- 1990 ls400 extremely rich can’t find issue
- To Buy or Not To Buy
- 95 ls400 diff into a 91 ls400
- Cranks but no start
- Start / Idle issues - ISCV or ECU?
- 2000 LS400 Common Problems
- Air shock bench test
- ECU affecting starter?
- My 1995 Lexus LS400 has P1600 and is being normal..
- Alternator and fusible link issues - seeking some advice.
- 1998 Engine ECU bricked
- missing and sputtering
- Help with P0340 and cold-start misfiring
- 96 electronics staying on
- Cold starts take forever for revs to drop to normal idle.
- 98 Celsior Leaking Fuel Gasket
- Checked my tire age - OMG
- Bought a 98 LS400 for $500, but...
- Razor blade fell into water pump coolant inlet, try to recover or leave it?
- Shift Solenoid E
- No crank, new starter & good battery
- Help: Moon roof and steering column stopped working
- 1995 Lexus ls400: Cylinder 2 and 8 misfire need help deciding how to fix it.
- Gauge cluster trouble
- Swapping JDM 1UZ into USDM LS400?
- Got backed into
- Driver Window Controls Not Working
- 89661-50224 vs. 89661-50160
- Replaced VVT solenoids, evap codes went away (2000 LS400)
- Shock spring seat heights
- 1990 ls400 no crank (no power at starter relay)
- ECU issue
- 1995 ls400 starts and dies 230k miles
- Ls400 power steering issues
- rear knuckle bushing?
- Question on 98-00 Lexus LS400 Deceleration
- 95-97 steering wheel tilt gear
- Fuse box is not coming off ls 400 1992
- Need Help: Aftermarket Rear Calipers for 1998 Lexus LS400
- 1996 LS400 will not accelerate when shifted in reverse or drive
- ‘99 LS 400, no power to Sony headunit.
- 1998 LS400 Crank no start
- Help. Door Lock Stuck
- 97 LS400 Battery Drain
- Seat covers?
- Replacing foam inside blower motor box and around radiator
- Ls 400 code 25
- Ls400 speed sensor?
- A fix for the Nakamichi issues (Passenger side channel going out)
- Gauge cluster 1995 ls400
- 1997 ls400 power steering issues
- 96 ls400 Inhibiting mode?
- 96 ls400 intermittent power loss and crank\no start
- Buying a rare Celsior spec?
- Does anyone have experience with SuperPro steering rack bushings?
- What engines fit
- Any trusted ls mechanics near La/Inglewood for my 92 ls400
- Completely rounded off brake line bolt, can I replace this?
- Parts from Scrapyards
- Are the front lower ball joints the same part on both side?
- Replaced ECU Capacitors, Facing Minor Issues
- Horn intermittent
- Knocking chatter noise at 1200k Rpm in drive only
- 1993 LS400 gurgling water noise from dashboard?
- Toyota Celsior Convex side mirrors on a USDM LS400
- electrical problem?
- What to do with trunk hinge wire harness?????
- broken shifter!
- Confusing and hard to figure out misfire
- 97 temp sensor replacement help
- Power Steering Control Valve?? Part #44020-50050
- Blown Engine, what are my options?
- Running very rich and will not rev easily and idle fluctuation
- 1st Gen Celsior UCF10 Instrument Cluster
- Tracking down a hitch for '95 LS400
- The Unofficial LS400 Buyer & Owner's Guide [2024]
- Serp tensioner pulley wobble/belt not tracking straight.
- P0336 slight miss , hard start and ping even after changing crank sensor
- Help Assessing Rust
- Clear fluid leak under drivers side
- Ls400 clunking and vibration
- 94 ls 400 no crank no fuel pump
- V12 LS400 project.
- Torque specs for drive belt tensioner mounting bolts/nuts
- Helps, Fan clutch pulley or replace entire fan clutch
- Your One Stop Lexus Shop!
- Questions on oil leak
- 99 LS400, Battery in backwards.
- What wire is this for? Thanks!
- Information purpose thread, tensioner assembly brand
- 1990 LS400 - New Problem. Flickering cluster lights
- Rear Turn signals and flasher not working
- 1996 Ls400 battery wont stay charged
- No crake no cel light when key is turn
- Converting from R12 to R134a
- Ignitor Circuit Multiple
- i don’t know what this isssss
- The most bonehead error ever!
- Front spring - mounting on strut
- was watching some Seinfeld season 3 (1991) when i saw the C&D magazine :D
- 90 LS400 - Lo Beam, Fogs & Turn Signal Don't Work
- 1994 Toyota Celsior cranking but not starting
- Serp belt tensioner assembly replacement
- Electrical gremlins after water leak
- UCF10 Running Lean
- 1993 LS Wheels
- 1999 LS400 steering column tilt does not work
- White smoke out of exhaust.
- Ls400 limp mode
- stalling and gas leaking out of the charcole canister
- Play in both rear wheels
- Number 1 speed sensor from other vehicles
- 95-97 vs 98-00 Tan Leather: same or different??
- 1990 LS400 check engine light/traction control off light turns on
- ecu pin out
- Need help replacing power steering pump
- 1UZ VVTI Cam Gear Oil Leak?
- Deleted the power steering pump air valve, what to do now?
- Ls suddenly shut off at red light now it smells like its burning
- 1998 LS Halogen to HID conversion
- 1995 UCF20 RHD with Bilstein. Anyone have experience about it?
- Engine misfire
- LS & SC rear caliper differences?
