- Help Please
- Looking for oem floor mats...
- Kind of a pleasant experience at Sewell Dallas today...
- My front and rear wipers and working at the same time!!! lol
- new to lexus but have couple issues!
- Help!! im looking for a reflector
- factory amp 2002 rx300
- Finally found a cheap silver-sport grille
- New owner!
- Fuel gauge reads low with full tank
- Windshield Freezes Inside
- would these rx300 rims worth it!!!!!
- NOOBIE and Introduction with Codes and Q's
- should I replace the battery, and with what?
- Horrible ice in Dallas!
- speaker upgrade 2002 rx300
- P0446 and Acceleration Vibration / Jerking
- Looking for oem factory chrome
- LEXUS Indy mechanic in NJ
- Rear Wiper Issues
- 2000 Lexus Rx 300 Wont Start
- Almost ran out of gas, now idles rough. Please Help!!!
- Center console Screen problem.
- HELP! Cannot open door after making lock-actuator-fix error.
- Car ipod adapter for a 2000 rx-300?
- Digital Readouts Reset to Metric?
- HELP PLEASE! Weird electric problem
- 99 RX 300 codes, p0171,p0141,p0330
- New projector headlights installed
- updated GPS disk wanted
- OEM replacement HID bulb
- Noise from the front left axle & Fan problem
- User manual
- Won't shift from 3rd to 4th gear
- Sounds like whinning noise coming from engine or transmission on acceleration
- RX300 power door locks
- Leather Reconditioning
- Idiots guide to Jacking up rx300 please!
- squealing noise when starting 2003 Lexus 300
- My RX300 maintenance costs (0 to 150K)
- AT oil Temp light
- Another bad coil?
- COLD weather transmission whine (AWD)
- my old car is up for sale
- RX300 cold start problem
- BMW owner trashing Lexus
- acceleration noise
- P1135 code checked and corrected by Lexus mechanic
- How often does your battery need to be replaced?
- 1999 Stereo - Power but no sound
- Few questions..
- Hid
- Fault codes P0300 0301 0303 0305 0171 0171P
- How's this deal sound?
- 2001 RX300 Revs before going into 1st gear
- Bent front end!
- Third Brake Light Problem -- SOLVED (hopefully)
- Any leaks after a tranny pan drop fluid replace?
- drivers side passenger door wiring diagram
- Has anyone replaced the third brake light assembly with an LED strip?
- Rx 300 fuel filter
- Driver's side sun visor keeps falling down.
- Hi, Just Joined
- Key will not turn on car
- Trailer/Tow Hitch
- 4 wd or 2?
- All four new Sensen AWD struts for $135!?
- Expensive transmission or cheap sensor issue?
- Front end shaking and RPM unstable
- Roof Racks
- Oil pressure switch sensor location
- Looking at buying a 2001 RX300 4x4, items to look out for?
- AC/Alternator Belt Replacement
- Stripped Engine Oil Drain Plug
- Switchblade key?
- Push to Start?
- 90k Service AND MORE????
- RX300: Which Aux-In solution have you installed?
- whining-noise-when turn on RX300 in cold weather
- Battery Tender Users Please Read...
- Clunk and Visor
- Mysterious Misfire - Exhausted my knowledge
- Passenger door lock 2003 RX300
- I need help with these codes
- Fuel pump fuse
- How Do I remove rear bumper
- 2001 rx300 heat doesnt work right
- Tranny drain plug/washer- Replace or Not?
- Aftermarket vs. OEM Transmission filter/seal kit?
- Help... Strange starting issues...
- 99 rx300 bad motor, UPDATE, read again
- What other factory wheels did you fit?
- Fog lights not working
- SL2VU in RX300?
- Cannot get into keyless program mode
- Beeps twice when locked
- 99 rx300 bad engine, what will work?
- My Own Stupid Fault, still got mad
- Clock Resetting
- Cleaned car, took pictures.
- 2000 Rx 300 Exhaust (Catalyst)??????
- Rear view mirror/compass for none rear view mirror/compass???
- Where is the "O/D Off" indicator light??
- Compass mirror
- Tires for RX300
- DIY Lighting?
- First RX!!
- 01 rx300 won't start sometimes?
- New wide armrests
- When Searching for Parts 1MZFE
- Need help - O2 sensor mount
- transimission problem or something else??
- Can't figure out how to remove door handle???
- reverse going out? replace trans oil on this 2002 rx300?
- RX300 - To Bid or Not to Bid?
- 17 bucks, I couldn't resist...
- DIY thread for drive/alternator belt replacement?
- More Evap Troubleshooting...
- KYB GR2 / H&R Springs any good?
- tried & true intake filter = better mpg ??
- new owner few questions please / 1999
- should I expect transmission problems in my RX?
- Since everyone has RX330 wheels...
