- knock sensor wiring
- Anyone know? Fuse radio & clock memory
- Bulb out indicator
- some pix and exhaust video
- 20" axis milano+
- Buying a LS400??
- changing injectors
- Looking at buying a 90 LS400
- Forged Rods
- 1999 LS400 dies at stoplight
- HELP!!!!! please help!
- check engine light
- On the fence about purchasing a used LS400
- Really soft brakes any ideas (1993 LS400)
- 92 Ls400 Stays on!!!!!!(ACC)
- Another new owner? 1991! YAY!
- MKIV Supra Struts/shocks work on LS4?
- Options for a '90 LS400 with shot air suspension?
- changing water pump ls 400 1992
- Found where my coolant is leaking to but need more help
- power seat stopped working?
- Strange starting problem...
- weird gauge cluster problem
- Another overheating LS400 problem!
- 1994 LS400 Swap Options.. (tranny) maybe motor
- could your ls peelout?!
- Reverse Light
- *94 ls400 * kick down problem, won't accelerate...
- CA Wants Autos To Have Reflecting Windows
- Slight Problem
- Thought I'd share my alternator experience
- Radiator Fan is sounding like a big rig truck.
- Necessary to remove caliper to roll front fender?
- gen 2 brake upgrade
- UCF10 ALL red taillights instead of RCR's!?
- LS40 1st gen headlight questions
- A/C compressor front seal replacement
- Front Impact
- 1998 - Programming Remote Buttons
- What Motor Mount Parts Do I Need?
- Check engine light and traction control light are on at the same time
- speed governor
- Are buying cheap ignition coils from ebay recommended?
- 1993 Air conditioner "thunk" sound from inside dash!?!
- Exhaust Tips...
- Hi, new here.
- UFC20&21 Deisel Powerplants????
- Clicking in Rear? What could it be?
- What happens if the Camshaft Position Sensor goes bad?
- Question about timing belt change 98 LS400
- ADUS Strut rod bushings, questionable quality?
- Help Me ID This Valve ...90 LS
- quick help! headlamp wiring diagram.
- JIC Coilovers I Need to Sell -- NOW
- question re;Wheels on a 98LS400
- My 5.2L LS400
- headlight issue help....
- Best prices for AC parts?
- New 1993 LS400 Owner
- horse power potentials?
- How to add freon on a 99 LS400?
- UCF20 Warm Low Idle/Stall - easy workaround
- High Idle, not normal, stumped...
- motor experts... any suggestions?
- Warped brake rotors
- help! turnsignals light bulb
- Steering Damper...worth changing ????
- post pics of what size wheels and tires you have!!!
- Washed engine and now electrical going haywire and wont start!!! plz help!!!
- AC leak's out over 3 weeks. Evaporator?
- Rear Wheel looks like it is falling off!!
- lifting points on the LS?
- 1993 LS400 Steering Wheel wont move down! :(
- Pls Help-Need susp advice fast
- Creaking in front brakes resolved
- Problems after installing new stereo - 1997
- 93 LS w/ is300 or mazda wheels?
- Tranny Code
- Passenger seat belt problem HELP
- 1999 Lexus LS 400 fuel pump
- Too high idle with A/C on in gear
- New owner. Just bought my LS this past weekend.
- Oil leak?
- Coilovers, grille, muffler delete etc.. = almost done ;)
- NEW 93 LS400 owner w/ NEW IDLE PROBLEM!
- Rear axel 91 LS400
- UCF20 steering rack mount bushes?
- Rear Brake Sliders
- LS400 starter challange
- New problem
- Who has had to replace their EGR valve?
- P0340 - Camshaft Position Sensor Problem. Help !, Running out of options
- :::Aftermarket hub for 1991 LS400?:::
- Heated seats not working
- Planning on getting a new exhaust system, need advice
- Remote Lock/Unlock - How to increase range?
- Popping or clunking sound from rear
- antenna alternatives?
- safe to drive with knock sensor error 52?
- Frankensteining LS400's
- trunk leak!
- Cracked woodgrain wheel repair
- Recent front conversions? I've searched
- Theft Deterrent System Problem
- Yokohama S. Drive tires
- White 92 LS with GOLD Sportmax 962's
- LED DRLs need module?
- UCF10 OEM add on lip/skirts?
- Help LED Strip wiring
- Factory Muffler enhancement. Pics inside.
- 98 LS400 Check Engine Light
- 1996 LS400 Suspension Questions!!
- 2000 w/ Nak wiring diagram/pinouts
- Rear Drop in Normal Mode
- Problem with a 92 LS
- installing megans
- newbie introduction!
- 94 LS overheating, yes i searched.
- Changed fuel filter, learn from my mistakes
- Electrical Issues on 95 LS400
- 98 LS400 break wear light just came on .
- Curious....swap no not the 2jz
- Car is GREAT on hwy but TERRIBLE in city?
