- Front Marker light poll
- 2002 GS300 clunking when braking
- ABS sensor
- suggestions for 18"x8" or 19"x8" wheels for my 2002 GS430
- 2000 GS300 Cinnabar peral with black interior 74,000mi/118,000km
- Pics - Finally got around to detailing my Black GS4
- A Thread about Turbo'd Engine Mileage
- New to Lexus, where to start?
- Water Pump and Timing Belt Change Out
- Gs430 4.3 motor in a gs400????
- Best AUX Input Mod; Radio Antenna Alternatives
- Where is the Mark Levinson Amplifier in a 2001 GS430?
- vent visors
- HELP!!! Unknown piece!! after removing headliner
- Roof Spoiler that flows with RMM 3 piece Spoiler
- Bluetooth Aux and Hands-Free Calling Additions
- Help p0763 >=[
- JZS161 Veilside hood questions
- Where is an aristo fuel pump assembly in the states?
- Adding AUX port
- Need Spanner wrenches for my Megan Coils. Is there a size?
- creaking noise from front end
- Im back in a 2GS again! 2003 Black Onyx GS300 Sport Design
- Where to mount sub in boot without drilling into fuel tank?
- A/C Sound, Code 41 & 43
- What is this for?
- Need help asap guys, cars stuck in the middle of my street lol
- GS500, 1GZ-FE swap GZS160
- Tool Size for Timing Belt Tensioner
- Battery check/service/terminals cleaning
- Exhaust question, Y-pipe and cat replacement
- Timing belt was changed, but not the pulleys...
- Help! Gs300 aristo swap
- Radiator change
- Someone try the HID Quick Start Kit for High Beam
- Options For Key - No Master Key!
- Noise coming from front end/engine compartment
- Do i need ecu changed ??
- Significant changes to 01 and 05 GS430?
- New To The Gs Life - Car cranks but no start, anti theft issue?
- 2003 lexus gs300 doors + gauges
- Wheres the OG's at?
- CEL P0446 Keeps turning on and off.
- I must have the wood grain
- Can i swap ECU's with other years?
- anybody know this car, white gs400 currently fs in Arlington
- GS300 trunk liner removal??
- one more ac question...maybe not servo related...
- cup holder divider headache...
- Looking to buy 2ng gen GS300
- anyone know what this front bumper and splitter are
- Oil and Transmission Leakage
- where is the schrader valve on 1999 gs 300 Thank you!!
- Having trouble removing manifold. 2002 GS 300
- My JDM Power Folding Mirrors Install with wiring + motor repair
- Long time no post
- Roof spoiler
- Winter Tires
- I broke my navi painting the faceplate
- DashBoard, Speedometer, Fuel Gauge ALL OFF
- Car starts then dies...sluggish throttle response GS400
- forced sunroof closed....now it wont open
- Need help with audio noise!!!
- Trunk hydraulic lifts
- SRT Air Filter Question
- VSC & ABS Lights, BMC, Speedometer and Odometer Issues
- M45 retrofit Projector headlights woth it?
- Mark Levinson Amplifier Compatability
- Anyone painted navi/radio faceplate
- No heat on driver side, heat cools down when driving...
- driver door window went down and is now stuck
- Need help finding a part
- Grrr.....hit from behind by a Yaris
- How to remove front fender??
- 98 GS300 Engine replacement with 04 GS300 engine
- Rear Dif Bushing
- Sales allowed in classifieds only.
- HID Retrofit help
- Anyone have a how-to for passenger side rear door lock actuator replacement?
- vvti pulley repair - does timing belt need to be removed?
- Aftermarket Lense and bezel swap to OEM Headlight
- Anyone here using car covers?
- TTE Lip install with speed nut and bolts...
- Steering wheel hard to turn
- Scraping in hard corners after rotor replacement?
- Alarm Problem
- Rear Squeaking sounds
- Cheap AUX input and more!!!
- Recommened Tyre Size For 18"x8 Wheel
- Does anyone sell OEM looking center caps for aftermarket wheels?
- Wobbles in Reverse
- Boiling coolant and overflow reservoir
- Need help!!! with codes p0420, p0430,p1345,p1350 and more!!!!!
- AC Blower motor gets stuck
- Not mine, just wanted to share this CL post...
- Gs300 repair
- Newbie and crank bolt idea
- Broke College Student and Expensive Car Repairs
- 01 GS430 DRL High Beams not working
- Another reason why were 2g kings
- Aftermarket headlight problems :(
- GS300 battery light staying on
- I'm looking to buy a 2JZ-GTE swapped GS300 tomorrow and I need help
- My 1998 aristo v300 vertex
- Looking for Lexus GS430 SRT Intake
- Front bumper/Lip identification
- Stored Gs400..first start up question?
- any guess on my hp?
- Help - GS300 2003 A/C only blows out of defrost vents
- Where to get a PCM?
- The Mask Man wants to say hello to Clublexus. New Mods!
- Finally got a 2000 GS400 but it needs a new gas floater.
- Heated seats stopped working? Shorted out?
- Someone hit my car and kept going, fender damage any ideas(Price, what route to take)
- New SSR Vienna test fit
- Kicker sub thoughts
- Clock, radio climate control dont work and cant get out of park!
- My First GS430
- Replaced Battery, NO INTERIOR POWER
- Some new mods
- Car starts and immediately dies after replacing accelerator pedal position sensor.
