- help ... sell it or keep it?????
- How to remove trims with windows??
- Looking to buy first gen but had a few questions
- Just Got My First Car!!!
- A/C solar sensor circuit code 21
- engine knocking.
- Code P1155 - I need help please
- Metal Strainer
- RX300 2003: Replace Driver's Side Window Seal
- tinting windows on that goldish factory rx glass?
- P0765 Shift Solenoid "D" Malfunction
- Video of RX300 engine with Compressor/Supercharger
- Air Fuel Sensor
- Connect Iphone to Audio
- RX300 Engine Swap
- Strange clicking noise coming from somewhere below gear shifter?????????
- a/c vent problem
- Clock pinned at 1:00 AM
- replacing amplifier
- Yes you make a short blade key from a long blade blank
- in-line amplifier
- new amp in 99 rx300
- et
- Engine Air Filter and Oil Filter
- Squeaky steering wheel
- Making a long blade key into a short blade key
- Test drove a 2004 last evening
- Buying another RX, how to tell if it's got Nakamichi?
- 20's on an 02 rx300?
- where to find cupholder button?
- Replacement for Shocks...KYB?
- what model year did Toyota go from belt to chain?
- My speedometer is pinned at 6:00. What gives?
- Engine start button
- Newbie Transmission question
- CEL 0402 Catalytic
- Can the faceplate be removed?
- Struggle between 30 and 50 mph
- Cel p1135 & p1130
- Mileage VS. Age??
- Dual exhaust installed today
- '03 RX300 brake rotor question
- Please Help me Fish my power wire from the hood
- Need help on brakes
- Pics of my 2002 Lexus RX300
- Black box under the chasis rear driver side !
- fwd offroading?
- Replaced radio faceplate -- radio doesn't work anymore!
- Replace Leather Shift Knob RX300
- does anyone think im retarded for this?
- Radiator Replacement
- 1oz of Sea Foam
- Strange problem
- Considering a 2001 Rx...how much is too much?
- Air conditioning
- low speed shimmy
- What is "best" year of rx 300? awd or 2wd?
- VSC Trac Off Check Engine light on?
- Lost a/c after driving thru water??
- 2003 RX 300 timing belt question
- avg MPG 14.0 city, anyone thought about adding a bigger gas tank?
- Brake pad wear question
- 2000 RX300 rattling noise
- Electric Conversion Kit
- 2002 trade in value
- Refrigerant Leak
- brakes make a clicking noise
- Help! Transmission Failure symptoms
- New to lexus: Headlight housing?
- Sending out an ECM 89661-48082 for repair
- Searching for SoCal Mechanic
- New tires
- 2002 RX300 130K Maintenance
- Owner's Manual
- Two questions here
- A/C refill and service
- Oil Usage Issue
- check engine light codes
- Timing belt pulley.............
- Okay,here is one for you guy`s
- Secret weapon r intake gain hp ?
- TTE AND EIBACH LOWERING SPRING (Eibach Pro-Kit 8269-540)
- Flashing CEL P0303
- Transmission - drain and fill or strainer replacement first?
- Can you paint stainless steel?
- getting a 99 rx300 with 183k
- Hesitation on Acceleration
- Anyone try Castrol Edge Yet??
- Front Brake pads - remaining 8.5mm
- How to Disable ABS on 2000 RX300
- ever bend your power antenna driving too fast?
- car will start but shut off right away...HELP
- 99 rx300 led taillights
- the A/C compressor on my 2001
- seat belt retraction tension gone
- youtube video on brakes
- Thanks to the forum!
- ABS Issue
- Kyb ultra sr & gr-2 struts
- Axle Shaft ebay
- Back up Camera
- 99 RX300 Rough Idle
- Hello from Austria
- 2000 Lexus RX300 hits 100,000 miles
- brake parts Backing Plate; calipers
- 99 RX300 Fan Runs High Speed Only
- rx 300 evaporator
- What all parts do I need for 90k service?
- Help: Loud idle while stopped in "D"
- CD Changer install help needed
- foggy looking headlights
- The 3rd brake lamp
- Anyone know where to add refigerant for AC?
- Remote door actuators don't work! Am burnt out!
- ecm reflashing
- 2000 rx 300 antenna
- Getting New Struts, What Else Should I Replace
- '99 RX300 Rear Window Washer Problem
- Strange Coincidence
- Newbie to your forum with antenna question
- Luxurymods.com
- 90,000 mile service - overdue
- seat heater switch
- Check Engine Light
- Check engine Light Code P0125
- Midas
- 2001 RX300 Climate Control
- Conventional oil w/RX treatment right now.
- Buying a 99 RX300
- Replacing Timing Belt- What else should be done?