- RX300 2000 Check Engine & VSC
- 20004 Filter on an RX300?
- Keyless entry
- bye bye RX hello SC
- convert to 265/60/18 ??
- Merry X'Mas...
- HELP! Code 1354 VVT system fault
- 01 rx300 radio inputs
- Engine RPM's at 70 MPH??
- How to check sensor and connector?
- Single beep at low speed (10 MPH) - what gives?
- Help Tracking Down the Evap Codes...0441 0447
- How to clean moisture inside head lights???
- Ride quality??
- Transmission slipping between 2nd and 3rd
- squeaking noise from right rear tire
- 02 Rx300 transmission not coasting....
- Coil Packs Failing, Need Help Please!
- Couple Newbie Questions
- A/V system wtih relocated A/C controls
- 90k mile service.
- Spark Plug Nightmare
- Need suggestions
- Llumar pp35 does not match rx300
- Hitch Carrier
- Dear Lexmex...
- Got my rx retrofited with projectors
- Replace RX300 Speakers - After Market Speakers for 1999
- I've created a tail light problem.....
- Sway bar bushings
- Rear Oil Drain Plug???
- Fuse part numbers
- New Grille From defo
- What tint would you suggest on this rx300
- RX300 Coach Edtion Grill
- Window lock switch not working
- I'm looking for some import glass!
- 1999 rx300 Display/Info Screen problem
- I have two questions about my 00 rx
- One tough Rear End
- out with the old, in with the new
- Upgrade to wood shifter
- Remote door Lock/Unlock does not work.
- Bank 1, Sensor 2 (O2) thread size?
- #2 Cyl does not fire.. HELP
- most common question of newbies
- ASAP HELP NEEDED... Tranny Stuck and I can not shut the ignition off!
- Now She wont start..
- Worst Problem replace PCV valve, Need help!
- 99 RX 300 issues
- anyone know where to get clips to hold inside cover of rx300 tailgate on?
- RX300 2001 - best minds please help
- Upgrade to wood steering wheel
- Would you pay $4,900 for a 1999 RX 300?
- Power window
- Replace a cartridge type fuse? Help please!
- How do I get rid of Discharge Warning Light?
- 0136 cel reading, where is bnk1,sensor 2
- Rear hatch lock wont open
- Driver side door lock not working
- Clear water like transmission fluid?
- Hi im new.... I needed some help on matching this tint up
- Can you figure this one out?
- Airbag Light Blinking
- catalytic converter problem
- 99 RX 300 Shifting Problems,also have a P0330 CEL code
- Post Pics of Upgraded Tails
- Looking For A RX.... Can It Tow ???
- Fog-head light bulbs replacement?
- Knock Sensor Issues 2001 RX 300 AWD
- Oil??
- How to check EVAP if my rx300 99 code P0441,p0446?
- CEL: Codes P0300, P0301, P0302, P0303, P0304, P0306
- Strange alignment after new struts
- Rear Main Seal Leak?
- Oxygen Sensor problem
- Fender Flares
- Another good story
- Scared the hell out of me
- *** please help???***power loss
- Muting audio system...
- Engine is having a hard time starting
- Purchased a car .....
- BRAKE warning light on
- Hidden exhaust leak
- Battery will not hold a charge
- Toyota Trans. Fluid vs. Castrol Import Multi-Vehicle
- Keyless entry '99 RX 300
- 2000 RX300 acceleration problems
- Warning Buzzer
- Any fabulous rx300 or fabulous harrier owners.
- A little maintenance brakes/ wipers
- Check Engine Code Help....
- Please help!! Car won't start, ECU problem?
- No CEL, Low Battery, transmission light in the cluster?
- Show off your after market wheels gallery.
- Car cranks even after taking key out of ignition
- Key Won't Turn-Seems Related to Broken Door Lock
- Solution for exterior fading pillars?
- Right front fog off, left highbeam off
- steering wheel crooked
- ABS not working since transmission replaced
- Where to put head unit in RX300 (keeping stock center console)
- Won't start at first, yet runs fine
- GENERAL Grabber HTS (tire) still the best?
- Rear Rim Offset
- Antenna/Motor problem
- Door lock actuator motor replaceable???
- Strut bellows repair?
- Another rear main seal?
- Finally! new part from Japan
- RX 300 Roof Rack Sliding Rail Bracket
- I want to put two 12" subs in my RX300
- Some Pics of my 99 RX AWD.
- Maximum number of ignition keys for ECU
- Accessory belts
- 2001 PCV size
- odd right rear brake "grab"...
- RX 300 hesitation at start
- turning radius
- RX300 vs 300RX? Ha ha
- Brake pad part number same as highlander?
- Adjust headlights in 03 rx300
- Rear vents
- 1999 RX 300 1,3,5 misfire and other problems
- Time to restore the wifes rx
- License plate bulb - lense removal
