- Resurrection '95. im saving her.
- 98 LS400 Fog Light Relay Part Number
- Power steering going out?
- Trailing Cable Under Car
- Are different year ECUs compatible? Such as a 94 in a 96
- Help with '98 Intake Manifold Removal
- Auto Tilt Wheel Deactivation
- 98 LS400 ACV Location?
- 94 Running cold, no heat
- Transmission replacement cost for others???
- Need Ideas for my car
- My 2000 Lexus ls400 won't start.
- ECM woes
- Red toyota coolant vs aftermarket coolant
- Ls400 issues- P0171 and won't start
- Code 13, hard start, stutter
- HELP!! 1991 LS 400 Engine Dies When Turning
- Spark plugs and wires
- Cam position sensor location
- No Reverse LS400
- 94 Wireless Remote replacement Key and cylinder
- 1993 LS400 vs. Newer Cars
- POLL: 91 or 94
- Replacing backlight bulbs on 1990 Euro spec Pioneer UCF10 radio?
- 1996 LS400 #2 ignitor
- 1997 ls400 issues
- Car Phone steering wheel controls
- coolant reservoir/overflow leak
- Increased Engine Fan Noise after servicing
- Talk me off the ledge
- can a 1996 ls400 ecu be used with a manual transmission swap
- Replace Pioneer subwoofer speaker surround foam
- 1993 ls400 headlights quick question
- Whole thing or bushing only? 99 ls
- 94 Issues: code 12, ran hot, won't start, code 12 again
- 1994 LS400 knuckle bushings????
- Surging Idle after Thermostat replacement-engine wash
- OPINIONS: Custom Door Panel
- Is this tilt motor correct for a 99?
- Whining sound coming from the right
- 91 LS400 - wiper blades
- staggered tires on OEM LS430 wheels
- 94 maf
- New LS400 for me
- Stereo replacement for a '91?
- Door Locking/Unlocking Annoyance!
- Meyhem Lauren Cruising and eating in Harlem in the Gold LS
- Car won't start and loud clicking noise
- Couple Questions: LS400 Timing Belt & Plastic Clips
- Timng Belt Replaced checked timing and WTF
- Guys, pls help... repair manual help
- Limited slip diff 99 ls400
- Location of fuel pump on 95-97? Also is this the procedure?
- unknown parts
- 1999 LS400 front struts question
- Custom Exact Fit Mats
- LS400 Seat Heater Button Question
- 1996 egr vsv
- LS for $650!
- 1999 LS 400 radio would not stay on
- Door frame hole plug plates
- Head Unit Replacement
- Smelling oil in coolant reservoir?
- Debunked: Kaaz DAT3020 fitment in a 95-97 UCF20
- Is there anywhere I can send my Lexus 1993 Ecu to be fixed with the capacitors
- '92 Celsior TRC light before and after TPS replacement
- ECU Inspection?
- High School Project Car
- Trying to upgrade my LS audio - help
- Odometer Stopped
- 1uz-fe bank 1 vs bank 2 coil pack difference???
- Belt or tranny?
- transmission making whining noise recently
- Engine vibration - tracking down
- Looking to become an LS400 owner
- Unknown Vibration
- Interesting LWB for sale in Poland..
- Why do people find it so hard to move slightly away from a predefined style? Discussi
- Help! Dash repair?!?
- Restore or use for parts?!?
- Installing fog lamps, one small issue. How do I get power to it from the cabin?
- Feels like buckled wheel but not.
- Reducing door window frame noise
- Ls400 water coming in both sides of trunk
- 99 LS400 - how to identify if I am Nakamichi Sound System
- 99 LS400 - A1 Cardone Strut replacement - opinions
- 99 LS400 - do the center console switches light up at night??
- 99 LS400 - -largest width supported for 16" wheels
- JoeSuff's-suspension thread
- One year in: Stick with or time for something else?
- 1990 to 1994 Headliner removal
- New to me 1998 ls400 sunroof not opening
- Help! Burnt air filter
- Interior code LA20 rarity question
- Resolving door cladding noise
- 99LS totaled insurance rip replacement advice needed
- OEM Wheel Finish?
- Help Shift Lock stuck
- 96 ls400 brake sensor install help
- decided to upgrade my entire stereo system....
- LS400 specifications for all model years
- 1994 and 1995 interchangeable parts?
- radiator fan clutch
- 98 ls400 no power to blower motor
- I BOUGHT TWO 1994s
- What is this coolant leak?
- 98 LS400 HVAC Blower motor
- shift solenoid E/lockup torque converter control
- Need help - 1UZ-FE VVTI Fuel Pressure Test
- New to Lexus LS400- 19-20" wheel specs?
- May go look at a LS 400 tomorrow have a ? or 2
- Pricing Information
- 95 ls400- engine mounts for 5.3 chevrolet truck engine
- Po171 po130
- Err 22???
- Lexus LS400 ECU
- Charging Issues
- 18" G37s sedan wheels on LS400?
- Can’t figure out vcs issue when accelerating from stop
- 1993 stalling and reving problems.
- 1st GEN BUYING AND SWAPPING QUESTION
- Can KYB GR2's handle H&R springs?
- 91 LS400 Winsheild Moulding.
- Side Mirror Aeroacoustical Noise
- new 99 LS400 owner - seeking a cpl of specific pieces of info
- Outside 'A' pillar trim
- Traction Control Problems
- What's easiest way to fill the holes left when you take off back emblems?
