- 1999 rx300--AC light
- Anyone Towing with high mileage RX??
- Transmission Drain Plug Tightening Torque Spec and Gasket questions
- VSC & TRAC OFF lights on, but no CEL?
- How to replace front brake caliper???
- Front right axle
- Is my RX "Trade-in-able" despite its age?
- Speaker Replacement Recommendations
- Is this the oil used in the oil change thread?
- Engine Immobilizer
- Parts diagram and/or numbers for Catalytic converters
- Check Engine Light and VSC light on
- Installing a new Radio
- Battery Drain
- aftermarket radio
- A quick rear wiper arm / motor question!
- odbc ii scanner
- '99 RX300 won't start, single click and then the electrical system dies
- Radio-theft deterrent design concerns
- Keyless entry compatibility
- '01 RX300 A/C Compressor - HELP
- Successful engine pull from top
- Hi I’m New
- How to Fix Rust Around Your Wheel Wells:
- Front Plastic Splash guard Pan Delete - ?
- How do I tell if it's my transmission or transfer case
- Transmission or front axles?
- drivers door window and central locking not working
- 2000 lexus rx300
- Rear end swaying left & right
- DTC's thrown...
- Flickering Lights and Transmission Stuttering: Related?
- Alarm goes off for no reason
- Flashing CEL, engine slightly rough
- Possible issues after timing belt
- Terrible vibration issue
- Loud Popping Noise and White Smoke from Underneath the Hood
- Semi clogged catalytic converter
- transmission grounds rx
- How do I disconnect the antenna power
- Clicking Noise by Middle Counsel of Car
- fabuloususa.com now a redirected site.
- 2001 rx 300 won't shift into overdrive
- P0125, P1155 and possible P0171
- timing belt
- No LED light when lock & unnlock buttons are pushed
- No LED light when lock & unnlock button is pushed
- Thermostat
- 00 RX300 AWD starts and then cuts off
- Going to drain tranny fluid. Just want to be 100% sure
- 99 RX300 mechanical issues
- Should I. 2003 rx300 with 126,000 miles???
- Anti theft was set after battery change tried all basic tricks
- Rx300 p1663
- Whining at 30-40mph
- 2002 Rx 300 headlight sensor and battery indicator stay on
- Lexus RX300 (2002) transmission issue
- VVT Solenoid is Stuck
- IACV question
- New Speakers are distorting
- Confusion on Bank 2 Sensor 1: is it "Mass Air Flow" or "Air/Fuel Ratio" sensor?
- Knock Sensors-Need Help
- Car heater issues - Need help
- Driving steep grades with large elevation gains
- How hard is it to change AIC valve?
- 2000 RX300 Code PO325 after replacing both knock sensors and harness
- What to know if my 2000/2001 lexus RX300 is a 4WD
- Transmission in limp mode. Knock sensor code.
- horsepower thread?
- Is there a DIY for changing front valve cover?
- Stutter on every shift with dim bottom light upon acceleration
- Wiring a Auto-Dimming Mirror
- What's the real difference between the Denso OEM filters?
- replacing lower control arm and ball joints - what else?
- Shift Solenoid Mechanical Function Testing
- 99 lexus Rx 300 not getting over 40 mph
- fuel gauge not working
- lexus RX300 not moving
- Oil leaking onto the TOP of the transmission housing
- rx300 high idle speed
- Lost wallet card and key fob for a 2001 Lexus RX-300. Can I bypass?
- Does this plug look okay?
- what is German Castrol
- Cost of replacement catalytic Converter for 1999 RX300?
- Removal of interior trim panel?
- Interchangeable transmissions
- AWD or FWD transmissions: Which is the weak one?
- Transmission failure at 175,000 miles and solution.
- back firing out the intake and rough idle???
- Windshield Washer Motor Replacement 2000 Lexus RX 300
- Transmission Failure
- Lexus rx300 gear jerking
- acceleration
- Aftermarket TPMS kit
- No Overdrive and code P0765
- Self adjusting headlights
- Vsc abs
- oil usage
- Seat swap
- Halogen bulb exploded inside headlight housing. How to remove back plate?
- Overheating
- 1999 RX issues-VTS, check engine light, tranny
- P1153 Air/Fuel Ratio Sensor Circuit Response Malfunction
- 2000 Lexus RX 300 Rear Wiper Washer not working
- OEM DENSO 89615-12090 Knock Sensors from eBay?
- Rough idle after a repair
- Engine Flush After VVT Solenoid Replacement
- Finally going to do it - timing belt
- Additional Components to Replace When Doing Struts & Mounts
- Testing Idle Air Control Valve
- Rx300 windshield fluid light is on
- Car cranks but not starts
- Updating Radio System
- 1999 Lexus RX300 Oil Control Valve Filter
- Michelin Stealth Hybrid wipers on RX
- Broken Timing Belt
- Bcm
- Need Rear Drivers Door RX300
- P0171-P0174 system too lean do I need to change the afr sensors or the oxygen sensors
- Low power after rear valve cover change
- Hole in cat to resonator pipe
- Low beams not working
- passenger sun visor 2009 rx350
- 1MZ-FE with VVT an interference engine?
