- Help needed please!
- 5 Zigen Exhaust question
- What brake pads for 2003 GS430?
- Welp, that lasted long... What should I do?
- Transmission
- Vibration coming from under the car.. help!
- Door locks
- calling all q45 retro fitters need some help
- come out of work to find this@#!!!!
- Interior LED's w/ Pics
- Not sure where to post...hopefully here..
- FS and wtb go in classifieds
- new wheels on my gs400 !!!!!
- Wheel size question
- Gs400 p1345?
- Canadian GS owners
- Will lexus gs430 sedan factory mark levinson tape nav oem radio work on 1998 gs400
- Finally started to mod the GS a little
- Okay. Im trying again. Is this the right area to post?
- Bye Bye wintermode.
- So Im programming this remote right?
- Aftermarket key-where to cut??
- How do I get MP3 sound on my GS 2004 (2nd gen)?
- Wider Front Fenders
- 2nd Gen. GS Alignment issue
- Water pump help.
- Car interior got wet from creep and now issues with Touch temperature display!
- Is this install quote for performance parts good?
- converting gs interior
- setero help
- 2001 GS430 Repair Manual
- Weird vibrations after changing ocv filter.
- 98-00 GS 400 Package
- 98 gs 300 noob
- 98 gs 3000 hid replacement
- 02 GS300 Question
- GenB RCA. Anyone ?
- bad creaking from inside wheel: parts replaced
- Replacing the Nakamichi HU - need advice
- Supra TT Brake Kit Replacement Parts
- 04 GS300 (Need help)
- Spark Plugs / Wires
- Cant figure out what the CHIME is for!!
- Tell me this isnt the only aftermarket cat available for a GS3
- How Quiet is the 2nd gen GS?
- Help!! Headunit locked
- Gte vvti swap couple questions
- Does anyone know what wheels these are?
- weird noise from rear pass wheel
- gs430 steering wheel radio controls in gs400?
- cam/crank senor
- Post up your I.C.E!!!
- Mirror won't stay on windshield? Frustrated!!
- 2006 gs 430 grille emblem w/precrash
- 265 40 17's on GS4?
- Cut the Mufflers off your GS400. Sound's good to me - Video
- Great weather in the Bay today, snapped a few pics with my new Olympus Pen EPl1
- Who's using an M2 performance exhaust?
- Can't get tire off
- H&R DRM 25mm wheels spacers
- What oil are you guys putting in your 2gs
- Eshift
- Gs430 at local junk yard, what should I pull?
- Did the Valve Cover Gaskets my 300...
- Front bumper License plate hole plugs / covers
- Just a quick trans question
- what bodykit is this?
- lo_dit's slammed Black GS430 on Leon Hardiritt Beil's
- Roof bar from GS 3rd Gen on GS 2nd Gen ?
- '03 GGP SportDesign Update
- Inner Control Arm Bushing Replacement
- Key fobs work randomly
- which exhaust should I get?
- AC noise on GS400
- Tires for GS300
- Swiss Guy over here.
- Style 95 Beamer Wheels
- 2jzgte swap
- get your maintenance game up...
- Would a 2001 gs300 hood fit on a 98-00 gs?
- Cheapest place to get Throttle Lever Sensor for 98 GS300
- A/C vents
- Removing the front bumper
- HELP. Car will not shift into Drive, Or L gear!
- need honest opinions
- Try this in 2GS section.. Those of you with Retros with D2S Philips 6k Flash White.
- wheels
- very sad to let go
- Sideskirt identification
- 2002 Gs300 SportDesign Progress
- Got scammed on a botched timing belt swap. Help? (pic heavy)
- Anyone know of any sites (besides ebay) that sell the JDM OEM window visors
- Could you help me out to choose right wheels for 2003 Lexus GS300?
- New GS300 owner soon
- problem with my Nav
- oem or aftermarket bumper/rims
- Finally pics of the 2GS with 3GS 450h 18" Wheels
- Widebody kits
- Toyota badge to fit 01+ grill?
- Exhaust leak on my 430..have a few questions
- Air ride q's
- Camshaft Pulley GS300
- Bought this woodgrain wheel..what airbag do I need?
- 98 GS300 P0441 & P0446 W/(Pic)
- Problem with ac fan mode...
- Pressure Wash OPPPS
- Soon Owner 98 GS400 190k (Urgent Help)
- Stock Subwoofer Question
- kinda sqweeky????
- How many current 2gs owners have ever owned a first gen sc?
- 2000 Lexus GS300 Body/Frame Vocab Problem
- toyota aristo before and after.
- Anyone had their steering wheel redone (woodgrain) by CarID?
- will these fit my gs400
- Steering Wheel Swap
- Best Led Tail Light
- stock ride high
- Introdrucing myself
- Control Arm Bushing Problem
- Good place to buy GS300 long block?
- Too many problems, smh.
- GS430 tinted glass?