- '93 ls for sale with 13,000 miles
- Looking for engine for 95 Ls400
- Had to put my spare tire on. Glad I don't have to drive like this for a long time
- LS400 taillamp failure
- give your thoughts
- Help ID'ing 92 Dealer Option Wheels
- New Owner 1992 Ls400
- My A/C Journey - 91 LS400
- 98LS400 starter replacement ALMOST went flawlessly
- New Lexus Owner. 92. Intro + Power Steering.
- About to Check Out a 90 LS Got A Few Questions
- Ksport Airtech Air Suspension system
- Turn on headlights and Reverse light comes on
- Replacing 93 LS400 Nakamichi with after market radio
- Which NGK plug to use in a 99 LS? 3764 or 4589?
- Top Gear Features a Lexus LS 400
- Megan Coilover settings
- Center Instrument console controls
- LS400lifes LS #392 rare!
- Springs in seat worn out.. Any suggestions?
- Rear Half Shaft DIY
- Just picked up my long-awaited LS400!
- No radio 99 LS400!!
- Ok ,my 98 ls400 starter is finally limping on it's last leg .Quick question
- Just bought a new 98 LS400...have some questions.
- Anyone tried SDSTOYO AUX Input?
- Slow accelaration, 0-100kph (0-62mph) in 10.3 seconds
- seat problem...
- Popping sound front brakes-maybe??
- 12v power behind glovebox?
- Do I Need An Alignment?
- Brake Caliper Sliders
- Need to change catalytic converter for LS400,1996
- Charging / AC Problem...Need Help!!!
- a lone pic night with 2 slightly modded LS400s. 56k warning.
- speedometer troubles
- 99 LS400 Headlight HID bulb replace
- Received my poly strut rod bushings today for 1LS.
- 2000 Tool Kit Question
- Need help with OEM part number !
- Egged LS400
- 93 ls acting crazy!!! help
- 93 Steering Rack Boot
- Car overheats with air conditioner on
- where can i get...?
- New tension rods on a 1998 with 80k ?
- Two interior noises-GOING CRAZY!!!!!!!!!!!
- LS400 started as a gauge cluster problem now it wont start.
- cant find the low pressure air conditioning port on my 91 ls400
- need some help
- blower motor bad?
- Suspension Install Tips
- Cutting Rear Bumper For Mufflers
- "R" light stays on when headlights turned on
- For sale items go in classifieds only please, not here
- UCF11 (1993-1994) - Door Moulding/Trim
- Need to Replace leather console cover. 95 LS
- Ignition question for UCF10
- AC condensor fan want turn on
- Air-con sorted
- UCF21 Stock Air Suspension??
- Replacement Leather = side airbag problems?
- UCF21 Shift Knob thread size.
- AC/condenser fans questions!
- Considering upgrading to UCF 21...
- timing belt question
- Replace Fuel Injectors how often?
- Help finding Wiring Harness
- rear axles out
- Suspension question and which year to buy 96 97 or 98
- 1992 ls 400 noobie got question can anyone help??
- My 1995 Lexus LS400 (56k take a nap)
- 98-00 ls steering wheel
- Fun with Starter Replacement - 96 LS 400
- help power steeing not working
- UCF20 teaser pic
- Tire problem
- ~Info needed on 2JZGTE in an LS400~
- Low pressure air conditioning port on 1996 LS?
- Rear Differential Problem
- Possible transmission problem? ('91 w/187K)
- Help needed no power when in gear '94
- Coilover install, anyone has it documented?
- Progressive Foam Bump Stops
- removing shift knob on 98 LS400
- Air suspension (UAS) installation on my 97 LS400
- My new addition, 99 ls400
- Tyre choice
- Does Minor Leak in Steering Rack and Pinion Matter
- Headlight adjustment
- Preparing for a small road trip
- Is-f
- transmission fluid leak
- 96 ls400(*help*)dead shocks(need help)
- Retrieving Airbag codes from a 1991 LS 400
- Opportunity to buy a 96 1UZFE for cheap...
- How to test sending unit and gauge
- 2 questions about a 99 LS4
- installing side airbags on a 1996
- Bilstein Air Suspension
- 94 model wiring on sending unit
- still feel engine running
- Heater problem
- Radio Problem
- Think it's time to introduce my car, a -94 LS400 (UCF11)
- Looking to purchase my first LS
- Anyone know what year LS this is?
- Renewing 98-00 Headlight At Low $$ // DIY // Photos inside
- Bendable Curtain Tracks
- How my Ls40092 to Last gen.
- Question for the Experts....
- strange electrical happenings on my 92ls
- Projectors
- UCF20 LS400 - Complete bush kit?
- Body Parts
- Just picked up a 96 LS400
- Ecm location on a 1992 ls 400
- 90 LS400 Center cap
- Transmission Hell :(
- Front Dash removal (help meeeeeee) '92
- 1993 ls400 poor acceleration
- Brake wear sensor.
- Looking to buy my first Lexus, is this a fair price? Pictures included
- Which springs
- Buying my first LS400