- Live oil leak vid w loud whine! Plz look!
- power steering for LS400, 1996
- What did you name your Lexus?
- Who does instrument cluster led builds?
- Where is security system antenna
- Looking for 1990 LS400 manual PDF
- Alternator for 1994 LS400 needed
- Power steering pump for 1994 LS400 needs replaced. Do I need to buy reservoir too?
- Sat for 1 year
- Alternate transmission dip stick?
- 96 ls400 steering colum motor stops and goes
- 1996 LS400 CD and Tape Issues
- Pic request: Transmission return line from radiator
- Car Shaking at High Speeds
- 94 LS400 High Mount Brake Light
- Intermittent CEL for Knock Sensors
- Shifting seems off, transmission or needs a fluid change?
- Adjust Headlights 1996 LS
- What are the best aftermarket engine and transmission mounts?
- Oem wheel options for my 99 ls400
- 99ls400 master key
- New LS400 owner, encountering some weird issues.
- The old car alarm deal
- Smoke from Y pipe 99 330k
- Plastic engine cover
- Free ECU caps to anyone in Portland area
- Lexus Seat Belt Shoulder Height Adjusters.
- Pristine 1995 ls400
- Removing road tar from rocker panels
- Lost 1997 LS400 Transponder Key- replacement solution
- tilt steering wheel work intermittent
- 1990 ls400 parting out
- are ebay ps pumps any good?
- Need help recovering 2 MPG
- Signal Flasher Too Quiet
- 1992 LS400 parking brake troubles
- Y-pipe replacement part question
- Rear strut question (94)
- Sunroof - not working
- Timing Belt Schedule
- 93' LS - Stuttering issues ..
- 1996 front defroster button light blinking
- Valet key starts,master no,immobilizer hack maybe?
- Bit frustrated, need advice on situation w timing belt, waterpump, and oil leak
- Blown valve cover gasket caused by pcv?
- 97 Lexus LS 400 Electrical Issue
- Recapping 91 LS ECU
- Wiring harness
- Can anyone read Japanese or know what the stamp on this ECU is?
- Faint whine when accelerating on 98 LS
- Hood is jammed shut on '91
- 1996 hard to start after a/c climate control cluster repair
- Speaker frame damping
- high beam indicator doesn't work
- '97 Power Steering Leak
- anyone ever tried to "update" an LS400?
- Weird leaking red gew top of engine 99 LS
- Intermittent Cylinder 6 misfire
- NEED HELP 1998 LS400 intermittent no starts and buzzing sound from the throttle motor
- Lock unlock piece
- NEED HELP - 1998 LS A/C Button Blinking - A/C Only Works From A Cold Start
- What's the second fuel pump ground wire for? (1993 LS400)
- '90 - engine compartment wiring diagram
- Lexus yacht
- 1996 climate control not working
- Codes - VSC, ABS lights and P0441
- Front bumper replacement questions
- Intake/ Sound in intake area questions
- Speedometer dim and not moving
- Temp gauge in wrong position when turned off
- Question about value of one-owner 41,000 mile LS400
- Sputter and CEL at high revs
- 1999 ls400 inner tie rod
- UCF20 pre/post facelift interior differences
- 1999 LS400 Repair Estimates for Valve Cover Gaskets and Timing Belt Kit
- Front fender noise wire conduit
- 1994- radio, power lock, interior lights not working
- 1998 Differential bushings replacement (part2)
- 98 Lexus LS400 Auto Lock?
- Need some measurements
- Front turn signal removal tool
- Turn signal trim repair
- Surging like crazy
- 1992 LS400 Key will not unlock trunk
- 1995 LS400... Just changed my transmission shift solenoids and filter... Aaannndd
- 1998 LS400 Auto Lock ?
- 1999 ls400 battery cca requirement
- 1990 ls400 rear quarter panel help
- Cabin Air Filters
- 98- LS400 Trans wont reverse
- What vacuume hose is this?
- New Denso radiator leaking...?
- Buying a 98-2000...What to look for?
- Spark Plug Fixed many Issues
- '97 ls400
- Shocks replacement (1994 LS400)
- Steering Yoke gone bad again
- Suspension/steering/brakes restoration
- Weird idling and grounding issues.
- Leaking lower ball joint
- Cooling fan broken 99 ls
- check those sway bar bushings!
- 2000 alignment issue
- 98 LS400 battery light on, then went away by itself
- 98 LS400 Nakamichi Amp Location
- Million Mile Lexus LS Has Held up Surprisingly Well
- How do you remove circuit board from ecu
- 1990-1992 ls400 cabin airfilter retrofit or alternative
- Steering wheel has couple inches of equal play left and right
- Lextreme still around?
- 91 LS400 Transmission Downshifting Problem
- RTH 1997 LS400 Trans solenoid "E"
- 96 LS400 Dashboard Sensor Question
- First road trip in my 2000 Ls400.
- OBD2 Diagnostic Scan Tool a must have!
- Testing a Used Tilt and Telescopic Motor
- 1998 Touchscreen Display Wierdness
- Manual swap
- 91 LS400 Electrical issues
- reset batt, now rear&sub spekers are weak
- 94 LS Buzzing Noise in ABS Traction Accumulator & Pump
- 98 ls400 cranks over but will not fire up.. please help..