- OZ Classe alloy rim with holes in the side wall from factory
- Then and now...
- Rear ball joints and waterpump (trick to get cover off..no new t-belt)?
- New and reside in Japan
- Frustrated Female
- Before and after
- Aristo Tranny Swap?!
- Can I fix this body/paint damage myself? Advice greatly appreciated
- Need Opinions on Wheels
- 99 gs300 mass air problems
- Lower Control Arm suggestions and input
- Cel
- 2001 GS300 Inquiry
- Srt intake installed!
- Rear Window loose from regulator?
- Oil leak at intake manifold and cylinder head
- Looking for opinons! :)
- q45 retrofit
- valve cover gasket, plugs and wires changed. car wont start
- 19" range rover wheels...done before??
- Need help pushing side mirror in. please help!
- Help my car keeps dying
- havent been here in a while, new pics!!!!!!
- pics of the new wheels... 20x10 all around
- running rich?
- *** Need SRT intake instructions for GS300 ***
- 03 GS300 radio/nav/tape deck not working
- Anyone ever changed the front catalytic converter?
- ABS kicks in every time i brake
- vip magazines?
- RX350 Wheels on 98 GS4
- Anyone ever replaced their steering rack?
- M35/45 vs FX-r retrofit
- 18" is350 rims
- Please read & help me Lexus members! Electrical problem!
- Battery, abs, vsc, vsc off lights on car dies
- What Color Wheels on 99 Gold GS300
- s430 timing belt time, question on bearing on idler
- can sloted/drilled brake drums be cut?
- na-t setup?
- paint+body finally done!
- Oil under timing belt cover?
- 98 lexus gs300 with 00 gs300 motor help!!!
- MMR HR3 for 03 GS430 wheel fitment question
- Anyone ever run their bluetooth mic through the factory mic?
- 2000 gs rear alignment
- Help guys!
- Temperature needle at a tad bit passed half...is this right?
- Front end noise
- Transmission fluid level question
- steering wheel makes clicking noise when i turn
- Moog upper control arm
- Why don't deals like this come up when I am looking to buy?!!
- Unidentified Box Behind Headunit
- Has anyone rebuilt their brake calipers
- Lexus Badge on Steering Wheel
- Ran out of gas!!
- p0440 p0441 p0446 dtc codes on my 02 gs300
- 2002 gs 430 cd changer
- Updated pics of my Gs!
- GS400 0-60mph
- Quick question about my Q45 retros.
- Rack & Pinion +: How can I get out the cheapest?
- What did you do to your GS today?
- New wheels on do I need both alignment and balancing
- oem tochscreen nav problems...
- Finally got to shavin the rears
- 1999 GS300 Driver's Side Fuse Box - Pictures
- Almost finished my front end repair and ran into this
- this is what happens when a non-mechanical guy works on his car, flame away!
- What should i be looking to pay for this?
- GS400 Muffler Delete
- help gs400
- Engine Cover
- Dumb brake help needed!
- GS400 1-2 shift point
- My Clazzio install (black leather with SD interior)
- gs400 vs sc400
- Oil Leak Question
- New Moog LBJ and Outer Tie Rods - steering won't return to center
- Advantages of a gs300?
- How do i stop this?
- 3UZFE Factory Supercharged
- Noob Transmission Oil Question
- 10 years ago.....
- Leather Care?
- Which mufflers are best for sound and performance?
- Projector Lights on 02 Lexus
- Totaled GS400
- A few pictures of my car
- New to CL: any iphone5 connectors for stock navigation with ML system?
- Radiator fans not working??
- hello there
- Approaching 200k and want my GS 300 to last FOREVER !!
- 2013 gs350 all weather mats in 2gs
- Can someone confirm these are size 74 bulbs
- Beginner Question About Exhaust/Muffler
- 99 GS300 Magnaflow header/cats
- need help gs400
- Shine auto project kit
- Small project
- BCP on Stance Wheels Stance SC-5
- Help with fog light mod.
- Wheel gurus please help
- Preliminary pics of phoenix marie (my white gs)
- 2004 GS Trunk Adjustment (Horizontal)
- Looking for engine and front clip importers
- Tow Hook as Jacking Point
- Opinion needed from fellow gs members
- Nokya High Beam Bulbs
- For the 2jzgte guys running on stock setup..
- I need some inspiration!!
- My 2GS 300 acts possessed when it gets wet.
- Interesting
- Braga type 3 are in
- GS 300 2001 struts.
- Headlight sensativity adjustment?
- Help on finding this grill
- Those with Double Din HU with single DIN EQ
- Touren TR5 Hypersilver wheels for my 2002 GS??
- rear bulb out dummy light on but all of them work + rewire 3rd brake light dificulty?
- Bank 1 sensor 1 and bank 1 sensor 2 help
- How much do you think my car values for?
- Picture request!
- Cool 0-60 calculator
- I wanted to see how it looked...
- new to 2gs ...
