- OEM side skirts for 2001 Mystic Sea Opalescent GS300
- 12V source
- 225/50/17 on stock 17's?
- car was broken into, nothing stolen
- New to Forums!!
- My Nexus 7 Install
- Driver window control doesnt work
- 98 GS400 Hard Starting Issue
- 98 gs400 passenger door won't lock
- 2002 gs430 ac problem need help
- My old and new gs400 engine
- where to buy tan leather paint
- Bagged the gs
- Need Help with wih ABS Codes C0226, C0236, C0246, C1223
- New to forum!
- steering wheel airbag question
- Fog light LED DRLs
- P0430 code; how to approach
- 98 GS300 - routine maintenance (plug change)
- Something Wicked This Way Comes...
- 2001 Lexus gs300 does not acceleration properly CEL p1349,p1656
- Has anyone changed the turn signal mirrors leds?
- 2JZGE vvt-i only interference engine when vvt-i activated?
- New to the Gs forum
- Any write-ups/diy for cam seal replacement?
- Inner tie rod lock washer issue
- Replacing headlight lens only
- Leak from cams?? New to forum and lexus
- VVTi GS400, in need of MAF pigtail schematic
- Oil leak question URGENT
- LED Signal Rapid Flash
- Brake system wiring
- Stealth Sub Box for 2GS?
- Need a new CAT I think
- Rear Suspension 'popping'
- 18x9.5 et 22 and TT calipers
- HID and Auto leveling aftermarket headlights
- 1198 GS 400 17" Chrome Rims - slow air leak from corrosion
- looking to buy a GS400?
- How do I fix these issues on my gs430
- Bee*R~~ (HELP PLS!!!)
- downpipe for aristo swap
- Is a factory trans swap plug and play?
- steering rack questions..
- Is it worth it to fix 2001 GS300 Front End Damage
- New GS430 purchase!
- Help on the location of an oil leak guys
- Fuel Filter Orings
- jdm climate control panel wiring
- New Fenders for the GS! (Finally!)
- Alternator issues
- Headlight Wiring Diagram
- Possible wrong ECU?
- ideas for go-pro placement in the gs
- Still have P1354, replaced OCV
- FS and WTB threads go in the classifieds
- Loud noise when braking and I mean LOUD
- Noise When Making a Hard Turn
- Key fob ?
- Funny video of GS4 vs S2000
- 2jz-gte swap questions
- Disable interior lights
- Can't open 98 GS trunk
- Lexus GS300...worth it?
- New Look
- Need help from someone with factory spoiler
- Replaced VVT and Timing Belt..car wont run now?
- wierd navi screen\gps problem. what could it be?
- 2nd gen gs tech in the dmv area
- Thinking of Getting another GS300
- Traction Control light W/ Soft Breaking
- DTC Code P0440 Repair Video/Link
- Foglight Rewire
- Slipping when accelerating
- 99 gs400 engine
- sensors in the grill 01gs430
- Gs430 with 2jzgte swap speedo issues
- Cleaning engine after leaky valve cover gasket
- Show me your drop!
- driver HID headlight operates for 30 seconds before turning off
- Evap not ready,bad fuel pressure sensor?
- Louder?
- Interior swap
- Rear License Plate fastening
- Help ! 1999 Lexus Gs400
- 2jz-ge Question!
- Need help with 99 gs300
- My buddy's GS ...
- Best "mode" to drive in
- aftermarket deck with stock navi!
- Take out cat converters?
- Just steamed cleaned the engine, now is f***d
- E-brake / Handbrake light staying on.
- Strange Noise Coming From The Front Of My GS
- JZS160 and GS300 Compatibility?
- lowering rims and camber kit?
- Non modified body/stock suspension
- Negative caster after alignment?
- ABS Sensor/Engine Harness
- Local CL Meets?
- Used Muffler on Ebay?
- There is no aftermarket sub+amp with stock headunit install thread
- Has anyone used these brembo rotors or pads?
- Air intake
- Moog EV80600 Tie Rod Needs To Be Greased?
- Just got her out for the spring!
- fuel pump return question
- Questions about electrical mods
- Step By Step...Removing Steering Wheel on 2GS
- 945 Garage: 4 Door Hero Kit
- 2001 GS 300 Need Help
- 2jzge
- Morimoto XB H.I.D Write Up
- 2000 Gs 300 hesitation
- 99 GS300 Aristo Swap
- Sunroof Motor
- Does this seem like a good deal?
- Dual Alternator Setup
- Help on correct lug nuts? Beveled or flat?
- paint matched grill pics??? white
- My GS' First Check Engine Light
- Weird Reverse
- Also popping noise, spent money, no fix
- Serpentine tensioner
- light polish+meguiars wax turned my paint into glass
- 1999 GS300 Radiator Fan Issue
- Xenon in Fog Lights?
