- P1349 Bank 1b = OCV replacement question
- GS430 hesitation need help
- master cylinder cap
- Steering Intermediate Shaft TSB
- qwik motor mount change
- 2003 GS300 Audio and Headunit help.
- clunking problem solved
- Take a look at this disgrace :/
- AC Light Flashing, Compressor Not Kicking On
- 98 lexus gs 400
- Help me ID these wheels
- My Nav hard drive gave up working
- anyone got specs on factory sub?
- Advice on intake alternatives to SRT
- e-shift problem
- Experiences with Sarona.com?
- How much
- 2001 GS300 Wiring help please!
- Door locking issues
- Lighting Differences?
- Door lock question...
- Vibrations and Antenna question
- Sorry 01 gs430 doing 2jz swap
- Lexus GS Indash 10.1 tablet DIY
- How much to pay for an 02 gs300 sport design
- 2002 Gs 300 sport design edition. Possible purchase.
- 2002 GS300 transmission pan service
- Tire Recommendation: GS300
- Seat swap
- Clear tail lights
- IS300 HPS air intake pipe on GS300
- New Lexus Owner.. New project..
- Quick trunk question!
- 3UZ-FE Power Steering pump help
- 02 GS300 Ultra racing Strut bar wont fit?????
- Reinforcement, rear bumper - size
- Dear lord I fixed my clunk after 5 years!!
- Seat Covers
- Gs300
- Brembo Pads & Rotors
- Help: Intermittent P0171 Code
- gear selector won't shift
- Replacement HID's
- custom trunk setup
- Lexus GS300 2003 Power steering squeaking noise
- Is there legal headers for 2nd gen gs3?
- 2jzgte
- Suspension
- changed throttle body now not sure what happened....
- 99 GS400 Navigation Update
- Code p1349
- Location of Oxygen Sensor - Bank 2, Sensor 1
- shaking rack sound?
- No engine power to wheels after replacing alternator
- 20w50 oil for gs300 in Dubai
- Aristo swap fuel gauge issue!
- Help! Need Identification of Engine Parts in a 2001 GS 300
- Help! please! 2jzgte swap, stuck!
- Funny engine noise- video included! :D
- Just bought a gs with a couple issues..
- want to buy GS300 need info about the car
- Is this worth it?
- Need help on the transmission cool lines
- Tire Size: Advice Needed
- GS430 - Trans/flywheel/Torque converter issue??
- Door Lock Actuator Questions
- 01 GS 300 oem rear strut mount needed asap
- Converting stock D2r hid to aftermarket H7 hid
- Aftermarket actuators
- Auto low beam function European and US car difference
- Stock Pioneer upgraded to Nakamichi
- Need a few questions answer on front uca and iforged aeros
- TX2k16 - Who is attending?
- 1999 GS300 Door issue
- What is this actuator-y thing making noise?
- Front bumper repair help
- Oil Pump Leaking?
- Intermittent rough idling - Help appreciated
- headlight problem GS430
- Unique problem...
- GS430 or GS400 for Dependability, not power
- Knock sensor codes P0325 and P0330
- Fukuoka car show...new headlights?
- Importing a body kit
- Gas hand doesn't go back to full
- I need help!!!!!!!!!!!
- Ball joint options
- I'm not tripping...
- 430s vs new 350s
- Help replacing a tail light
- Fog Light Mod gone wrong
- P0430 - When is it really the cats?
- Electronic seats moving position and self ajustable sterring wheel
- Do I trust local gas station to do timing belt?
- Trunk shock options?
- Will 19 inch rims rub?
- Aftermarket air intake suggestions??
- Transmission
- Who has the better gas when it comes to gas stations?
- 2nd Gen GS300 Seatbelt Removal & Winding How To
- GS400 won't start off and on.
- Maintenance Musts on a newly acquired 2000 GS400
- 03' GS300 stalls after filling up gas
- Convert Nav 98-00 to 01-05
- Hood Latch Sticking
- Best oil for Lexus
- Back-up camera Install HELP
- Fwd or Rwd?
- Lexus Maintenance
- Can some one check the coolant overflow
- Tail lights won't turn on?
- rear tail lamp warning light won't shut off
- Gs400 p1351, p1354, p1351p
- How do you hold your hood up
- Tom's Side Skirts + TTE Lip
- Oil Leak GS430
- Tail light
- Towing
- Noob Radio Question
- Spoke with RRRacing about tune for our cars
- How much my car worth now?
- GS400 purchase with 235k
- Oil leak from bank 2 OCV?
- Getting lowered car in spec? (camber)
- LA GS400 owners with tanabe touring exhaust
- Omg !!!!!!!!!!!!!!!!!!!!!
- First time Lexus buyer
- Can a 01-up is300 ac compressor fit and function in a 99 gs300?
- Help with Rotors/LS400
- P0305 in 2001 GS430
- P0440 Possible Cause / gas smell
- Does anyone have a recent feedback on CXRacing?
