- Engine seal kit
- ECU service information
- Help !!!! - clicking when trying to start
- Where do you lift using Floor Jack
- 95 Ls400 Knock Sensor Wire Location in ECU
- Rear Wheel Going out of Alignment??
- 1990 ls400 value
- Where to find exact fit carpet kit for 91 ls400?
- Has anyone tried this ATF??????
- Problem with locking driver's door
- New seat belts?
- REAR Stabilizer Bar Link - OEM or Other
- Brake Calipers - How Urgent?
- Winter Tires/Wheels
- 1996 LS 400 Mirrors VS 1998-2000 models
- Alternator Replacement Info provided
- Engine oil light comes on when door(s) is open
- How would you feel about buying a 1998 LS400 with 244k?
- please help! doors flying open!
- HELP!! Ucf10 cv axle popping out
- Best 1/4 mile time so far....
- ls400 alternator or fuse issue?
- Engine mounts on 96
- Rear Bumper question
- car accident
- New LS400 owner!!!
- Thinking of selling - Should I or nah? how much?
- Trouble Selling High Milage LS400
- Full Throttle Behavior
- Engine cable / Line got cut while driving
- Abs
- Widest Tire on 1LS
- automatic choke
- Rebuilt power steering pump, now vibration
- 92ls400 Big problem! grinding noise, low idle..
- P0171 & rough idle after changing starter 98' LS
- Another Dash Light Bug
- the LS400 disease.
- mk4 sc300/400 subframe in ucf10?
- 93 LS400 Drift - Easiest way to lower gearing?
- Is wheel track the same
- Soon solved my bad lightning issues!
- Brake pad wear light questions
- Head rest question
- Speedometer reads slow after repairing needle illumination
- rpm drops during acceleration
- Looking for alinement specs
- Help with these symptoms- code 25, 26 low idle
- Where did you get replacment ac compressor?
- Who sayis there are no great 2000 LS400's left? Right here!
- How do i take this off -fan bracket sub assembly
- Air shock front 98 fit on 96?
- Odometer question 92 LS400
- Ecu doesn't ground Fuel Pump Relay
- Just replaced the starter in my 1995 LS400, brutal
- From start(er) to finish
- Code question
- Car randomly gets warm
- Blower motor / A/C clutch
- Sway Bar Links brand ( does it matter ) ?
- 95 ls400 cd changer not working not playing
- In trunk cd changer
- what do you guys think of this? Tons of dealer maint. city driven ok?
- Could crappy gas be my issue?!
- Naming your threads.
- ECU Swap...when is "reprogramming" necessary? (Any other ECU replacement advice)
- Help! Thump when letting off gas
- Throttle Position Sensor Faulty
- 1993 LS400 Electrical Problems
- 1992 LS400 questions
- Glove box question 90-94
- consistant driver foglight dies
- Please help me! Erratic-won't run after ECU change
- LS400 Automatic Transmission Fluid help
- Driver low beam headlight not working
- rebuild 97 LS400
- just did timing belt engine sounds kinda like a diesel please help
- 1993 LS 400 Seat power
- Interchangeable parts- 98 to 91 interior??
- What else should I replace?
- Need a louder car! [exhaust]
- 1995 Ls.Is it that hard to chnage the T -belt?
- Eletrical system issues
- Need help this afternoon 9/18 - Air Intake hose ripped
- need help identifying component
- 1991 won't start due to theft control starter kill?
- Thinking of buying an LS400
- If you were needing a transmission..where to buy?
- engine misses
- Engine Code 25 - O2 sensors? capacitors? EGR pipe?
- Headliner removal forward of sunroof?
- No Heat or AC....HELP! 91 Ls400
- Hit and Run
- Wiring diagram needed, amp drain found 00 LS400
- LS400 wont drive?
- Double glazing
- Front BBK to the extreme?
- dumb question. ..but 15-40 oil?
- Car won't go into park or reverse without pushing in safety switch near shifter?help!
- Heater/AC problem
- Repair Manual
- key help please
- Accessories on when the ignition is on?
- Question about No. 1 idler pulley
- Wiring up New Amplifier to Stock Pioneer Amp Harness? (1994 LS400)
- Any tips for power wire through firewall?
- 1994 LS400: New Brembo Rotors.....which brakes to use now?
- LS400 overheating and possible knocking?
- Front Passenger Window
- Gearshift getting stuck on neutral after tranny oil change
- 1994 LS catalytic converter Replacement
- 1998 LS400 rear seat armrest panel
- 94 LS400 223000 miles Egg smell?
- 1995 ls400 differential noise with video
- Ucf 10 gated shifter+ucf 20 style center console(pisc)
- Need some help on finding out who makes these wheels.
- My First Lexus: 1993 LS400
- No start / Electric Gremlin SOLVED! DTC Codes 14 & 15
- My ebay chrome grill 95 ls 400
- Are all the LS's in bad shape?
- LS400 Bucking and Won't Pass 50% Throttle
- Leaking Antifreeze?
- Leaping 98 LS 400 with 368K miles on it.
- nakamichi cd player help
- LS400 Front Swaybar modification - Your thoughts needed.
- must share - small fuel filter makes big difference
- non wood package 98 convert to wood?
- What is this leak?
- My car will not start...
- 3UZ Timing belt/Water Pump/Tensioner fit 1UZ?