- Will a 2003 auto is300 lsd rear end bolt up with a 1999 lexus gs300
- Climate control issues
- Immobilizer Problem Anti-Theft won't let me start car
- 2nd gen gs430 or 3rd gen gs350?
- Warning light issue
- Anti-theft not turning off wont start car please help!
- Tail light failure with a twist!
- Aftermarket front bumper?
- power restrictions Gs 300
- What should I look for when buying a gs?
- Where did you mount your AMP
- Escort 8500
- Moving on from my GS300
- Lifespan of a GS300?
- Battery died & now the a/c isn't working all of a sudden
- 02 GS300 What do these codes mean?
- 02 GS300 How do I remove the emerg trunk release
- High speed clicking (not brake booster)
- Beginner Project Advice
- Desperate! Car wont hold charge!!!
- weird lawnmower jet engine sound when letting off gas!
- inner tire wear and noise when turning
- Anti theft mechanism problem please help!
- Starting problem
- curb weight of 2 gs
- ichiba wheel spacer question
- A/C problems
- Strange and haunting electrical issue
- 99 GS400 engine, what CAN cause limp mode?
- 18" offsets work?
- Anyone ever see these infiniti wheels on a 2GS?
- Can I fit 245/50-16 on the stockies?
- heating issue
- Does anyone actually own a saddle interior GS?
- Freaking headlight problem, car look possesed.
- Aftermarket ballast?
- CV Driveshaft Question
- Tape deck problems
- HELP? aftermarket radio connect factory sub-woofer.
- Bigty / Liberty / Mod Parfume
- to Jeff Tsai / anyone that can help
- My new 03 GS430
- Someone have OBD II Problem before
- quick shots of my gs300
- P0140 o2 sensor
- rlca bolts and strut bolts
- Can't get belt tensioner off on 2001 GS430, help please
- Not sure if this belongs here
- Trying to remove bumper, bumper bolts are spinning!
- Lexus GS430 steering wheel.
- Another Steering wheel shaking thread...
- Going to install a whole new sound system 98 Nak
- 2001 Lexus gs300
- Are these parts useful to GTE swappers?
- Best New Synthetic Oil
- Replaced lock actuator and now keyless entry doesn't work
- Clicking Noise
- Offset and tire question.
- Swapped gs300 Ac question.
- Fog Light Question
- My car got featured on PASmag
- VIN check
- Hazard lights and climate control lights
- put in battery backwards :( Consequences?
- Door Acualtor Help!
- Good replacement washer nozzles
- How to replace windshield on GS?
- Needs Help!!!
- Please Help! Power Steering Problems!?
- is my car clearcoated?! no black on my cloth after polish
- Refresher on the Steering Shaft (U-Joint / Bushing) Clunk
- Thoughts on high mileage GS300
- VSC and ABS problems
- Electronic Conundrum
- Tire dilemma please help!
- Double sided tape Wings and Spoilers
- fs goes in classifieds please
- Procedure for replacing tensioner and idler pulleys on GS430?
- Can anyone Identify this rear lip kit?
- Broke my Fuel Vapor Feed pipe.. HELP
- Help with wheels
- shaving wheel hub to change offsets?
- 1/10 Scale HPI Sprint 2 Mini Me
- Almost Trded it in, Glad I Didn't
- Need to replace indicator bulbs
- Mirror project, this is possible right?
- Next mod
- Aristo Fogs fit?
- 2003 GS430 - Check Engine, VSC Off, VSC Lights on - Surprising Cause
- Loads of Codes.
- headlights: why is one white and the other blue?
- Will it fit on the rear: 19x12 49mm with 305-30-19
- GS400 Surf Rack
- 98-00 gs300 master cylinder pressure sensor
- fuel pump pressure test
- Where to buy this piece..
- Bye Bye GS400!
- No abs.....no abs light either...??
- 02 GS Horrible idle.Misfires. Changed plugs, wires, coils. HELP!!
- Brakes Grab hard at front driver side... no spongy pedal
- Ignition coils going bad? Fuel injectors?
- Lurch at low speeds
- GS300 open OBX headers
- LS430 wheels on my 2GS
- Highway Shake
- Should I buy 2002 GS300 Sport Design
- Wow! Very odd electrical problem, whole car shorting out.
- FS wtb wtt threads belong in classifieds only
- new alternator, same problem. maybe its time for a new car?
- Charcoal Canister part number question
- Trying something different with my fogs
- Replace stock radio with aftermarket
- Painting front bumper
- p0174,p0174,p0133,p0153,p0430
- Accessory Connection
- Freak knock sensor relate issue
- Should I tackle DIY timing belt. Just replaced the starter.
- Master cylinder pressure sensor
- Transmission Fluid Help???
- Head unit power supply
- Three blink turn signal
- Gs400 throttle lever
- Radio Display
