- Intro thread - Minnesota LS400
- Blown factory amp. Can I replace with a new head unit?
- lexus ls400 UCF10 1992 rear upper control arm
- 1998 LS400 Maintenace costs
- NEED HELP - Coilovers
- SonicC's 98 LS400 "Restoration" Thread
- Ls400- 1995 ECU problem
- Ridiculous
- I don't understand this one.
- Not another repairs needed thread
- Transmission - front pump
- 1992 LS 400 bucking...and other problems
- LCD Screen where to buy for 1999 ls400
- For Sale and WTB threads go in the classifieds
- Gas Mileage
- Best Engine Oil
- Differential Fluid
- '92 LS starting problem
- Engine Oil Flush
- Installing DVD/Stereo in 1998 LS400
- 1992 LS400 one button remote key
- Please help -stuttering, loss power, stalls
- 95 ls400 project car
- ecu. help. what and where to buy transistors
- Window tint question
- Ucf10/ 1993 ls400 rear camber?
- Replace Harmonic Balancer?
- 91 LS400 HELP Sputtering Not Accelerating right
- 92 LS400 Temperature Gauge
- electrical problem need help! battery drain?
- New or used coils?
- '91 LS400 Headlight/TailLight Issue
- Door panel removal driver rear to fix locking/unlocking Act.
- Over Heating Issues 1994 Lexus LS400
- obd1 codes 13 22 25 71
- Trunk lip ideas
- Cant find stock LS430 wheels/ Want to Buy/ How bad are adapters? (Pic)
- Wheel fitment question 98 LS400
- Engine surging power loss
- Need Help: '96 Lexus LS400 turns over but won't start.
- Questions and part numbers - 98 LS400
- Rear Suspension/Shock Deflating - HELP!
- 02 sensor from 94 to a 95
- running rich ive looked through forums.
- 1998 LS400 with a JDM 1UZ VVTi swapped in - temp and fuel gauge issue(?)
- SOLVED...almost. Acceleration issue, Help!
- Nakamichi System...Radio works but CD/Cassette do not
- Sunroof issues after battery replacement
- Combination meter/ Rheostat
- Timing Belt What to do please help
- WTK: Forums for Toyota Prado
- 1993 LS 400, Speedometer sometimes works and sometimes doesn't (sits at 0)
- Old vs New: 900k 1996 LS400 vs 2015 GS350 F-Sport
- Anti camera stickers
- LS Coil Spring Rate: OEM Tanabe H&R
- Upgrade -suspension, brakes and power?
- For what it's worth
- 1991 LS400 off brand seat belt replacement?
- Another automatic transmission fluid-thread
- Tensioner pulley finally froze
- rear center passenger seat belt
- Lowering a 93 LS400 on coilovers
- lexus ls400 model 2000 ( p0125 )
- anyone know about a 1990 LS400 air shock adapter?
- 1998 Lexus LS400 volume knob
- How to removed instrument cluster removal 1999 ls400
- Battery Died now get "Check VSC"
- Which is preferable setup - H&R + Bilstein HD or H&R + KYB?
- Fresh 4 wheel alignment
- please help- erratic idle when warm, engine dies
- I'm getting the cel 450 code - evap sensor
- 1992 celsior (Ls400) running rich and not much power
- Thanks for your support.
- CEL & fuel cut
- just came in to a 96 Ls400
- Jdm power mirrors
- 1995 LS400 Timing Belt and Water Pump "how to"
- Looking for a LS400
- 0W-20 oil
- Gonna buy some Coilovers :) opinions/advice appreciated
- What is this? A/C condensation
- lexus performance parts needed
- Drifting AE86 Plays With LS400 V8 Power
- Tilt wheel not returning to driving position
- Re-badge and interior panel removal
- 1UZ-FE Individual Throttle Body (Project)
- Aftermarket steering wheel hub
- ls400 window motor?
- Rear suspension difference 91-99
- New owner First time Lexus
- water leaking into both front doors
- Cost to replace CATAlytic converter 94 LS400
- replacement master keys
- LS 400 1994 Intermittent start puzzled?
- Can we get an Instagram user name thread going?
- Need help. 1991 Headlights for Non US LS400
- how to disable windows opening from remote?
- No electrical power '93 LS400
- hey all just saved my 400ls from being scraped but...
- 1992 LS400 Pioneer Subwoofer 86160-50010
- 18x9.5 fitment
- mpx b fuse and dome fuse
- Having odd electrical issue.
- Need Help,,,Valve Stem
- 1998 LS400: Engine suddenly sounds different??
- Exhaust suggestions
- If you find a nice one, buy it ASAP
- Uh-Oh: Car throwing 0763 code??
- Need Help,,,,TMPS question
- Wanted 1999 LS400 center air vent
- Adding Bluetooth to stock radio - could it be this easy?
- Unexplainable 3 cylinder misfire
- 1991 LS400 Engine Sound
- Need Help - 1994 ls400 sunroof opens but will not close
- Making room for quad exhaust..
- Loss of power - help
- FOR SALE 1998 Lexus LS400 3300 OBO 231585
- Lowering a 93 Ls400 with OEM Air Suspension
- Does a 1994 LS400 with 68k miles need new timing belt?
- How healthy does this timing Belt look?
- 91 ls400 - need more power!
- How to change the cabin air filter in a 91 Lexus?
- Shift Kit for 1999 LS400?
- 98 LS400 Connected jumper cables backwards
- How to reduce/eliminate wind noise using Gummi Pfledge
- 92 LS400 ECU and Starting issue
- little bugs in my Ls
- 94 LS400 DS Electric Seat vs 91 Electric Seat Problem ?