- What happened to member cduluk's wood conversion posts?
- Coil Problems
- Toyota Harrier 1998 - 1999 (seat heater)
- Help: Front door courtesy light cover
- Marvel Mystery oil
- Looking for some advice
- Weird sound and very sluggish
- How to remove rear rotors
- Trader Score: (0)
- DIy 1999 RX300 rear rotors
- Air Filter Box
- Happy easter!!!!!
- headers installed
- Did someone snap off the bolt heads Brakes
- Wood + Leather Steering Wheel Refinishing *PICS* :)
- Cup-holder Cover Wood Conversion *PICS* :)
- Best place to get parts
- RX300 valet key -car won't start
- Spark Plugs - Opinion?
- Whining/Purring/Whistling heard btw 60-80KMH (40-50MPH)
- Navigation "Program Disk is Inserted" message
- Grinding metal noise
- RX 300 ABS Help please.
- Brake issues and other thoughts
- a little help please???
- Accessory plug in the hatch removal
- White smoke
- new mod !!!
- RX 2WD vs. AWD
- Fan stop working? Any help? Thanks
- Problem with both Master Keys and door locks in 2001 RX300
- Question about CEL and Coil Packs, :)
- Upgrading to 18"
- Information display blank
- Exhaust sensor kaput
- unique tint color
- 99 RX300 or 02 RX300 to avoid tranny probs??
- My 2000 RX300
- Where is A/F sensor bank 1 senor 1?
- 300 still the best RX model!
- CD changer
- RX series in movies and on tv
- Coil Packs Repeatedly Going Out...:(
- Worried about my RX300
- 02-4WD Front rotor splined ?
- Please help me identify the AT cooler hose
- Outside Temp Sensor Bad
- ABS Sensor problem?? - 99 RX300 AWD
- Dealer detected 3 issues...
- RX Navigation retrofit
- My new 1999 RX300
- How do I test the O2 and A/F sensors?
- squeak in steering wheel
- The Ole Oil Pressure Problem
- Check Engine Light :(
- Transmission UOA Amsoil Universal ATF
- Bad Solenoid on RX300
- Windshield pump replacement
- Ivory with Brown-Gray interior; scratch coverup
- I have a stupid question that I cannot figure out.
- Water leaking from rear under car area
- Front Side Marker Bulb/Socket Replacement
- Lock or Security System Problem
- Used Struts?
- Loud rx300
- Low Hum. Help!
- Need to replace exhaust manifolds
- navigation location
- 10-Year Airbag Maintenance
- Air/Fuel sensor codes P1135 now I get P1155
- fuel filter replacement
- How long is the life for Front and Rear Struts
- Your experience with tires for rx300
- Strange Noise/Rattle
- TEST RESULTS FOR Pulstar Pulse Plugs
- Asking for feedback Lexus RX
- Weird Light? Help Please!
- How Auto-RX works for Engine, Tranny & Transfercase ?
- new wheels.
- Bank 1 Sensor 1 removal
- hazy front light covers...
- '01 AWD - Brake shutter/pulsating
- 99 rx ignition lock cylinder and new keys
- Clear Side Markers...Anyone Seen Them?
- 99 rx300 color ?
- 2001 RX 300 Code p0770 for sale
- question about grease for wheel bearings...
- Leather Seat/Steering Wheel
- Replacing Front Rotors DIY
- Help! Drivers side door won't open!
- Some service questions
- Speaker size?
- Possible '01 RX purchase... opinions?
- 2001 RX Coolant Leak
- Need Transmission help! WTB RX300 shift solenoids
- Has anyone with Nav upgraded stock xenon with 6000K?
- Cel code p0500 for vss/ should i change the sensor ?
- what is the ride quality like on a RX300 with 20-inch wheels and 245/45/20 tires?
- 02 RX300 AWD 44,000 miles shift points
- trans prob or not??
- Anyone have pics of a lowered RX?
- 2001 RX-300 AWD transmission troubles
- 2000 RX300 cd player doesn't play as loud as it use to
- Draining and Filling 99 RX300 2WD Hints/Tips
- Someone hit my rx300 with a carriage!! GRRR :O
- Help should i buy a 99 rx300?
- How bad are the 99-01 problems REALLY?
- Alternator gone bad "battery light"
- pushing in the brake caliper
- RX300 Horn Upgrade DIY?
- has anybody here changed out their front bearings?
- Need Help. Bad experience from Lexus of wilmington delaware
- changing out my rotors this weekend, any suggestions?
- I have a brand new OEM uncut keyblade- anyone interested?
- rear spoiler install
- car keys...HELP!!
- What do I really need to do?
- temperature display
- Is there a DIY for the rear center mount brake light?
- New Dashboard Alert
