- Sudden acceleration
- Help about my 2001 RX300
- New Member
- New and Questions
- filtering atf is it ok ?
- Help with heater blower
- hello RX guys! here is my new car project... 99 rx300-330 awd
- US RX300 in Europe
- best app (android/iphone)for lexus rx300 elm327r
- How to remove rear power outlet
- is the emergency hazard light switch supposed to light up in the dark?
- Considering an RX
- Remote entry, courtesy dome light, door locks randomly "lock/unlock" while driving
- Master Radio Code
- does the bulb failure warning light monitor rear turn signal and reverse bulbs?
- Is a BG Power Steering fluid flush Reasonable?
- Headlight help for rx300 please
- 18" Rims on my Rx300 help
- Coolant Leak
- P/N for the front seat belt button?
- Having some problems. Any suggestions?
- 2000 RX300 Door Lock problem
- ECM Master Key/Valet Key Mixed Success
- RX300 Misfire CEL codes
- Can the electromagnetic side mirror just stop working?
- My RX is totaled
- Audio Button
- Oil Drain Plug gaskets
- 2002 rx 300?
- CEL: code p0171 after replacing Bank2Sensor1
- AC Not turning on or Trip info not displaying
- rough idling and lack of power
- PCV vacuum routing?
- i erased the label (beside engine) any help?
- i found a parts like filter but it is not ?
- rubber engine support
- someone's opinion please spark plug
- My latest high mileage RX adventure.
- strut noise
- Test Driving Today/ What to look for?
- oxygen sensor part, are they same? help
- Fellow-up "help no oil flow"
- Rx 300 2.4L
- Talking about bad luck!!!
- A Hamster in my RX AC vent?
- A LOT of work on her yesterday.
- New to THIS forum & buying a 2002 RX300 AWD this week
- starter overhaul - question
- Loud POP while driving...now small noise when turning
- 1999 RX300 Alternator Pulley Size help
- Oil flow problem help!!!!!
- Lexus RX300 left speakers problem
- KYB rear strut mount VS OEM
- Calibration of the climate-control system.
- Tire Dressing ?
- Scored some parts today for the RX300
- Remote Door Opening
- radio button and switch lights
- hearing a chime after major undercarriage repairs
- How To Search This RX300 First Gen Forum
- Should I get one?
- my bumper got smashed!
- I bought Super White 9005 12V 100w Xenon Gas HID High Beam 5000K Light Bulbs to 99rx
- Autobox jerking and bucking after fluid change
- 225/70/16 Hankook Dynapro ATm
- Both Rear Doors cannot close
- all electronics dead
- My driver rear door does not lock
- OBDII scanner problems
- Dreaded VSC & Check engine light
- Rear Wiper Length Mystery
- '01 RX300 vs '01 GS430 - Utility, Reliability, Value?
- 99 RX won't shift into park - can't start --Help
- HOW TO: 2 Minute Fix for FAULTY Brake Light Failure Sensor Module.
- Poor turning radius on my 99 RX300
- Factory Radio Power/Volume control broken
- Happy New Year 2014
- ABS and VSC light pulse on when braking
- Obdii actron cp9125 scan no code (0)
- Need a Re manufactured Driveshaft - RX300
- Air servo problem
- Tacoma Antenna Conversion Power delete
- RX300 year 2000 airbag light steady on
- how can I determine which door needs to have the door check replaced?
- part number for this clip ..(pics)
- body Kit
- AC Noise
- Wish you all Happy Holidays
- Day Time Running Lights inoperative
- Misfire DTCs 0300, 0302, 0306 all at once.
- still leaking after rear main seal and gasket replaced
- Bought a RX 300 for 2K
- Question for GROM users
- Missing Bolt on Cruise Control Cable Bracket?
- can I change the beep that the RX300 makes when I lock/unlock doors?
- Extended Wheel Studs
- Master key work around
- original shocks feel normal on 160000-mile RX300, should I bother changing them?
- Another reason why I do my own repairs
- Solenoid Problem???
- Dash Lighting Question... After Searching...
- Mirror Controls Inoperable
- Incontinent RX300
- Coolant leaking into Cylinder
- Recurring Swooshing noise from AC/heater?
- Need Advice On Radiator Sealer
- Need help turning on Navigation
- 2003 RX 300 CEL and VSC
- CEL 1133 - O2 sensor next to firewall?
- intermittent reduced power at highway speeds
- Roof rack questions
- what is the part# for the original gas cap on 2001 RX300? Is the tether included?
- 2003 RX300 replaced actuator, remote fob no longer works
- Just introducing myself (a new user)
- 2001 rx temperature control problem
- Wet windshield on inside and water by B pillar
- Can anyone identify this part?
