- Please Help! CEL turns on and off. Read my threda please..
- Looking to buy this vehicle. Need input please
- PPE Headers GB...again.
- 100K+ Tune-up
- Occasional Jerk
- need some advice about possible trade
- Cleaning throttle body from the inside
- Coolant Color, red or pink?
- D.A.D steering plate
- 99 GS300 Ground Cable
- CLT saying what's up to the 2GS group
- Gapping spark plugs on 98 gs300
- No power to or from all windows??
- Destroyed my rear axle
- Lighting wring question...High, Low and Fog all on, how to?
- IS300 vs SC400
- Toyota Aristo V300
- Power Steering Problems
- Fuel Injector pressure/flow rate
- 2002 GS300 Tranny issues?
- 1998 gs300/3000 vvt-i
- ProjectGS - Highway cruising videos
- 1999 GS300, Engine Misfire, Rough Idle, Power Loss
- Going from Aftermarket HID kit back to OEM. Could use some assistance.
- Need help on finding out which sensor it is
- Which body kit/bumper is this?
- Bad idle and no dash lights
- Steering wheel shake after new tires
- Yet another new guy with GS300.
- All stock GS400 Video
- What do you'll think??
- navigation update???
- no sound from radio
- sad day...
- We got pulllllllllll!!!!!!!!
- MRR HR3 Quality? Plate Style Wheels On a GS?
- Noob Oil question
- Research and Opinions
- where do i get some blue calipers
- 1999 GS300??'s
- Adding Navigation to a non Nav GS 300
- GS400 Gear Ratio
- car down again 3rd time in two weeks. pls help again
- Eyelids
- Mod for al M2 Exhaust owners!
- what i notice about throttle body and tensioner pully
- OEm HID headlights on non hid GS
- Rubbing noise coming from rear passenger side when turning
- Does anyone know what color wires are going to the subwoofer/amp?
- PLEASE someone help why is my car doing this!!
- Hard to find parts...?
- Random No Start, GS300, starter turns over FINE, engine sounds like no compression?
- Headlights
- How much do you think I can I get for my car?
- FS posts go in the classified forums only
- Bc 272 cams on slightly modded gs300
- Pass Fuse box removal/install
- need your help. smoking navi unit.
- Thoughts
- Fat Tire Setup ?
- Finally got some wheels. First set on the GS.
- Park Assist?
- Need help on offset
- Alpine White III 2nd gen GS300
- Driver side door lock broken. How much$$$
- Front Bumper repaint quote
- Rear fender mod?
- nooob with ???s looking to buy a 2GS
- Which wheels should I get/ opinions please....
- Door Lock Actuator Motor Gear
- 01 gs430 Nothing but problems with my car! Radio went out today to add to the list!
- Totaled 98 Gs400
- Radio Replacement GS300 - Yr-2001
- left tail light went out BRAND OEM NEW
- Wher do you buy the door actuators I need three
- Its been to long.....
- I'm Screwed - Actuator Motor Replacement Problem
- GS Second Gen on BBS RS Wheel, any pics ?
- Upper third brake light upgrade
- Install Your Own?
- Just Another 2GS Shoot...Call Me Maybe?
- Tail Light Issue
- Curious about headlights
- Replacement Harness Connectors?
- No sound after reinstalling factory radio
- Will these rims fit ?
- Parking lights ?
- New owner of 2004 WDP GS430
- What Wheels are these!?
- Who's running 20x8.5 et/offset 30 fronts????
- GS4 Starting Probem
- Custom painted hood
- Should I not be putting regular unleaded fuel in my Sport Design?
- Curious if this is normal or do I need to change something?
- bought my first GS and ready for import alliance, whose going?
- Injectors
- video
- Annoying Ticking Sound under Hard Acceleration (GS400)
- Please, please help! Fender splitting?
- car down again.. fixed starter now this pls help
- AME circlar spec r wheels
- moldings and trim
- 2GS dilemma: What to do with 2003 Sportdesign? GGP on Saddle
- No Lights no start
- Wheel fitment
- 20x10" wide wheels in the front
- How much is a 2002 GS300 SportDesign Worth?
- coil question...
- new to cl what size rim to change to
- Importing Canadian GS400 into America
- Manheim Auction Pricing for GS300 "MMR Report"
- Something Arching...Need Help!
- ZSC3's SBM GS400
- Could i go with a bigger tire?
- How to cover holes from spolier removal?
- new stance
- help needed
- Plasti Dipped my rims and emblems
- Catback labor cost
- pass dor lock cable issue
- AC clutch pulley bearings
- Gauge Mounting
- 1999 gs400 doesn't start - then it does?