- Just hit 200,000 miles driving home from work on February 2nd
- 1999 Rx 300 Jerking when accelerating
- 2000 rx300 tether anchors?
- P0420 catalyst efficiency low
- Lexus Starter Clicking; won't start
- Headlights and dash lights won't work together at night
- Code p1135 and codep1155 on a 2001 rx 300 Lexus
- 99 RX 300 Strut mounts
- transmission problem 1999 RX300
- RX330 Low Idle after leaving key in ignition overnight
- P1354 P0330 oil burning issue
- RX300 alarm sounds after I stop car
- Seat Heater Issue
- P0770 code and stutter
- Replacement Headlights for 2000 RX300
- Rear Differential Corrision
- Odd starting condition.....
- Battery Running Down After Non Use
- Replace Timing Belt & Waterpump - What else to do?
- ?Where is Fuel filter located?
- Replaced door actuator, now I can't lock by hand
- Electrical Malfunctions
- Installation of bluetooth adapter in 01 RX300
- 2002 RX300 Shift-lock override
- Transmission shift issues when cold
- Thankfully, no transmission issues, yet!
- Armrest replacement
- 1MZFE valve cover washers?
- tried to start got one click no start
- Need help identifying transmission solenoid part numbers
- What is this tube?
- Check engine light codes
- Navigation problem
- Emergency brake light indicator
- 1999 RX300 loose spoiler?
- 3rd Brake Light - No Voltage
- Small Coolant Leak
- Nothing but trouble
- OCV Part Numbers
- Rough idle, no "creep"
- 1999 Heated seat swap
- Removing the CAT System.
- What is the black adhesive used for the plastic sheet inside the car door?
- Apply sealant to top of head during Valve Cover Gasket replacement?
- 1999 RX300 rust spot on undercarriage
- Where to et a 3rd en rear valve cover 11201-0A060?
- 2003 Rx300 air bag light
- Fuel guage
- 1999-2000 under seat plugs different than 2001-2003?
- Slip Indicator Issue
- my 2000 Rx wont start or even crank
- 1999 Rx300 Fender Removal
- Any concern to switch to a synthetic oil?
- Fues or pwer source to the A/C Vent & Heater blend door servos
- 1999 rx300 won't start
- Transmission temperature gauge
- 1999 - 2003 Lexus RX300 in the snow
- Noise at full turn.
- Heater intermittently working on 2001 rx300
- 2000 rx300 cel p0300 p0302 p0304 p0306 p1354
- Happy 2018
- RX300 key which is the master??
- Help, axle popped out
- 2000 RX300 transmission shifting roughly
- need answer asap - control arm
- 2000 rx300 transmission replace
- suspension parts
- RX-300 Security System Issue, Car wont start, don't really know what the problem is?
- Automatic transmission problems - 4 speed vs. 5 speed?
- Charcoal canister vs Evap canister location?
- Use of green Evap Service Port on 2000 RX300.
- Key dilemma
- Playing home burned CD-Rs
- RX300 replace ECU with used one
- Rough noise/vibration upon acceleration only
- 1999 RX300 AWD Rear Wheel Bearing
- P0325
- brakes
- emergency brake cable question
- 1999 RX300 terrible radio reception new radio??
- Whiplash transmission with RX300
- Castrol gtx 0w30 to 5w30?
- New Codes Every Time!
- Parasitic Drain Killing Battery
- Air Intake Control Valve No 2 / P0171
- RX 300 low beam issue
- No Driver's side heat...or pics
- Hard Shifting Problem
- Axle sliding in boot
- rx300 tuttering problems? Please help!!!! Knock sensor?
- Problems arise - shaky idle, misfiring, missing as it accelerates
- 1999 RX300 Rear Axle Part
- Right front suspension replacement question
- Transmission isn't happy right now
- P1155: Sensor is working?
- Is there a hood switch/sensor?
- Brand New Member - Need Some Help Deciding
- Help! Trans Dipstick
- Failure of low beam headlights
- Lexus RX300 new engine?
- flapping noise
- RX300 Tool Kit
- Looking for the transmission part number for 2000 RX300,
- How long to create vacuum?
- Finally replaced rear cover gasket and plug seals
- P0171
- HVAC System
- Cruise Control
- noisy lifters and loss of power
- Rear valve cover.
- Good Wishes Thanksgiving 2017
- Best struts for smooth ride??
- brake lights
- 2000 lexus rx300 check engine light flashing
- Chasing down cold air problem
- can you switch between high milage to synthetic
- 2003 Lexus RX300 All doors are locked and won't open
- Curious about little issues.
- FCS Quick Struts?
- Wrong oil control valve installed - problem?
- Cooling fan seems alittle slow to come on
- HELP! Need New Radiator for my 2000 RX300
- RX300 Lean Bank 1 when Cold
- Wheel bearing gone bad?
- Does my car need a coolant flush?
- Well
