- I have a stupid Door/Lock problem....Please help
- Boston: Rays . JP . LuxuryAbstract . Bagged
- leather is showing its age
- O2 Sensor Wire Question!
- alpine m-1000 amp
- How high do you rev your car?
- 2001 gs430 brake failure!!!!!!!!!!!
- steering wheel sound when it up/down
- Real quick vote!.!.
- L-Sportline M IV Chrome 19" Staggered 19x8.5 front and 19x9.5 rear
- My stretched tire failure
- Front Seat Nightmare
- push pin for trunk
- Looking at a GS400
- I need help.. Car was egged and need help picking out a good car cover.
- what type off rims are these
- GS400 storage tips
- Faulty ac magnetic clutch reley?
- urgent help please with upper control arm bolt stripped
- Removing Dashboard to seal Evaporator Box
- AC blowing cold on one side and slightly warmer on the other
- 2000 gs300 gear shifter not shifting
- Steelies on a 2000 GS400
- Can someone help me n let me know if these offsets will fit?
- Wheel fitment guide?
- TSX retrofit
- Some pix of my 400
- Anyone in orlando who roll fenders?
- Houston, TX Members...I'm Here!
- Watch the video...valve slap or??
- Odd Horn issue
- new owner
- Anyone who has ever used EBC pads please help!
- About to pull the trigger in a few hours.....wheel fitment/tire sugestion....
- Led tailight, what type turn signal bulbs?
- 98 gs300 coilpacks
- Japanese hanging rear view mirror options...need ur help.
- Headlight Conversion Help
- Where to find tan junction produce neck cushions
- will gs350 engine fit on gs300 2002?
- Rear Ended Someone
- New wheel set up
- Gs4 inside tire wear (stock 16's)
- Painted LS400 calipers Sunday
- Rear seat cup holder
- Thoughts on Plastidip???
- 98 gs300 transmission mount help!
- Super Squeal
- GS4 up close wit M2 exhaust
- Radiator fan turns on with A/C normal? 98 GS300
- Auto Light Sensitivity
- Borla Rear sections installed!
- Tire size options!!!
- Tires rubbing on steering knuckle please help!
- Mobile Auto Paint...Highly Recommend
- cosmicci / Cinnabar Pearl GS300
- Heu guys you prolly don't remember me,
- fuel economy
- Got side swiped!!!
- Crystal White GS430 - Choose My Next Wheels
- Not another tire question...
- GS300 battery drain or leakage
- Aimgain Grill
- Who makes these wheels??
- First post of my car with some new shoes!
- 3uz-fe
- question about gs wheels
- Ls430 projectors for a retrofit
- 3rd light LED now can't get warning signal off dash
- Front window making noise...
- Strange overheating issues with 300 GS
- Is the exhaust supposed to sound like this?
- Pics of my GS300
- 98 gs400 repair manual
- waterpump/ timing belt video
- Quick coolant leak question!
- Some pics of my car
- how do i get my CEL off?
- Putting 24s on the gs
- Updated pics of my GS
- New 18" rim need staggered
- Low Mileage GS 400 for Sale
- COMPUTER SUB-ASSY, SHIFT LOCK CONTROL what does it control?
- Headlights
- Hi from half around the globe
- spacer gurus who knows THEIR poopy doopy please help..involves equation problem
- Timing Belt packages???
- OEM vs Denso air fuel sensor
- My pics
- quick question
- where are folks picking up the JP Rep spoilers??
- 2gs HID replacement to 6000K Philips D2S
- Looking to go UAS on 00 GS3 looking 4 feedback
- New member to CL
- AC port on 2jz
- PLEASE HELP! Where to buy black shift knob?
- Brakes a little squishy
- ProjectGS DIY: Custom bright LED license plate lighting mod.
- Planning on running 20x11 +15 in the rears anyone got same offset ot close
- Wtb jdm led tail light!!
- Sensitive fog light switch!
- need a hand deciding between these two wheels
- Mk4 supra tt brakes worth $400?
- Recommend Shops (Sacramento 916)
- Lights
- How do you get to the brake light switch
- my new GS4 Greddy Evo2 exhaust video!
- How rare is cinnabar pearl color?
- aftermarket trunk alignment
- My new 18" wheels
- vmr v710
- Borla Exhaust Shipped
- Soooo undecided....
- JSK Coilover
- Is there anything I need to check?
- Installing wheels spacers
- FS and WTB posts go in the classified forums only
- PCV bypass? To run breathers instead.
- Fog Light Lens Cover
- Black Driver Side Pillar
- If you could choose an exhaust, which one?
- Kped at Motion :)
- Another HID thread, looking for quick answer
- 2 questions for you 2gs owners!
- Need some help(new car guy)
- help please!
- 98 gs3 rear axle removal
- A lil progress
- Changed my third brake light now car won't shift out of park
- Starting issues :(
- Brake project complete. Hello Supra brakes.
