- Ksport coilovers?
- Benefits of TRD Strut Brace
- Intake options?
- Dont Shoot i searched P0441 cel and other prob
- Wheel help!!!!
- Finally......new wheels
- GS300 stalls / dies after filling up with gas (CEL P0441)
- TM Engineering
- ML stereo right side louder than left???
- Anyone use the Tomei LSD in their gs300/gs400 pumpkin/diff?
- 2005 GS300 starter melted
- anyone lexus thieves?
- same wheel locks? dfw texas area i need help
- Just purchased ebay strut bar....question for those that have one
- Are HIDs too hot for high beams?
- hid
- Does CEL turn off by itslef?
- Window problem... door problem..
- Refurbished my Wald D23 Wheels.
- 2nd gen led taillights?
- Looking for VVT-I O ring
- cup holder divider installation
- How much money have you saved because of Club Lexus?
- fog lights
- New engine harness?
- XXR 521s in 20s !
- does anyone have engine mounts for sale for a 2jzge motor ...
- Finally pics of my ride
- Some iteresting lexus rides
- PLEASE HELP supra tt pads
- trunk removal off 2gs
- Look at this ish...Codes
- Bad ecu question
- Is the hard to install
- Need timing belt replaced and door lock motors, where do i go?
- Post pics of youre Imperial Jade Mica GS!
- High amp alternator
- Name that front bumper:
- Need opinions!!!
- Stainless steel oil filter
- Ac ?
- Help deciding which wheels to get
- door lock actuator brass collar
- ECU help Please
- quick brake nub question
- Rear lower brace
- GS300 Knock Sensors Locataion (p0325)
- P0441 CEL Code; won't rev past 3800-4k; VVTI not engaging
- platinum gs300 on 22s. what say u?
- New to CL. 2000 gs300 platinum edition
- Would this be feasible?
- Weapon-R Secret SRI vs K&N CAI
- Spec-D LED Foglights with Daytime Running LED Strip
- Just picked up a gs300
- So it BEGINS!
- 01 Shift Assy GS3
- 3 PIECE TRUNK WING installed ??
- Question for all the slammed/flush fitment owners...?
- how do you remove the stock rotors off the gs?
- New to the club
- Opions on these wheels
- Finally found a GS430 but it might have issues...
- Removing Rear Deck Lid to repair subwoofer
- New kid on the block
- Can't close hood on 99 GS4 -- any help?
- Lexus Pedals
- HELP installing Ashtray
- car back from body shop !
- How to preserve the black onyx paint
- FX-R Retrofit
- 1999 GS400 Nakamichi CD changer notes
- Should I give up on this projector project?
- All Locks stopped Working? 2001 GS300
- Wheel help please
- Bad smell from the air vents
- Anyone With Photochopping skills Please Help!
- does lexus have a safety issue free replacement???
- How do you clean your WORK Wheels?
- Lt.Dan! New shoes!!!
- Starting Problems Intermittant...
- Help please!.!.!.
- Advice On Wheels
- Front side markers
- biggest subs in your trunk ?
- Ame cx
- Anyone manufacture a polished 19" LM rep (like a 1.1.2)?
- Calling all wheel gurus 20x9 et25 20x11 et33 fitment??!!
- need advice
- Need Some Advise on Supra calipers
- Getting SIDEWAYS!!!!
- Gs argument ?
- front suspension noise low speed
- HID Fog lights
- Reverse light went out after changing the ride height..
- Is this a 1 stage air bag on a 01-05 airbag??
- Removing studs????
- Well hello there.........
- Help! SRT GS430 instructions needed
- LED Interior Light Problems.. Help?
- In just a couple months....
- Need help with some wiring..
- Just put 3rd gen wheels on.. not sure if I should go back to stock
- What's wrong with my OEM HID? (PICS)
- replacing the parking light bulb (194)
- Interior and Exterior Color 2GS Production
- I want to paint my calipers but PROFESSIONALLY if possible.. please need suggestions.
- Night Pics, take a peep
- Red Brembo Brake Covers
- Need help please
- how can you tell if the mileage is not correct?
- Having fun with late night session of street drifting.
- Steering Wheel question UPGRADE!!
- So Cal Westminster Lexus
- A few progress pics of round 2
- What's wrong with this
- Took off my spoiler and now my trunks pops all the way open
- Awesome GS... Anyone have more info?
- Spacers are on....
- Soon replacing differential bushings, what else to do while differential is out?
- Can someone tell me where these FIGS Rear Pinion Mount Polyurethane Bushing goes?
- Will not shift into overdrive
- 65mph+ shake fix
- Found a unicorn 400 FS!