- 4 amp battery drain in 98 ls - nightmare..help
- aisin timing belt water pump kit for 22 dollars
- Broken headlight
- Is it the Headlight Bulb or Lamp?
- Sourcing oil leak. Cam/crank seal pics.
- Erratic Fuel Gauge
- looking to upgrade my sound system
- Bearing front driver
- do you still have a clunk AFTER SRB's??
- Need help fix/disabling HID auto-leveling feature
- 1999 LS400 Starter rebuild
- timing belt shortcuts
- Thanks to the forum for all your help.
- Chasing LED tail lights 1995-1997 Planning
- Speedometer sometimes doesn't work, ABS and tach are good
- Trac light comes on
- Exhaust volume comparison
- Noise coming from front suspension: what could it be?
- Engine mount still good or bad?
- Air Suspension - LS400 1998 210,000 miles
- 1999 LS power steering noise, fluid not low
- Help me , my ecu engine 89661-50310
- What's it worth? - 93 131k
- 96 LS 400 - Camber and control arms
- 91' Ls400 electronic problem
- Replacing coolant temperature sensor & VSC: is there a connection?
- Is there an Alternative to Beat-Sonic SLA-20AD
- so I lost my brakes today.
- Thinking about trading for a newer model
- Timing mark help
- 3mm spacers on front with out extended studs. Safe?
- Antenna parts
- Not good news
- Replica LS430 18" worth it?
- 1997 ls 400 shifter problem
- Strange leak in trunk area: need help diagnosing
- Clear indication your 'new to you Lexus' has not been cared for properly
- Vacuum line tuck? Emissions delete?
- Battery installed backwards.... (UCF20)
- Looking for '98-'00 LS400 Rear Suspension Diagram, with Key
- 1996 LS400 steering pump groans
- Just the exhaust tip...
- Did anyone see Adam Carolla's new movie Road Hard?
- New lower ball joints for my 1999 LS
- HELP no start
- Questions for various electrics - electronics
- 1999 LS 400 brochure
- speedo and ecu issues
- Rear knuckle bushing 1994 lS400
- Starter motor
- Clarification: changing out oxygen sensors on 1998 LS400
- High idle at start up lasts longer than it should
- 1999 LS400 TRANSPONDER Doesnt Work AFTER CHANGING TRUNK LID STRUTS!
- tt supra calipers
- Back Light does not work on my stereo
- Need opinions on the fate of our LS400
- car only tries to start with key turned
- how many different trannys in a 95 ls400?
- CODE 31 Help
- Hiroshi's frankenbumper, pt. 2
- 92 ls400 2nd gear slips or doesn't catch?
- ecm
- High rpm idle after resetting ecm, 1200rpm in drive
- excessive - Smoking and oil consumption -PCV
- Looking for 2nd '97 LS400 - Is Trac Control worth it?
- Do 02 GS430 wheels not fit the LS?
- resistance too low on my brake fluid level sensor
- Need help, just replaced front rotors & pads..
- Need help-accidentally ate through the finish on my '99 LS400 stock wheels
- A650E cooler
- Real Car Reviews Tackles the LS400 (Not Matt Farah's Though)
- PPE headers UCF20 clearance issues?
- 1992 LS400 Electrical/Short/Failure
- Stock wheels-strip the clear, sandblast and re-paint?
- Seat compatibility between UCF10 & 20
- ADDICTED to LEXUS
- specs on tps (96 ls400)
- Tutorial: DIY Gauge Cluster LED Needle fix
- All electrical fail, won't go into gears but engine turns
- Lower glovebox removal....not so simple
- 96 Ls400 with ONLY 17k miles
- adjusting date on Sat Nav
- 1995 LS400 Key cutting
- Clarification on ATF fluid change: 1998 LS400
- Lexus LS400 idle RPM speed???
- Did they do a European "Standing Light", aka why is my left turn lamp stuck on?
- Lexus LS400 Gear Selector plate or cover or whatever it is called.
- Lexus LS400 Premium Sound System No Back Light & Non Active Rear Speakers!?
- Cluster light problem..
- 99 ls400 runs rough 2500-3000 rpm
- 1998 LS400 Buying Advice
- ASA AR1 wheels 18" wheels
- 1992 LS Keyfob Battery Replacement Code
- Wires, wires, and more wires: sharp eyes needed
- Can I safely go 10k on Mobil1 EP oil and filter
- LSCowboyLS
- 1994 lexus LS400
- Turn signal stalk might be broken
- Bought blue leather seats...want to dye/paint black...any advice?
- Hood latch problem...
- PCV & smoking- Very Strange. Stumped....
- Need help in identifying gasket
- 98 LS400 front turn signals are they night time running lights?
- 95 ls400 ecu pin outs?
- '92 Rim offset w/SSR Vienna
- First Lexus
- Starting problem (maybe electric???)
- Ls400 #3
- 1997 LS 400 Transmission Fluid Change ?
- Possible future LS
- cranks-runs then engine dies-need help
- And now to have some fun, 98 LS400 in the garage
- anyone else using power steering fluid
- 1998 LS400: what is this part called?
- Engine bay shots..
- LS400 Backup / Reverse Camera
- LS430 6-speed transmission on a 2000 LS400
- Can the camshaft position sensor be affected/damaged when working on the radiator?
- OCV Problems
- Nakamichi audio no treble nor bass??!!
- 93 LS400 Engine Temp Indicator at 40%
- Brake light playing peekaboo
