- For those who changed their Engine Coolant Sensor..
- Is this a good deal on Rims for $800
- Like GS430 MORE than LS430 - but I'm too tall!
- Opinions on 2011 RX350 19's
- Paint for leather, help pls
- How do I replace bulb in 3rd brake light?
- This seems legit...
- what rims are these?
- need help ASAP with key problem
- Another I'm back thread
- Low oil pressure light cause?
- Springfest in virginia!!
- Headlight auto leveler indicator question?
- Rear lock Actuator :'(
- 1999 lexus gs400 help with motor mounts
- New sub for decklid
- Aristo swap
- Where to buy clear VVTI Cam Gear Cover?
- NEw to the Lexus game
- Driver side power window does not roll up...help!!
- WTB, WTT and FS posts go into classifieds forum once eligibility is reached.
- See you soon clublexus
- Programming the Pioneer Audio DSP - Factory Settings
- Need a favor...Can someone please help?
- 2jzge valve replacement ??
- Just installed Mechman Alternator, Battery Light comes on now
- '99 GS300 APP sensor output curve OK?
- 99 gs 300 keeps dying help please
- What tool holds the harmonic damper still during install?
- 99 Lexus GS400 compressor. . extra plug
- Lexus GS 300 HELP?
- NEED HELP on my 1999 lexus gs400 P0441
- transmission oil cooler hose from radiator?
- Just Bought Tanabe Dfs
- P1346 and P1351. is it always a timing belt?
- Is my starter on it's way out...
- Are The GS300 Headlamps Adjustable?
- Need advice regarding price/quality GS300
- Headlight restoration, anyone tried this way??
- suggestion tires for my 18's?
- Evaporative Emissions Code P0440 From Hell
- Knocking sound when idle in the engine bay
- Just bought a GS300 250k Miles, need help
- Trunk amp setup
- Gs 430 2nd gen replacement
- What Tires
- Need serious help!
- Po 125 and Engine coolant sensor
- will 1st gen jdm cloth half seat covers fit 2nd gen
- Non-HID headlight bulb replacement
- Lower Drivers Door Molding
- Rust Spot
- New Member . . .
- Enkei RPF1 Anyone?
- Issue w/ fuel.. parts list...anything am I missing?
- Opinions: Is worth getting (2000 -2002) GS300 with 250k+ kilometers ?
- How To Test A Radio?
- considering ls swap anybody know of any shops in Tx preferably in the dfw area
- Brake fluid bleeding help needed
- Passenger brake light not lighting up/ failed inspection
- new member with fresh gs300
- New Member with a GS300
- Blitz throttle controller PLEASE HELP
- 1999 Lexus GS 300 error code P0125
- Fender rolling on 18's?
- Specific Rim/Wheel Questions for my 2003 GS430
- Quick Question On Sparkplugs
- change spark plugs now misfire..
- Rear dor lock actuator
- Gs400 taking longer to start
- Age of tires on average when purchased new
- 2001 Lexus GS430 Cam Position sensor location?
- help, dash lights don't work
- Passenger mirror?
- Fuel Pump Question
- Need some help car has been dead a while
- gs wont start... new motor
- OEM engine mounts vs Megan racing's
- Door lock problem.
- A/C won't run automatic
- Help- Coolant leaking... but from where???
- Need some advice..
- P1349 on GS400
- My Aristo Vertex Edition...finally an intro thread
- Help~ Thinking to Fit a Standard IS350 18" wheels on 2nd Gen GS300
- Paint Job Suggestions?
- HID ballast not working in socket?
- 98 GS300 Idling and Starting Issue, list of new parts
- modification to your headlight to prevent moisture
- 1999 GS400 engine will drop right into a 2000 GS400, correct?
- New Tips on Gs430...
- Aristo Swapped 99 GS300 ...questions
- Bought a bunch of maintenance stuff for my gs4, anything I missed?
- New GS with a question!
- does anyone make side mounted sub box for the trunk?
- will is250 19" wheels fit a 1998 GS400
- took some pics today of the gs on coilovers.
- gs300 rear speaker not working
- Arp head stud help!
- GS400 tranny vs GS430 tranny
- Sell GS300 for 4Runner?
- Should i get my rims painted? Need opinions
- Led courtesy light???
- Quick question about iPod 98 GS4
- Strange noise inside cabin on cold start from my GS300
- Carwash done and 01+tails on...
- Which hid kit is the best?..
- Trade my 2000 gs300 for 2005 xterra
- Retro fitting?
- Is Jefftsai still rebuilding VVT-i pulleys?
- Passenger HID won't work at times..
- Removing Steering Wheel....
- 1998 Headlight assist
- I added pictures in the fotos section
- Console switch light bulbs
- Fuse Box Caught Fire!! Photo
- rear badges
- How do you completely remove plate light housing for led housing?
