwoofer and Amp
- Will the 09-10 halogen headlight fit in the 06-08 model?
- Is this IS250 worth the trip?
- 2006 is250 bluetooth with without airplay
- rotiform tmb
- Intro - 2012 Nebula Gray IS 250 (Teaser Shot)
- toms lip
- Has anybody install new ECT Sensor for IS250/IS350?
- How's she looking? (Is250 AWD)
- 2007 Lexus IS350 Engine Cover Mod
- Side swiped and need to paint
- Opinions/suggestions?
- Custom Headlights done
- Engine cover screws
- HELP with tinting IS350C
- My new Toy :)
- Questions concerning new wheels
- Does bad O2 sensor affected performance IS350.
- P0051 - Right Sensor?
- Doors unlocking themselves?
- IS-350 Check Engine, VSC light, traction, Engine shake at stop light.
- Surprise Surprise and I thought I was SOL
- Dead battery: windows wont roll down now
- System Upgrade??
- thinking of trading in my LEXUS IS 350 f sport 2012..
- Would Lowering Car Cause Drivetrain Issues?
- Clicking Noise from Suspension
- Elevation effect on cars
- What Oil Weight?
- Advise on buying Lexus IS350 PLEASE! Should I buy Lexus IS350?
- check engine light?
- Looking into buying 06 IS350.. need help
- Car won't start
- Front window tint not dark enough? UpShade?
- Love it...or leave it???
- 2010 IS-F Dash Cam install
- Is there anyone know what is this called and what is its part number please?
- Slight road rash on loaner
- Shifter trim plate peeling..
- Need help please!!!!! [Very little sound from rear speakers]
- Is this the PVC Vacuum Valve?
- One exhaust tip has more soot on it. Normal?
- Q50s vs 2is IS350?
- DRL with the Upgraded 2012 LEDs Headlights?
- Rev Engine
- Wanting To Ditch the Woodgrain Interior
- AC pulley going bad. Anyone else have this problem?
- Anyone ever gone here?
- Low Engine Oil Light
- Hard brake pedal after sitting overnight... help?
- JDM visors anyone need rear visor replacements?
- Just Joined the Club
- Pic request: vertex trunk spoiler?
- Correct PSI for 19's
- GS350 AWD....??? Thoughts?
- Painted front and rear bumper cover?
- Buying a new car
- I'm abusing my car. .
- 19x11 +25
- Front bumper hanging - 10mm bolt
- Front & Rear "L" emblem replacement
- LED Tail Lights
- lowered my car today; Auto-level headlight doesnt work now
- 2012 IS250 Halogen lights to LED question?
- Need Help! Tire Rubbing Question?
- Service Question - Dealer, Independent, or DIY?
- front passenger Jdm visor got ripped off and car scratched
- Are front and rear axle nuts the same size
- New Koni Yellow faulty?
- Anybody ever used axles from Detroit (Dearborn) Axle
- Axle nut torque spec???
- Real carbon fiber trims
- RIP Black/White Lexus 2009 IS250
- What product to clean engine covers?
- another thinking of buying is350
- How far can I drive on bad rear wheel bearings?!?
- IS 220D - AFS flashing
- 2006 IS250 - touchscreen failure
- Transmission Problems... Replace or Repair? Advice? HELP!
- Thinking of Buying IS350
- Well my engine bay!!!!
- 2is tire recommendations
- Replacement Gasket for Tanabe Medalion Driver's Side Muffler?
- Fuel Pressure Sensor replacement after recall
- MOTORTREND 2IS comparison TEST. Good read !
- Selling my IS for an S5
- Scraped a Curb, Ended Up Squishing My Tire?
- NTB Mixed Up My Wheels