- I want to know what car is better, gs400 or es330?
- Gas smell outside car, passenger side tear door.
- 2002 lexus gs vsc/vsc off engine light on codes P0300 p0301 p0303 p0305
- Brake rotors easy??
- Repair Manual Available?
- Interior modifications
- Keep Footwell Lights On
- What is this part called and what does it do?
- Clear side markers
- GS400 Engine Noise after Cam Seal Replacement
- Motor mount installation on GS430
- Little photoshoot before going back to stock
- Post for sale item in Classifieds Only
- New Exhaust tips
- Where to get or who makes rear control arm bushings (rubber)?
- Upper Control Arm Replacement Cycle?
- Starter Replacement Problem (98 GS400)
- Odd buzzing/vibration sound somewhere in the dash
- fuel cap not completely tight. Check engine light on.
- Catalytic converter
- Code B1266, causing other problems?
- fog light problem
- Tire size opinions
- Anyone running this wheel size19x10.5 +13 and 19x11.5 +13 rear
- Gs300 won't start
- What Transmission Is In My 1999 GS300
- What/Where is the fuse
- Need help with air ride setup
- Heavy engine fumes in cabin.
- 2jz gte vvti, 98 aristo questions....
- horrible grinding sound when i move
- GS400 starts,misfires,dies..not always.
- Wheel fitment suggestions with BBK
- Help with fuel/ecu issue
- Crystal clear & LOUD aux mod for stock sound system!DIY!
- anyone using 15mm H&R 30656014 DRS TRAK+ Wheel Spacers? their site says...
- Best way to get usb/iPhone music capability 04 levinson? Did some searching but....
- When is the right time to sell/trade-in my GS?
- Rain guards and rear spoiler.
- Switching 19s to 18s.Tire size help!!
- Weird Throttle Response
- Tail/parking light fuse keeps blowing
- 2nd Gen service manual acquisition
- P0155 Sensor change
- Can anyone get me the tape cassette wiring color codes
- gs430 shakes at 80 mph
- Gs400/430 High stall torque converter drivability
- front license plate : what r u guys sporting nowadays
- Please help brothers
- First mods to a '98 GS400
- About the headlights
- OEM aristo/gs300 wing mounts
- Help, No engine management light/won't start??
- Seatbelts q
- Looking for pics of Lexus GS with these IS350 wheels, anyone have any?
- New Member Long time lurker
- Door locks when put into drive.
- cam bearing cap removal gs400 need info
- Brighter immobilizer light
- New to Site
- Advise please
- question about 19x9.5 +35 in front on 2004 GS300
- Is Dexron III correct for steering fluid? PS cap says ATF type dexron II or dexron
- 2000 gs300 na-t
- Gen 2 instrument cluster.
- Help leaking from ceiling
- electrical gremlins
- OBD 2 Software
- Any decent GS300's for sale in the STL area?
- 2nd Gen GS LSX Swap Oil Pan Options???
- Wont Start On 1st Turn of Key
- Gs300 anybody else have this color
- codes
- help - trying to smog & getting cat readiness indicator to clear
- JP Grille insert Installation help
- my new exhaust
- Winter driving tip GS40/430
- Weird noises coming from behind my steering wheel
- Loud knocking sound only below 1000rpms (vid clip)
- Stock stereo differences - regular vs. Mark Levinson
- Oil pressure light stays on a little too long
- Idle issues when hot
- Please help vacuum lines
- Poor gas mileage on 03 GS300...
- Griots orbital
- Can I change steering wheel/airbag assembly 1999 to 2000 GS300?
- Headlight condensation
- After Market Headunit Installation Help
- P1354 Oil Control Valve Code - Free Fix - Worked for me.
- High beam question
- Anyone ever used BBS RK on a 2GS
- Does Anyone Makea 45mm Hubcentric Wheel Spacer?
- GS With Sport Shift Pinout
- Complete Front Suspension Kit
- Where do you think this leak is coming from. Engine Pic.
- Rear window flex & 15 inch sub
- Please help my car won't start
- Power Steering Solenoid
- GS300 brake replacement and rear brakes "scraping" noise
- VSC and Check Engine light came on as I was driving home
- Will a 1999 GS300 Steering Wheel Fit A 2000 GS300?
- Dont know why Moonroof is stuck.
- Oxygen Sensor
- Need help with O2 sensor
- Un-Pairing Homelink
- Where is the Camshaft sensor located
- Valve cover gasket replacement DIY? (GS400)
- Tire leaks air but no nail...
- Is the catback exhaust the same for 300s and 430s?
- Need help with wheel fitment
- Telephone transceiver and speaker relay
- Sun visor options
- hey guys!2001 lexus GS430 service repair manual
- 2000 GS300 RPMs on Highway??
- Lexus gs300 1998 be rev limiter wiring
- Instument cluster dark
- Job Design