- Help! Problem putting in new grille
- gs300 hard start and random loss of power problem
- 2000 GS400 spark plugs?
- New to Lexus!
- Side Marker won't work!!!
- Mad as hell
- DRL US/rest of the world
- Leaking Fuel Tank: 3/4 to Full Only
- negative experience? crc maf cleaner
- Buying GS300
- how to replace charcoal canister on 01 GS300
- Bluetooth microphone installation?
- Clear Corner Side Markers
- GS Bay Area
- Accident
- Advice needed
- 02 Sensor Question.
- 2000 gs 300
- Best way to run speaker wire thru door?
- help with p0430 trouble code
- High beams and fog lights?
- HELP! with key
- newbie to Lexus some simple stuff and some hard stuff
- Some small issues pls help?!
- Wheels
- A small module with a fan buzzing noise
- heating probs...faulty blend door actuator
- Good Website To Get LEDs From?
- Blackwood Trim
- How do I tell if the key I have to my car is a master key?
- Who has a high powered sub in stock location?
- Pothole gets a win
- Broken Wiring Plugs
- 03 GS, ML amp maybe bad???
- GS Boyz
- 2002 Lexus GS430 Headlights
- Brake on Dash is lit and brake pedal is hard
- 2003 GS300 Sport Design over heating !!
- HID question
- Advice on coolant drain and fill
- How to turn on factory amp
- Buying new steering wheel, airbag questions
- 2002 gs 430 with mark levison system installing loc converter please help..
- New Member from Jerseyyy
- VVTI Cam Seal at 90K
- Need help with timing belt alignment
- For those with wood grain steering wheels....
- CEL Diagnosis
- Car idles low, slow cranking, & hesitation on go after start up.
- trunk spoiler delete?
- picked up a 99 gs a few weeks ago..DRL?
- FS and WTB threads go in the classifieds
- First Gear problem
- P0430, P0154 codes.help please!
- GS300 not running right PLEASE HELP
- Fitment question for 2003 gs430
- New guy outta philly
- Project: Blk out
- 99 gs300 back into limp mode???
- Picked up an 01 gs300 for $1300 today. Shes a bit beat but I'm excited to fix her up!
- Quick Question About Oil, Etc
- need fitment help
- New member from Canada saying hi, eh! =)
- Need Help, Fluid Leak in Bottom Rear of Vehicle
- Kbb or Nada for buying used gs300 ?
- Need to know what this is . Lol
- Tire fitment issue
- Introduction PRKeus, New GS430 owner
- So i got new wheels... Nitrogen in the tires?
- EVAP small black box, what is it?
- Speed Sensor
- VSC Off, VSC, Engine Light: ALL ON!~@!!!
- DIY: Radar hardwire using invisicord (rearview mirror)
- Fog light installation help
- Auto transmission gte problem
- Need help from someone with a manual
- Po441,po446 look here this could help you!!!!!
- ABS Computer (TRC & VSC)
- Anyone have a gs300 ECM circuit diagram?
- Crashed my gs430
- Sold my GS hope to get another one day!
- Looking for a rebuilt VVT-i pulley...
- Spark plugs and plug wires
- 2gs woodgrain
- VIP Tables.
- pulled 4 codes today
- Weird smell coming from hood... slight smoke
- Hub Centric Rings
- GS300 hood won't stay shut
- Lol this guy is funny hanging out the window
- No air coming from front defroster
- Rear disconnect light on.
- New GS430 owner with questions
- how to remove TB GS400
- Broken throttle body level sensor housing?
- Websites For Ordering Parts
- mine again!
- Timing belt kit from Amazon?
- First one to do this????!?!?!?!?
- 2000 gs300
- Projector Head Lamps
- Code troubles
- Door sills item #??
- Low idle on my 2001 gs300
- Provided Techstream keys not working
- WTB and FS posts go into classifieds forum once eligibility is reached.
- To all 2gs. Do u want a jdm power folding mirrors install on your car??
- Need help identifying body kit
- The salesman was WRONG. Sub install/wpics!
- C1204 error code
- Door Locking Problem
- LSD Differencial
- Temperature Gauge??
- I pick up a 98 GS400 on Friday
- How long is too long to get a tranny flush?
- *HELP!* Speed Sensor Replacement Write Up
- Hello Club Lexus
- Wheel fitment question...
- (Please help)
- Hesitation problem?
- Rebuild in progress
- rear main seal
- Wheel/Tire setup
- Has anyone used JET Preformance to tune thier car?
- p505 code/idle issues
- TTE Lip fitting
- Blew out my head gasket..
- painting calipers/rotor overspary
- Pioneer Amp
- Help Aem ems V1 transmission wiring
- Gs400 Window Problem!
- Clutchs!!!!! Everywere!!!!fml