- Headlight leveling on dashboard
- 1998 LS400 HVAC unit buttons not backlit after installing new radio
- Failing engine, maximum speed of 3000 rpm and red exhaust, what can be?
- Added PS Stop Leak - Reservoir Now Empty
- 99 LS400 overheating
- Anyone ever chnage their drive shaft bushings?
- Tranny wont shift while headlights are on...
- BMW Style 95 fitment question
- interior lights not working (dome light, foot well)
- Brake warning light on, now off, need help
- Seatbelts? where to buy
- Ls 400 coolant leak
- Improving the look of a worn steering wheel
- Tuning & Throttle Body Gasket
- How to Wire up a 1UZ engine (VVTI and non-VVTI)
- Key Will NOT go all the way in to START CAR
- Coverking seat covers
- Introduction into the Lexus world
- Ls 400 (1994)power steering pump & alternator replacement
- Quick question regarding key less entry
- Steering Wheel Mod
- Lexus LS 400 1994 Unusual Idle when at traffic light?
- "Mooing" noise at idle
- Alternator Wiring
- Radio and Keyless entry doesn't work - 98 LS400
- got my first Lexus ever, need some help
- TRUNK LEAK - and how i found & solved it
- 96 LS400 Oil Leak
- Will 1993 brakes rotors pads fit a 1995?
- aftermarket stereo and factory sub
- Rear Strut Rod Bushing Repacement - GEN1
- UPPER CONTOL ARMS - Useful info
- Toyota ATF T-IV vs T-II
- Help - AC questions
- 94 vs 95 transmissions.
- Airfilter drenched in coolant?! Help?
- LS400 Cabin Air Filter and No more smoke smell!!!
- Can I put a 99 GS400 engine into 97 LS400?
- just found this article
- LS400 dont go sometimes.
- Replacement keys for 2000 LS400 - ebay ok?
- vsc lights on after I use OBD scanner
- Repairing Gauge Cluster
- 1991 lexus ls400 starting issues
- Time to replace the head gaskets
- Parts interchange-95 GS to '93 LS?
- ABS and VSC issues on a 1998 LS400
- will a 96 r/f door window fit a 99 ls400
- My New Toy Car! Did I get a good Deal?
- What years interchange with a 92
- Poor running and check engine light after cleaning maf
- looking for a maintenance manual..
- 1995 ls400 grill on ebay.What do you think
- Coolant leak - cancer can not be cured?
- Winter tires stretch?
- New to me 1995 LS400 172k
- '98 windshield onto a '95
- '99 400: Noise when brake pedal depressed, car stationary.
- Failed smog! Air injection failed
- runs rich, cuts off erratically above 2500RPM
- ls400(ucf10) seems sluggish
- Powering electric seat with no power to car
- 97 ls400
- JDM Upper intake man. has fuel line ?!!?!?!?!?!? PLZ VIEW PICTURES
- ucf20 badge less grille
- Bad light from aftermarket headlights
- 94 LS400 runnin rich HELP
- Broke battery tray bolts... Suggestions
- Antenna hole diameter?
- Lexus Throttle Body Extended Warranty
- Kik down
- No spark, ecu related?
- Trany noise
- Swapping interior of a tan 1995 LS to a black 1997 LS
- Can i use a 91' transmission in my 93' car?
- Hesitation at low RPM & Shaking at Idle
- Center arm rest storage lid won't stay closed...
- Coolant Level Dash Light
- need a measurement of 2nd gen wheel hub:
- How I fixed my Soft Brake Pedal (99 LS400)
- LS400 Track car styling
- 98 LS loud bang on speedbump in front after lowering!
- Maintenance cost- Help!2000LS
- Paint removal, Front bumper flaking/chipping
- i need to know if gs300-gs400 steering wheels fit
- 1992 UCF10 Radio dead, fuses ok.
- '96 LS400 A/C restricted air flow? Freezing up?
- 1uz eating belts
- 96 alternator wiring harness plug
- ring and pinion install kits for LS400?( Supra MKIV differential installation)
- My Dumb Low-Speed Bumper Collision--Any Cheap Fixes?
- 91 LS400 How hard should turning be?
- 1994 LS400......transmission fluid needs replaced
- Water Leaking from passenger door is this a common issue?
- Another Fuel Gauge broke.
- 91 LS400 Power Steering Dead at Idle
- 93 ls400 help please - overheated
- OBD2 Scanner
- Post-crash Air bag R&R question
- 96LS Instrument Cluster Needles Tears out!!
- Thinking of selling, pls help me value car(s)
- Cleaning LS400 front/rear windows, seriously
- 1991 LS400 no start issues "Heeellp"
- please help--worth it?
- Keep it or Sell it
- 1996 LS400 tranny issue? Hope not
- Question about lowering springs on my '99 LS400
- HELP me fix a high idle issue 1300RPM+?
- Just got my first 1990 Lexus ls400
- Better rear lift point than diff?
- 1uz twin turbo manifolds
- Can the infamous EGR leak cause a/f lean mixture code 25?
- heavy black caked gunk intake manifold and ports on head
- New Club Lexus Member, Long-Time Lexus Owner
- Missing bolts?
- "New" to me! Got my first Lexus!
- Poll on Wheel Job
- Trunk pin switch/cargo lamp
- When should I change brake pads?
- Spark plugs
