- Better off with a 95-97 w/ low miles, or a 98+ w/ relatively high miles?
- New rear lower control arm/trailing arm time?
- 92 Lexus LS400, Need wiring diagram for dash trunk control to trunk latch
- How long does it take for a timing belt to crack?
- Anybody have an 1g oem speaker handy (measurments needed)?
- OBD1 Engine code 25 and Trac code 51
- Introduction ('99 LS400)
- My LS is DONE (well, for now)
- brake question
- 2000 ls 400 exhaust leak and engine vibration
- 94 Lexus LS400 suspension problems
- Help with vibration 92 ls400
- Shift Indicator Replacement
- Bimetallic Valve
- Blown A/C??
- Another question on CEL Situation
- Picking up a 91 LS400 tomorrow morning!
- MY HEaddd Lightss
- Why is my A/C headpressure sooo high?
- Trac off light?
- Need some advice on my 1991 LS400
- 99 LS Power Steering Fluid or ATF ?
- can someone help me!!!
- 91 LS4 Dying at stop lights...
- washer spray nozzle adjustment
- Anyone have pics of any 1st Gen Silver LS400s w/ wheels?
- BCR coilovers on ls400
- Alot of TRAC trouble codes in my ls400 :-(
- Need Help: Tilt Steering
- Power steering pump knock?
- The economy lamp always lights green
- Picked her up! 94 LS400 - Need help with a few problems!
- Check engine light on, O2 Sensor code
- Fitting 18x10s
- LS400 AC fuse blows
- Hey guys new member here and yes already a problem.
- leak in trunk
- Clear headlights on 91?
- 1998 LS400 Fan Speed Controller
- Ooooooooooo! Ya'll gon' be mad!
- Electrical Problem - HELP NEEDED
- Hood problem.
- Rear control arm/carrier/trailing arm part numbers and sources?
- Not sure what happened.
- Just test drove a 99 LS400 and a 99 GS400
- 1994 ls400 - alarm randomly goes on
- Key-off operation function power windows?
- 1993 LS Firewall Location
- '95 LS 400 Wheel fitting.
- New member intro and ??
- Replacement sub for UCF11?
- Anyone else have their rear axle bolts fall out by themselves?
- Wheel Fitting
- 99 LS chrome bumper inserts.....where to buy?
- 93 LS400 boiled oil.
- Beck Arnley Parts
- coilover settings
- What has to come apart for EVAP replacement?
- 93 LS400 Exhaust opinions and advise needed please!!
- Oem air ride
- Max Camber
- Looking for an LS around $4,500 or so...
- hey guys and girls i have a question? (coilovers)
- Help with 1997 LS 400 audio
- Why is my '96 LS shifting so early?
- Replacing emblems on '96 LS400
- O2 heat sensers gone bad... i think
- Need help 96 Ls400 (P0340) hows it look like???
- Exhaust Cam change make hp?
- Buying an LS400 with 250K miles....
- variation of instrument lighting problem
- Going to pick up my new 1994 LS400 on Saturday
- disconecting traction control on a 92 ls400
- Factory security system
- Anyone here bought the 98-00 LED Tail lights on Ebay?
- HID Question
- 1992 ls400 traction conrtols issues?? !!help!!
- Worth putting a dual air intake?
- upgrading to 145 amp Alternator
- fuel pump question
- Oil Leaks with Synthetic Oil
- Electrical problem
- Vent Shades?!
- Ignition Tune Up - OE Vs. OEM
- "Take To Car Dealer" Warning Light
- transmission shifts BUT.... problem?
- Possible facelift 91 > 95 hood and grill ?
- JIC Coilover Thread (Post Your Pics, Settings, and Discuss Please)
- lights stay on? 91ls4
- 1993 LS400 driver's window problem
- My 98 ls400
- Advice: G37 wheels on LS1?
- Flushing Brake Fluid
- '98 windshield replacement & cleaning or replacing the headlights
- 90 LS Weird Noise over 60 MPH
- New to the forum. checkout my ride!
- 99 ls 400 key battery screw
- Window problem fixed!!!
- Installing New Free-Air Sub
- Helix AER Air Suspension Kit
- newbie needs some tips please
- in dash navigation HELP!
- 93 ls 400
- Power Door Lock Problems - 94' LS400
- Ball Joint question,, fresh perspective needed
- Question on R-spec Data System ASC680 controller.
- I Checked The Air Conditioning Diagnostic Codes
- Out with the old, in with the new. Look!
- Synthetic throughout drivetrain
- EGR Pipe DIY
- Death of a starter
- Starter relay...
- Warning light
- 1LS wheel size question
- Lexus badge on Toyota grille
- Dropped PCV Valve... Can't get it out... Help
- ECM source voltage issues.
- a/c cycling on and off anyone?
- Shudder, Stumble at Low RPM ?????????
- Idle going up and down
- I'm back, plus question about dual filament brake light.
- Looking to buy '98 LS400, should I be worried about it's high mileage?