- How to connect iPod to radio (w/Nav) for music
- Code po0171 and 1133 Bank 1 Sensor 1
- Toyota Techstream!
- Evaporator Leakage
- Hose question
- replace antenna 2003 RX 300
- Do the outside mirrors dim?
- 2001 RX300 Cylinder 2 issues
- need some help putting driver-side interior door lock handle trim back in properly
- Mickey and Minnie moved in
- Driver's door
- CEL - codes 0440, 0441, and 0446
- outside rearview over tire driver side
- lexus 300 rx first generation
- Replace front strut mounts?
- Big steering issue
- When I press brakes ABS start working - Lexus RX-300 2003
- Rear sways to left when accelerating
- Best RX 300 Year/Generation?
- new tech device to program keys....any advice....
- car will not go in park
- RX 300 wont start
- Mobil 1 ATF for RX300
- Intermittent Shaking/Vibration at High Speed
- VSC and CEL code P1349
- Radio cuts out when turning brights on.. AC Toast
- Can 1st gen nav be added?
- New owner / New to forum
- Rear Strut Difference? AWD vs FWD
- 2001 RX-300 Newest Nav DVD?
- winter storage question
- P1153 code 3 hours labor ripped off by mechanic?
- joon6
- front differential issues
- Emergency Brake - Hand Brake problem
- A few questions about p0446
- RX300 Driving Position Memory System
- 2000 lexus rx300 awd / loss compression / misfire
- parking brake
- Mouse nest
- Tanks to Cl, mainly to LEXMEX
- switch my U140F tranny valve body with a U140E valve body
- Time adjust of JDM version (Harrier)
- ECM or EVTS?
- AC Servo Damper Air Conditioning Issue! (2000 RX 300)
- Driving Position Memory System:
- 2001 RX 300 Water Damage
- Vibration
- Looking for a mechanic in TN
- remote start install ???
- Coolant venting from water pump housing
- Loud motor
- 190000 miles
- Passengers LOW BEAM not working.
- p0440 code on 1st gen RX300 - anyone?
- Gas Grade 87 89 or 92 in 2000 AWD?
- Quick Struts?
- Need help on fixing SERVO motor - stuck gear
- Door Lock Actuator parts help
- Engine Mounts - How much movement is normal?
- New member needs some guidance
- rx300 2000
- Please Help - Tranmission/Lean/No Start Issues
- Bank sensor cost
- help
- Power antenna replacement options?
- 2002rx antenna
- Rear strut install tips needed
- P0420 Code
- Problem
- Dog Barrier
- AC blower motor or servo?
- sway bar bushing replacement - how hard?
- P0171 Smoke testing
- winning sound from blower motor on a rx 300
- 2000 RX300 Error Codes
- Considering 2000 RX300
- RX300 Android Install
- RX300 Headlight Bulb replacement
- Intro and basic questions
- P0446 may be caused by hose on top of trank
- Trouble Reinstalling Front Struts
- 2000 RX300 CEL on P0171, P1150 and P1153
- De-slugging....is it worth the price?
- 2001 RX300 cold engine squealing/whistling noise
- P0770 Shift Solenoid E Malfunction
- VSC and CEL lights on...
- New ultra high mile RX owner
- Another new RX owner
- 1999 RX300 side step
- 2000 Lexus RX 300 Fan related noise after iginition is turned off
- 2000 RX 300 Front Brakes Pads and Rotors
- 1999 rx 300 ride
- P0446
- Seat cover replacement
- 99 RX front wheels spin on wet pavement
- new wheels for my RX
- P0171 and no power?
- Won't start - No power to Dash at all
- leak from exhaust manifold
- small metal shaving in my transmission fluid
- RX 2000 airbag 2002 steering wheel
- 2000 RX300 idle problem
- Rhythmic ping
- Gearbox Update!
- P1349--NJ, help!!!
- Stabilizer bar bushings - are there any?
- Servo?
- ABS Sensor Bolt Size?
- DIY or take it to mechanic for sparkplugs change
- Removal of the gear shift knob RX300 AWD
- squeezing noise when start up the car?
- How do I find bad tone ring w/out DCL1 port?
- Transmission won't shift to third until temp rise
- Robbers busted out my window!
- Interference or Non-Interference
- New way to remove driver side window switch
- Death of my RX300
- Another air mode thread
- No Heat: How Do I Replace Air Mix Servo ?
- RX300 Grom Audio connection
- Messy oil filter removal
- Power steering fluid change
- castrol transmax full synthetic multi vehicle atf
- Door Speakers and Dash Tweeters
- transmission fluid replacment any body use a mity-vac 7201
- key battery replacement
- DING DING sound w/ brakes on 98 RX300
- Piece dangling from my undercarriage
- Automatic door locks?
- Door Lock problem
- my RX300 won't start under certain condition
- Wonder where she went.....