- Front brakes dragging, rears dragging slightly
- LS400 fender question (UCF 10)
- Need help - Got spark, fuel and crank but no start
- How to reset proportioning valve 1991 LS400
- What is the correct Front Passenger Door Actuator Motor Part?
- 1999 ls400 steering tilt motor
- 95 LS.Where to purchase crank sensor?
- Taillights not working but brake lights are fine!
- Fan Pulley Part #16371-50030
- 1999 Ls400 Key Fob Issue
- 98-00 LS400 rear subframe comparability with 95-97
- LS 400 1993 Manuals vol 1 and 2 available
- Gone in 60 seconds
- Links List for LS400
- Keeps blowing fuses
- Need help - Camshaft middle gear removal
- 1999 ls400 ecu replacement
- Lifting the LS400 onto blocks
- Ls400 can run 5w40 factual.
- Belt for power steering pump delete
- Disconnected / broken wires in the trunk, wanna know what they're for
- 93 Lexus LS400, no backlight on dash buttons or gear shift
- Re-wiring
- Water leaking into trunk from tail light
- 98 LS Vibration
- LS400 Power Steering Issues - 1997 LS400 Pre Face
- No fluid to rears. Fronts sticking
- How much is my car worth
- GS400 Compass Rearview in 95'
- 97 VVTI Celsior power loss that seems unfixable
- Cooling system refill problems
- Smog sensor filter cleaning - how to
- 1995 LS400 low idle in gear
- 90 LS400 - Part for Headlight Sub Assembly
- 1993 ls 400 stalls when warm
- Fuel injector advice. Reseal myself or send out?
- 95-97 LS400 Transmission Rebuild Kit
- Leaking ECU Caps???
- How to remove the subwoofer from 96 LS400?
- Crank no start
- Ignition key switch removal HELP!
- Cat removal
- No crank/No prime
- License plate bulbs 98 Ls400
- Please help car wont run
- 1uzfe
- Lexus LS400 Is One of the Most Reliable Cars From the 1990s
- P1351, timing question
- 90 LS400 Front End
- Weird cluster issue
- Brakes sticking
- Parking Brake light not turning on.
- Power steering chaos.
- Large nut securing bracket to passenger side inner tie rod next to bellows?
- 90 LS400 Airbag Code 15 - Help
- 1998 LS400 Seat Belt Replacement
- Coolant leak 99 Ls400
- 95 LS400 Power Seat Motor
- Brake bleeder size
- need help with 1997 Lexus LS400
- Help identifying cable 1993
- Just got a 1993 LS400 and need some guidance
- Immobilizer problem
- driver's seat pad restore?
- Lexus 2000 LS400- Slow shifting Transmission when cold
- Lexus 2000 LS400- need a new under engine cover
- Nakamichi Radio problems 1995 ls400
- Floor mat clip popped out
- Dealership sold me a remanufactured starter?
- 98 Ls400 Rear View Mirror Removal
- LS400 1998 dash error code EFI 19 meaning
- Very weird issues with my LS400 possiblew
- No power. Reeks of fuel, NO CEL 91 ls400
- 90 LS400 Start Issues
- 95 LS. Harness connector broke on the coil
- Dome? Fuses? Security? Actuators? 97LS400
- Transmission solenoid connectors keep braking
- VSS issue and intermittent check engine light
- ECU leaking capacitors help
- 1995 Ls400 Smoke from tailpipe choppy idle + gas smell
- Downstream O2 Sensor Replacement
- 1998 LS400 Lower Dash Cover Ports
- need help. 92 LS400 power steering ACV cross thread
- Here yet again,1995 ls400 not staying on
- UCF10 Exhaust Cutouts
- Intermittent Stalling, Power loss/No throttle, No start but idles great.
- Air suspension compressor question
- 98 LS400 Power Steering Pump
- Weird issue with my 96 LS400 this weekend
- Tire Speed Ratings
- 95 Lexus ls400 Shift solenoid A replacement
- Low-beam lights don't work - 1996 LS400
- Engine Splash Shield Falling
- 1999 LS Air Sus doesn't work at all
- Battery keep dying
- Trip A and Trip B, Reset buttons not working
- 99 LS400 battery light on after starter replacement
- Celsior Seats
- 1994 LS400 loss of power, followed by no start.
- Brake caliper "clips"
- NO POWER, idles smooth
- help with misc part
- ABS wheel speed sensor, any interchangeability?
- Running issues
- Stripped transmission pan bolt
- Instrument Cluster dimmer knob not working
- Brake maintenance, parking brake light turns on when accelerating/braking
- Starter issue? Iginition switch? Something else?
- Center Console, radio display and odometer don't light up at night
- Ls400 1992 ticking noise
- ECU-IG 15amp keeps blowing
- bulb out - fourth gear on dash
- 1998 LS400 Deceleration Sensor
- will not drive with vsc on
- Ticking stopped low oil white blueish exhaust
- Splash Shield for 1999 LS400
- 1uz vvti unit re-assembly
- 1995 2nd gen Project with crash damage, want to try repairing on my own.
- Cartridge Fuses....
- 95 vs 96 Strut Rod Bushing differences
- What years are the clearance light interchangeable
- JDM 1996 CELSIOR UCF20 ( 1996 ls400 rough idle wants to die
- Should I sell my 2012 Hyundai Genesis for a 2000 LS400?
- 1998 ls 400 Passenger side window washer nozzle replacement mocha color
- 1998 LS400 P0340 error - continued
- Should I buy this 92 ls400?
- Floating 10 inch audio screen