- European/JDM Lip
- Pics of 'uneven' tint on an LS? Cant find any
- Question for LS Experts
- 2000 ls400 mouse smell when in resirc
- coilvoers
- Lexus LS400 head gaskets
- Timing belt change.
- Looking for parts list for 91 ls400
- anyone put hydros on a ls? looking for ideas here
- a little bit lower! new pix! more mods!
- 17" IS rims
- Ways to tell if LS400/430 has air suspension by VIN?
- wiring!!!?????
- My LS won't peel out!
- Driver window problem
- any one wanna trade grilles? i have the toy logo
- help LS400 stereo
- Check options using VIN number
- ♫ DO™ - Picture Me Rollin' ♫
- 92 LS400, Radio (Head Unit) dead after battery replacement...
- Problem Removing 96 LS400 Rear Dome Lights
- $$$96 Ls 400 Power Steering Leek$$$
- HELP!!! car dying, but only on hot days
- 93 LS400 serious hesitation/ bukling problem, need HELP!
- 97 ls400 replacing head unit, speakers, amps, wires, etc
- what the hell is this
- LS400 EGR Code 71
- Mazda 6 oem rims on my 93 ls4...?
- No sound when engine's running '95
- Lexus Knock-Off Rims
- about to own a 99 LS400
- my car wont start
- 12 Volt Sources
- Foglight question
- Buying a 1996 LS400 next week, any comments
- LS400 exhaust system
- LS400/460 baby
- 1991 Ls400 with Air suspension Problems
- 94 LS400 for $800 should I buy it?
- Check Engine Light Issue
- wheel styles
- How to fix the problem with non working reclining on drivers seat. Pictures inside
- megan coilovers on ebay.....
- Question on upper control arms Gen 2 vs Gen 1
- 98 LS Lowered *pics*
- Over heating 91 LS400 w/ pics!
- 95 LS400 rear airstrut bad question
- Driver seat problems!!!! Please help!!!
- According to Gates, 95-97 LS400's are NOT Interference Engines
- FINALLY!! got my LS
- Exhaust questions, cats and mufflers :)
- Can anyone please help me find a Billet grill for a 91?
- ls400 antenna hole plug!
- My new Ls400
- just got my 90 ls
- First test drive of an LS, 1999 LS400
- Can a 1995 gen 2 Ls bumper be mounted up flush on a 1991 gen 1 ls?
- Cap/rotor replacement
- Stuck in Park GEAR *NEED HELP PLEASE*
- Lexus seatbelt warranty
- im tired of this!!!
- Modified my Tail lights today :)
- Doing a muffler delete
- UCF30 seats/doortrims into UCF20?
- 98 ls400 w/NAV electronics dead
- Need some quick 02 sensor help (97, walker univ.)
- Small Puddle Of Water Forming In The Trunk At The Bottom!
- Hit and run!
- My New 1995 LS400-Some Niggles
- Huston,we have a problem....with my car!
- Couple questions regarding the LS400
- injector question
- LS460 rims on LS400 - fitment?
- Fan motor problem escalate's.97 LS400
- Trying to fit 93-94 headlights into a 91? anybody?
- New struts and now ride is horrible
- "Im Dyin' Here" no voltage to A/C fan blower
- LS400 Air Suspension Button Location
- Tires from Costco.Will 235/50/zr 18 fit on a 95 ls 400?
- engine issues after repairs...
- Suspension questions
- longer wheel studs needed
- help..
- she dumped me!!!
- Sunroof Adjustible?
- Sunroof replacement
- Help! Fuel Gauge Reading Empty when Tank is Full
- Radiator bites the big one after freeway...
- Please help 91 ls 400 running hot
- Question about Blinkers going out
- Head scratcher
- A few window switches have gone bad - any ideas/solutions?
- stumped
- As low as she's going.....
- A/C troubleshooting help
- 94 ls400 headlights problem.
- 98 w/Nav - OEM CD Player Skipping & Freezes Up
- Picked up a 95 ls400 for my father in law
- No Response When key is turned to start - No Clicking
- slight slipping
- Officially 3gen ls 400 owner
- Just purchased A 93 Ls400-Help?
- Looking for Platinum Edition
- a little teaser :)
- Slow windshield wipers
- About to buy a 2000 "platinum edition"
- CARFAX report
- I am Dirty Octopus™ and this is my UCF10
- 98 LS400 Fuel Gauge?
- alternator woes 93 ls400
- 1990 LS 400 making an odd noise any advice?
- Two low pressure fittings for A/C ~ why?
- 95 totaled
- noob wheel fitment ??
- painting calipers
- '96 LS400 won't start
- Just picked up a 1991 LS400!
- Buying an 2000 ls 400
- How Low Can You Go???
- A sad day.
- Coilover question
- Ls400 96 fuel filter and distributor
- 90 ls transmission issues......
- Voltage appears to dip at idle
- Installed new caps, still a fuel gauge issue maybe???
- Remote Keyless locking system not working anymore...
- Tired battery or . . . ?
