- Bad acceleration but no check engine light
- Haters are gonna hate!!! stupid people egged my car...
- Whats good club lexus..
- Fitment question..
- Interior finally done.
- I need help picking Front Shocks
- Heater Hose Coolant Leak
- ?? DO U KNOW: 99 & 00 GS 300 Throttle Body ??
- 2000 GS300 Engine Shaking; Need Opinions Please
- Question on Rear main seal and quote
- stock amp wires to aftermarket amp
- Stock intake is better
- I want an LSD!!
- Rear Upper Control Arm Compatibility?
- Lets talk built tranmissions....
- Bye Bye 2GS will be back soon
- ECU tune for gs400? Anything other than Jet???
- "The external system is not connected" error message - HELP!
- Has anyone else seen this?...
- Transmission Issue (Update)
- suggestions for CAI/filter
- SRT ECU Location?
- Used these tires on GS400 or GS3? Rate them 1.0-10.0 or N/A them. Thanks
- Have a question, start by using the SEARCH button!!!
- Macadamia brown gs430
- After Market Headlight Options
- Lifespan of Lower Ball Joints
- Anyone familiar with Headunit/Radio and Amp circuits?
- Which is a better engine, Inline 6 or V8?
- Led replacement info
- just got my aligntment and left side a lot worse than rt, why? (pics)
- TM Engineering order issues.(update)
- What Is This???!!! (See Pics)
- Found a GS300, but now I need advice... (oil leak) *pic*
- Tips on modding a grille?
- had mt rear fenders rolled today...
- Need advice - lowerin w/ 20" in a week or so
- UAS DIY anyone?
- Foglight Fuse keeps blowing.
- Horn stopped working
- What grille is this ?
- Anyone got pics of a GS300 on Lowering Springs 2inch Drop?
- Does Anyone Have Pics of GS300 On Lowering Springs?
- 2000 GS 400 - wierd electrical problem
- Misfire only at idle?
- HID Fog light not turn on
- sub forums ?
- Does 20x9 w/ +38, need to roll fenders?
- HELP!! problem with key
- How much is that speaker in the window, woof woof
- 20" rims with 30, 35, or maybe even 40!!
- Gs300 Drifting at ThunderHill Raceway... Need more Power!! :'(
- Help with offset
- Do any other Make OEM wheels fit the 2nd Gen GS?
- TM Engineering order issues..
- Vertex steering wheel, yay or nay???
- GS respray
- Colored wheels!
- Questions about this GS
- Anybody know how to remove lower fender?
- SRT w/ AAFC
- engine question
- GS300 + UZS186 Majesta = Majestaristo?
- possible brake issues?
- What is this???
- Help from the experienced
- Bye Bye Hondas Hello Lexus!
- What to replace on used JDM 2JZGE?
- bake tail lights?
- lbj and bushing questions.. ??
- Do you VIP cars get pulled over alot?
- 1999 GS 400 Help with tire size.
- Need Help...99 Gs300 gives poor gas millage 245miles total on a full tank
- infiniti M35/45 projector retrofit
- Tire pressure for 245/35 on 20X10.5?
- steering tensioner adjustment question....
- Got 20's, Now need smaller tire.
- honda head in a lexus
- Timing Belt service tips?
- +22 on a 19" x 10.5 rear wheel? Tire suggestions? rear fender mods?
- qUICK ?
- Tire rubbing
- Interesting GS
- Easiest ways to add power?
- To Halo or Not To Halo That's The Question?
- Hello
- Does this sound normal?
- Looking for a good Replacement Bulb with that HID effect
- Flip Key on 98 gs400?
- Looking for Aftermarket Double Din Radio
- RX330 18" OEM Wheels on GS300
- Does anyone know if the GS2 brake master/booster/abs pump is the same as the sc430?
- Improve Photoshoot me and some friends did today...
- How to wire up a 2jz-gte vvt-i in a 98 gs300
- Just another day in Philly
- Cam seal replacement tutorial (430)?
- GS400 New Suspension Update! Stay Tuned!
- ordered my balljoints ! n guess what happened !
- Sessions Carbon Wrapped Aristo (pics)
- Hello all...
- Wheel spacing question...
- HELP! ASAP!! Where does this plug into?!?! rear deck
- Gsf 350
- few pic of my LS430 retrofit
- Hello, and a question!
- If I hit the lottery....
- GS400 Wont START!
- Got my Borla's installed!!!! Quick Video
- 2GS full tank $140+
- help car wont stay crunk
- Abs sensor
- Car Repair
- Running Rough
- How many miles to the gallon?
- show me a pic of your 1998 gs400 remote
- A couple side by side pics.....
- Adjustable Upper Control Arm and Rear Camber Kit, Worth It???
- Anyone wanna meet up in South Beach?