- New Car
- Fresh New Wheels
- Does my GS4 need replacement timing belt?
- Pic Request 20" staggered with lowering springs
- A/C Freon leaking out of radiator?
- Price check and cheap place to get stock style headlights
- G35nyc-nycmaximas-now clublexus(hollywood new here)hello fellas
- looking for a new shift knob
- Can't decide on a color for Wilwood calipers
- key lock code
- New wheels wuuuh.
- Need head unit help...00'
- WTB And FS go in classifieds
- 98 gs300 air vent speed question
- GS3 Top Nut Engine Mount Torque Specs???
- new M2 exhaust on GS400
- Does anyone make a larger replica of these OEM wheels?
- Picking up gs300 tomorrow
- Fog lights stolen. What size bolts do I need?
- Specific things to look for when buying used?
- Exhaust update
- coilovers comfort on freeway?
- check engine, vsc, vsc off lights are on
- Mbc question
- Want new taillights! Which one should I get?
- just lowered lil bit more!!!!!!!!
- Muffler hanger problem
- My little brake project for this weekend
- All 2GS guys looking to re-do their armrest? -- Don't buy these!
- Trunk not opening from panel or remote!! Please Advise
- I'm having a hard time identifying this body kit
- Anyone know...........
- tranny service etc
- Looking for a sweet exhaust for GS400
- Pics of lowered gs300s with positive camber
- GS is gone :( Time to move on
- Who has owned both a GS300 & GS400/430
- Help, Odometer issue !
- Power lock problem of 2001 GS300
- Well, it's been a good fellas
- GS300 rear crossmember, works on IS300?
- starting problem
- Hood Strut .. Strong arm?
- RMM bumper with Veilside executive skirts, any pics????
- Just got my car. Time for some MODS!
- Aftermarket fender
- Black paint job suggestions
- Has anyone had experience with aftermarket OEM Front bumper replacements?
- 2nd Gen GS in J Reyez' new Youtube vid..
- Funny Rear Light Behavior
- Headlights have moisture! What options do I have?
- HELP! battery light on after timing belt change
- LEDs in your fogs?!?
- tanabe medalion touring
- Tanabe Medalion Touring
- Newbie with first Mods
- Ballin on a budget :D
- Small update
- 110 speed limit..... Help?
- How Much Dynamat do i Need For Trunk?
- SPC front upper control arm
- Something to look at
- Car is stuck in Parking gear
- Dazen Caster/Trailing arm Bushings Opinions Please!!!
- 2002 GS430 Dash Noise
- steering column issue?
- Battery dies while braking
- Poor GS 430
- Need my familys input.
- Coilover question
- body advice!
- Audio install on Stock HeadUnit with NAV.
- Introduction Post: 2002 Black GS300
- LS400 Brake question...
- How to fix your Servo Motors! Complete guide.
- Gateway ECU or Navigation (or both)
- 99 gs300 JDM LED Side Signal Mirror NEED INSTAL
- Topspeed Exhaust
- access to black book wholesale pricing
- Black interior
- goin with a hood bra look .. comments please
- best place to get new alternator + couple teaser pics of my new baby!!
- Aristo side mount
- 20" wheels staggered
- Update pic of GS430 :)
- Looking to buy a gs400 any helpful tips?
- speedometer died while driving!
- How to replace driver's side mirror on 2nd gen GS?? Also some pics up!
- NEED help nowabout bf goodyear gt radial tires stretch?
- Need help finding part...
- New Navigation Upgrade 11.1, not impressed
- Test fitted the TTE replica.
- When to replace Radiator?
- Just a little update
- '02 2JZGTE VVT-I swap issues... some advice please...
- Remove Intake Manifold to Change Valve Cover Gasket??
- Inner Tail Light Install
- Anyone have SONAR BRAND LED TAIL LIGHTS? - LOOKING TO GET PICS!
- Gs 2Jz turbo swap
- Who's up for some playing swaps... for keeps!!
- After installing SRT and Tanabe...
- Front tires heavy wear on inside (normal?)
- gs400 transmission under 30k for $700
- What is this???? Please help Gs 400
- No pressure in radiator hoses?
- Which one is best?
- Trying to program a 2nd key with crappy door locks?
- Easy or hard: swapping out GS3 steering wheel controller to GS430
- Lexus gs400 Should I buy a used Upper control Arms from An Auto Recycling?
- Thinking about new paint, championship white?
- sqeaky suspension??
- Help!!!!!!!!!!!
- 99 GS400 Strut rods or Lower rear arms on the front suspension? Plz help me identify
- Some pics of my update...Go low or go home!
- painted engine cover
- Need help asap: Spiral cable/clock spring reinstall method?
- GS4 exhaust leak?
- New GS400 for me! Water pump and Timing belt questions?