- Best Repair Manual for GS
- The Trunk Release Lever Broke
- This was stuck on my Carpet!!!!
- VSC, Trac Off, CEL Lights + Limp Mode - Help!
- *GS300 drifting* Thought the 2GS community would like to see this!
- GS300 - Who Has The Final Answer Why These Loose Power?
- Single popping noise everytime I hit the brakes
- Tte lip problem
- Car sometimes won't start. All dash lights go out. But its not battery or Alternator
- Need a GS expert near Schaumburg, IL
- Replaced battery, now no power whatsoever **PLZ HALP
- 18 inch 2nd gen Scion Tc wheels on a gs300????
- Failed smog
- AC Doesn't work properly.
- Would these fit
- ECU flashing in a GS300
- headers?
- CEL after installing k&n FIPK
- 1 Crazy month later I Finally got my 01 gs300
- How to replace 120 amp alt fuse?
- Cluster swapp for e-shift
- Good Deal?
- BMC swap question
- Once you go black...
- Instrument Bezel scratch remove
- Electrical issues
- Calibrate servos
- Radiator Replacement
- Opinions on bubbling roof!
- Passenger door will not open properly
- Good quality car cover??
- Thats what happens when you check 2 positions on timing instead 3
- AC Not working
- my new/old gs4 blk on blk (bb)... take a look!!
- GE/GTE- Orange-Grey Plug Wiring
- Aftermarket radio help
- Will these wheels fit on my GS300? Help please
- Gs 430
- Found a 99GS400 with 47K, Dealer wants $8,600...what to do?
- Car charger dead?
- TT calipers and stock 17s
- Ive been out of the Lex game for awhile.. Whats 2000 GS400 with 36k worth!?
- Morimoto HID Bulb and LED Install
- Bulb type for transmission indicator bulb
- White smoke from engine bay
- Fuel pump brand....
- 2000 GS300 wont stay running
- 2000 GS 300 steering wheel swap to wood grain
- Aftermarket steering wheel hub
- I need help r
- Loss of power and management light on
- Should I remove my badges??
- 2nd Gen Gs300 F sport grill
- P0171. Noooooooo. Help me.
- GS300 power steering problem. Please read!
- Anyone know what this sound is?
- Will Depo lenses fit on OEM housing?
- EML, VSC, VSC OFF lights on, HELP!
- New taillight question
- How to reset ABS ECU after MC replacement?
- Louder rumbling noise during low speed acceleration
- new owner of a 99 cinnabar pearl gs4
- Car doesn't respond to keys anymore?
- Any things I should know? Bro is picking up 01 GS300 w/ 83K miles
- Misfire on Cyl 2,4,&6. Cylinders filled with oil.
- Oil Pan Leak on GS430 and Acceleration hesitation
- Car won't start after fueling
- Aluminium radiator for a GS300?
- Testing fuel pump and the other gas tank sensor while off car?
- Something very strange happening with my 2002 GS300
- Aftermarket Heated Seats
- WALD Lip Lit install @ a stand still
- 1999 gs400 gauge cluster
- What is this module?
- New wheels!
- Totally stumped on this one? Drive shaft wont go back in
- After market HIDs
- Removing hood
- Odd starting problems after my last "starter replacement" thread anyone chime in? Thx
- JDM or Europe headlights?
- Adding some height to the Rear
- For canadians, price check on JZS161 Aristo with repairs needed
- Brand New 19/20 Inch Wheels, for under 700$ Possible?
- Help! Tansmission and idle issues
- anyone have gold emblems and trim?? photoshop
- Vibes on 3 Sets of Wheels
- GS300/GS400 rear axle replacement (difficulty level)
- quick release and hub
- Resonator Delete on a 2Gs300
- Need help with a starting issue
- Why I won't run a K&N or other oil wetted filter
- New to second gens! LED tail brands?
- Depo Tail Light question
- P0325 Knock Sensor parts?
- A/C Hot Air, not refrigerant or compressor
- Looking to make my 2003 gs300 meaner
- Having problems
- Battery drain because of unplugen rear door locks?
- Hub Centric Rings Needed???? Please Help!!!
- 3rd oil change (long drains) with oil analysis GS400
- GS400 speedometer working intermittently- Help Appreciated.
- Tune up....
- my new look
- Catalytic converter and p430 Question.
- Fuel pump control module blues
- front map light broke
- Spongey Brakes after bleeding
- Will these fit?
- 20 inch MRR-HR3 (20x8.5)
- Timing belt replacement at 60K, not 90K?
- 2000 GS300 occasional clicking from engine bay
- Salvage yard goodies
- Post a pic... Exhuast system need ideas
- Center front speaker on 2002 GS300 with ML sound
- 98 gs won't accelerate and hmm noise
- Nav problems First post
- Aristo!!
- my steering wheel not turning tires!!
- How much should it cost to repaint the front of a car?
- Going in for paint, need opinions...
- GS300 didn't start this morning, maybe bad battery?
- Front transmission seal keeps blowing
- 2002 GS 430 engine problems
- GS 430 motor blown
- Lexus Gs300 brake booster failure. Dealer wants $3k!
- Rear View Camera
- Picked up this clean Gs few weeks ago!, Just with 91,xxx miles
- 2001 GS 300 Air mix part number
- Recurrent rear main seal leak