- Gona need a bigger rubber...
- Manually adjust auto leveling hedlights?
- Super weird freak problem, car tried to start itself with no key
- Need quick advice pls...
- VVTI Cam Gear Leak
- Help.. How to remove steering wheel ive searched
- Does anyone know where I can purchase the chrome window trimming for the GS300 2002?
- Looking to buy a 2002 gs430, help please!!
- Fog light replacement / wires
- *****UPDATE on engine ticking******
- es300/gs300 ??
- GS300 1JZ engine swap
- Photoshoot with the GS!
- website suggestions for gs300 parts
- "VIP" headlights
- NAV frozen
- PVC Valve removal
- Sewell
- Suggestion for my gs300
- Pioneer X930 Installed but tweeters sounds bad
- Sup Guys ... New here
- V-Day! How much do you love the 2GS
- where to buy caster arms
- shark fin antenna?
- SJGS Silver 2gs UPDATE from the BAY
- heat issue
- Sunday Funday Shoot
- dreading this day.....
- 98 GS400 - Idle Speed Adjustment
- Help! Electrical problem or alternator??
- Electrical Help!!!
- GS430 market value?
- my 2gs, update and some drifting.
- gs300 98 Front Shocks DIY with PICS
- your thoughts on gabriel ultra shocks for 98 gs4
- How much does a kazz grille go for now?
- Question for those who have changed or removed rear toe links
- Question for the guys with LS430 retro
- Custom 01+ Tail with Led mods, Here's a PIC
- Clicking sound when braking
- Caution with size 34 battery on GS and other Lexus ....
- A little burning oil smell
- Tan vip curtains
- new to the site!! supp fellas
- Anyone know the name of this part?
- Odometer Correction
- Custom Tail Lights
- Anyone got these headlights?
- Great price for aftermarket headlights
- Do these upper control arms look like a good? buy?
- found out one of my wheels are bent, what's the cheapest route?
- *PICS* Depo (insurance style) LED Tails
- lexani wheels on gs3
- Just got my baby painted :D
- Sewell/Carson ProblemsSB/ADUS decision.
- need help w/ braking noise & random engine turning off
- New wheels
- Bad gas mileage and an engine tick
- weird steering wheel bs !
- Locked out of car, Help!
- Modify steering ecu DIY
- FINALLY.... It's show time!!
- Aluminum bolt on Caliper covers.......?
- New here, wanna run my bbs lm's
- Parts from another GS
- Gas cap
- LuxuryMods?
- Does anybody know what size screws hold the outter tails in?
- Disable cabin air filter
- new wheels =abs light vsc light on ???
- GS430 80-140mph video
- Philly on airlift LOL
- rear camber ?
- Lexus gs400 or Lexus ls400
- 2000 Lexus Gs300 Body repair
- which hobby red spray tint is best to use for tails?
- Considering doing an NA-T build to my GS | Boost Logic Kit
- oil leakkk !
- Key shell keeps breaking
- Is it hard to replace led bulbs from my depo tails?
- Amber Delete 98-00 GS300
- front sway bar bushing noise
- steering spins freely
- Air runner rubbing question
- gaskets/spark plugs & wires
- How many of you guys wash your cars?
- Re-laced my GS | New ADV1's
- The shaky steering wheel and vibration thread!
- Shaky steering wheel follow up and tire recommendations
- '05 amp harness
- 3 piece spoiler
- Where are you from?
- Kazz Grill & Wald Lip
- What are factory chromes worth?
- Aristo from japan(video)
- Anyone with spacer knowledge..
- My rearview mirror fell off
- Tail light issue, possible electric problem?
- Anyone have pics of millenium silver with black wheels?
- I don't like the tips of HKS what do I do?
- bypassing parking brake
- AC issue....
- Finally ready to slam my car!
- coils or springs ????
- steering wheel jerks.
- Please use the classifieds only for WTB and FS threads
- Research engine serial number
- Just sold my GS430, here are 2 pics for posterity.
- Lsportline Rear Bumper and rust
- Silver/ Blk GS300 Parts
- Anyone have a aftermarket antenna?
- soft break pedal, vsc, abs, brake warning lights
- Rear window question??
- I want my 0.6 seconds back!
- Headlight Washer
- Some help with a noise...
- What is this call and where can i get it?
- Gs400 turn signals fuse ?
- Spacers???
- 18x8x5 chrome wheels keep leaking air!
- 03 gs430 Nav, Clock, radio lights out. Fuse? Help!!!
- Polyuthrane Body kit
- door locks on gs300
- Any Photos of 97-2000 sc oem wings on a gs
- My style over comfort feature
- My rant on my recent part out!
- Catalytic Converter
- Best coilovers for under a g?
- time to change my grill!!
- Help Folks
- TTE Replica