- hid kit
- Gave her a face lift... (Plasti Dip DIY)
- WTB: Retrofitted headlights
- Gauge Cluster
- Got my knock off Tsuna today
- Lips resizing need your input
- Wheels
- Advice for chrome rims
- diff swap compatiblity
- Bringing back the ABM.. 1.1.2 and Lp's
- Third Tail Light In Spoiler Out
- great deal on poineer double din nav, but does this seem sketchy?
- boring day so i decided to burn my springs !
- Need some expert service....
- What is this connector? Can someone help? ver.trunk?
- Proper Way Of Brake Bleeding GS400
- Spray paint?Single stage paint?
- Weird issue, harmonic balancer related.
- Ball joint replacement
- 20% or 5%???
- Revisiting Something wicked this way comes 98'
- Revisiting the GREATEST marketing campaign EVER
- Window Issue...has to be an answer!
- Updated her rear end...
- what kind of mpg's/miles per tank on gs430 only?
- Unbelievable car damaged at work
- Monitor Headrests
- 2000 gs300 passenger side mirror
- New Pics!!
- Upgrading OEM HID Bulbs
- New Stance :)
- Anyone running aftermarket Engine management?
- Full coilovers!!!!
- 3 piece trunk wing ??
- Rear Diffuser
- Stant Gas Cap, Anyone Ever Try It?
- Clear VVTi GTE spark plug cover
- Plasti dippin the kazz grill
- Another random question about ashtray???
- Yellow Fog Light Overlay
- Some pics of my 2GS drifting on CV3s
- first time doing timing belt/water pump
- how do these look
- Fresh Ride
- GS300 wouldnt start but was surprised at the problem.
- My Car @ Caffeine & Octane
- Pic request please
- LS460 Headlight retro
- Help! Door won't open after replacing door lock actuator motor
- Car Overheated and radiator has a huge crack
- Anyone have pics of a GS with MRR H4's
- Does anyone know what rear bumper this is?
- Will 04-09 Rx steering wheel fit?
- Burning rubber smell?
- Tilt motor rebuild
- VAPC 18x9 wheels. JDM from '02
- New wheels on, hate stance, need advice/suggestions
- broke down
- Another new member
- Flange Size question
- changing original brakes, any recommendations?
- Do SC400 Console Armrest Lid fit 2nd GenGS
- Uppers and lowers need done...
- Just got my SRT intake. Ghetto?
- PBM coilovers
- Hi Guys - "Hopefully" New GS300 Mk2 owner here.
- Name this grill
- Reputable website to purchase coilovers?
- Cousins Rollin' Vip photoshoot.
- Im about ready to install double din dvd/gps with cam. what is needed?
- New look, gold gs from 19" to 20"
- speaker sound ???
- How do u guys do it??
- Good place to find parts!
- I am upgrading my garage for my GS have I gone crazy
- New to CL...looking for helping finding parts
- Yay me!!
- Cigarette lighter and aux power won't work
- help
- 07 es350 rims fit my 98 gs400?
- thought i share my modz
- Dyeing my headliner black!!
- Wierd Electrical Issues
- Any one have these headlights or seen the quality on them?
- Spoiler name?
- big transmission issue
- Axle Stub Spline Count?
- UCA squeak but UCA/LBJ are new
- My Battery seems to drain after a couple of days of non-use
- Brake Fail
- New wheels!
- leaking trunk
- Valve cover leaking oil
- 2000 gs 400 issues 100k
- Cigarette lighter & Power outlet not working -all fuses fine.
- Slight wreck GS430 front L suspension_wheels_out of line
- Do you daily your GS?
- New Rims and Parts.... More Still Coming In
- What RCAs do you use on your setup? Any bolt failures?
- Does a GS400 Airbag Fit in a GS300?
- Speedo Problem
- Oil type?
- Exhuast
- Coilovers VS Shocks and springs
- need a lil advice
- Key fob range is very short..
- How do we feel about Bosch parts?
- Plasti Dip chrome trim???
- AC Problem
- L-Sportline Calipers
- Rattling sound front left
- anyone going v2 lab meet on april 8th?
- Rear Main Seal Leak(Possibly)
- vibrating brake pedal on warm up with buzzer sound
- Do anyone know what this is?
- front speaker adapters ?
- rays victrix help center caps!!
- Help red/clear or red/smoke LEDs? on silver
- AUX input for under $5.00*** You guys wont be disappointed Pic intensive
- building my own rear table!
- My 98 gs400
- How would you rate your car?
- car all of a sudden slows down
- ProjectGS: Quick Makeover Before TX2K12
- 2003 GS300 VSC / ABS Skid Control BUZZER - Where is it located????
- Downpipe choice's?