- Airbag light / seat issues
- Q Lock Problem
- Wheels trade....
- Question for the Audio guys
- Sportdesign from the Middle East (Pics)
- Looking to pick-up this GS430 today
- well 98 gs300 air suspension fit a 94 ls400?
- New Stance/Set up! PICS!
- Engine Cover 2GS
- Are the SC and GS exhaust flanges the same?
- 1998 GS300 buzzing on acceleration; brake and radio turns off
- Non-OEM paint colors?
- a few months later....
- What is this?
- Brake Master Cylinder
- Which steering wheels have emblems which don't?
- OEM alarm key or Aftermarket?
- GS400 CD Changer Harness
- Gs300 electric exhaust cutout
- Advice needed...GS4 related
- Photo of 19x8.5 M35/45 wheels on a GS400 Gen2
- Anyone have pics of iforged Astras on GS?
- Front O2 Sensor AFR replacement
- IS300 wheels on GS400
- Just because
- drivers door handle lock not working
- crazy screeching noise
- GS 300 or GS 400? Which one to buy?
- My 2003 JZS161 Aristo
- GS400 Valve Cover grommets or 1uz?
- Missing a front bumper bolt???
- stock twins power
- What is my 99 GS300 with 225k worth?
- Major oil leak on GS400
- fuse diagram
- Motor, Tranny Mounts location of GS400?
- radio and clock help
- Time to join the gs?
- STB and 2GS
- Wheel Well Liner Removal?
- My first photoshoot with a CL member
- car down. please help thx
- Need help figuring out why my telescopic steering isn't working!k
- will these sit flush?
- How much does it cost to fill up your gas tanks?
- 2GS cig lighter socket removal help
- Cam seal leaking a few ?s
- What prices are you guys paying for 01-05 GS430's?
- Black roof Suggestions - Carbon Fiber or Glossy Black.
- fx 45 wheels on my gs ;)
- Tail Light Decisions
- Velocity Stacks?
- Megan ez
- Urethane TTE lip replica
- M2 exhaust comparison with and without silencers
- 98 GS300 Climate control button lights dont work
- GS 300 new owner
- Headlight tabs
- Updated pics of the GS
- Wheel fitment
- Anybody removed their side and bumper chrome trim?
- wtb front lip
- What wheels are these..please help
- cruise Control
- car being painted in a couple weeks, made my choice to go with copper but what kind?
- New problems keep coming... (Engine)
- Turbo or supercharger !?!??!?!
- GS 300 2001 wont start
- Automatic headlights not working...
- Leon Orden Hardiritt Super Stars?
- Anyone ever used xs power na-t kit ?
- Single turbo vacuum hose routing
- Front Lower Arm Brace ?
- jp kit with different front bumper?
- FUEL ISSUES!...mpg and gauge
- 99 GS300 AC blowing hot air
- muffler delete with branch antiresonator
- Help driver side courtesy light is out! short circuited***
- Alighnment Help.
- ECU woes... I'm ready to throw in the towel...
- Another Retrofit M35/45 Projectors
- 01 gs oem sub question
- Guys need help
- chasing kits.
- Touching butterfly valve inside of throttle body = dead throttle?
- My retro fit : LS430
- Need quick answer!!
- Vsc.vsc off, check engine ! No start help !!
- 99 GS 400 ignition Coil Test
- Thoughts on 19/20 staggered fitment
- 99 gs300 strange knocking Need help
- New to Lexus community, need some advice...
- Problems with V LED 9005 DRL Module
- what to know for paint job?
- High Flow Cats
- Flywheel cover?
- Has anyone been using SLLC on GS430?
- Speedo dies and brake light comes on
- Stereo upgrade but utse standard Unit.. Please help.
- 98 with auto level headlights?
- Found another one...
- New to the Lexus GS, Questions
- Which speakers to replace ML speakers??
- Looking At Buying a GS300
- Torque to spec??
- Replacing Blower Motor Control
- My baby in progresss
- "VSC" "ABS" "VSC OFF" lights when ever i press on the brake
- Sidemarkers...
- Where do I get this rear spoiler???
- Finally Lowered
- GS 300 - 2JZ-GTE swap - Help
- New Member Introduction
- Hard starting rough idle
- Replaced atlernator, now noticing things....
- FYI: Bluelex's GS is on Ebay
- pics of my gs300
- Re-Adjust Headlight Level
- Tanabe Medalion pictures
- po 446
- newbie
- Noisy engine
- Transmission whining noise: Have I boogered up?
- Check Out My New Plates! Haha.
- Broke 30 mpg in my GS400
- jp kit got questions need answers
- can i use gs lug nuts with is rims on my gs?
