View Full Version : Suspension and Brakes
- need to compare Tanabe springs before buying
- Bilstein HD vs. Bilstein Sport
- Disgruntled Brake Guide Pins? ..pics
- New rotor or resurface existing one?
- slamming car on tein cs
- About to drop my GS
- Opinion Needed: Red brake calipers OR no?
- Cutting stock springs
- When you should do an alignment after installing coilover/springs
- What springs provide the lowest drop?
- supra coilovers on 1st Gen GS - has anyone had success
- Price for a Brake Job - Your opinion
- Frozen rotor????
- Tein CS V2 settings, help asap
- Adjustable sway bars
- VERY uneven brake pad wear!!!
- recent photos of my project. 8 months in
- Brake juddering...
- tein type cs coilovers
- Tein CS price
- Rear Suspension Brace
- New Tein CS vs. the Old?
- Anyone purchased from... (... = Race Inspired?)
- For those of you with 2IS or 3GS 18s on a 2GS....
- Suspension settling?
- brake question
- How many 01+ GS owners...
- Completely new beast..WOW
- Tein SS
- OEM or aftermarket part?
- Espelir ASD Springs
- Will 1st gen Gs suspension fit on 2nd Gen?
- L-Tune ID?
- brake rotor help please!
- What's the difference between these 3 coilovers?
- Adjusting Camber
- Checking brake pads?
- Rotora Brake Paint
- Drill and sloted rotors on the rear clicking (HELP)
- Tein Flex and stiffness controller for $1500
- Tein SS or Wait for CS
- Question about the brakes...
- Noise When Steer
- Front and rear strut brace
- Questions about HKS LS+ coilovers
- fender wells
- Bilstein PSS Install?
- How bad is it really?
- lot of play in brakes after replacing pads
- Suspension Advice
- Apexi Suspension
- Steering Shimmy-where to get balance around Dallas?
- Guys with sways or sway knowledge, I need your help.......
- Finger Gaps & Rubbing Issues!
- Lowering Spring Website
- upper control arm bushing problems
- Espelir springs impact to camber
- What do you think? Still unsettled...
- TRD front lower chassis brace
- (Pix?)Tein CS's Dropped All The Way w/ 20's(Pix?)
- Another member looking for suspension advice
- Daizen Sport Spring Owners
- GS brake caliper clearance...
- Daizen Bushings-2002 and 2002A-Differences?
- Have you ever checked your wheel bearings?
- Weird brake sound GS300
- Wald Big Brake Kit
- suspension setup on gs430 advice
- question about slotted brake rotors
- Torque specs rear stb?
- Coilover's
- Question about bleeding GS430 brakes w/ service manual pictures?
- 98-00 vs 01-05 rotor differences
- Busted Upper Suspension Arm???
- new member & finally pics
- Has anyone had their shocks or coilovers' compression/rebound rates revalved?
- brake caliper skicker vendor? >searched<
- Megan Racing Coilover Damper Kit
- Adjusting Tein CS v2
- Question about Tein... Camber kit?
- Tire Size Calculator...
- question on wheel fitment
- quick quesiton on changine the front lower ball joints
- Brake Problem?
- DF210 or NF210 springs
- daizen steering bushings? do they really help?
- Coilovers
- Should I replace all rotors?????
- Brake System/ABS meltdown!!
- ??? for those that have replaced the master brake cylinder
- Poly bushings woth it?
- Car Clicks and Creeks over large speed bumps
- coilovers that can go the lowest?
- Safe Drops and Rims
- Tanabe NF210's or LTuned?
- Bilstein Shocks Not Available For '03 and Beyond
- L Tuned Springs
- Rear Brake wear ??
- What are some good cross drilled rotors for the the GS?
- Side to side shimmy!
- Hks Ls+
- The Ride Difference from CS ver.1 and ver.2
- Tein HA's question
- Ceramic Brake Pads Suggestions Needed
- Zeal for the New Year!
- Brake Job for 2000 gs300?
- intrax sway bar
- So my borther got some new goodies from Tein [front and rear STB pics].
- Need advice
- brake feel relative to seat position: is this normal with the 2gen?
- Installed: Brembo iRotors; Axxis pads; Blick roof spoiler (pics inside)
- front suspension problems?
- Harsh yet floaty?
- Ball Joints collasped
- What is a fair price for kyb gr2 install?
- bushings
- Brake booster=$2500 at dealer
- Damnit, another thing needs to be replaced.
- Help With Springs
- THe Shakes
- anyone have an opinion on TEIN SS
- coilovers
- do you need alignment after ball joint replacement?
- Brake question
- Lower Ball joints
- Is replacing ball joints and tie rods a do it yourself job?
- megan racing coilover damper kit
- need new rotors
- blown shocks to blame?
- How much did you guys pay for tein coilovers and EFC install?
- Need New Rotors
- Quick help needed on Torque Specs...
- HELP!!! Seeking urgent expert advice
- Clunking noise coming from the front end
- Have Ceramic Pads..Need Rotor-Help
- replaced front brake pads
- Odd handling after front end alignment
- Lower Ball Joints
- Help...Question..on Brakes
- H&R coilover.
- Air Suspensions
- Tein CS v1
- Where can I get Brembo GT kit Rotors/brackets?
- Steering is out of control!!!
- Brake help please
- advice, opinions on leaking shock please
- Spend my $1500.00.....
- Spring Rates, stock and L-tuned?
- New CS installed!! Love it but one question
- Picture Tein CS v2 with 2 piece brake rotor
- Grinding noise when braking hard, good pads ?
- Floating or rocking from front end??
- What comes with a Brembo BBK ?
- suspension question
- Weird Knocking Noise
- Brake master cylinder
- WARNING! front lower ball joints!
- Tanabe Sustec Coilovers...
- Will '07 GS350 Calipers Fit on '01 GS430?
- Swaybar endlinks loosening with Daizen swaybars?
- Finally Eliminated the Dazien Sway Bar Squeak for good
- Eibach Pro Kit / Bilstein Sport Installed
- HELP!! I need a camber kit!!
- Soft Lexus quailty ride with handling to match???
- Urgent help needed with brakes!
- How often does your brake hydraulic booster re-pressurise to 'top up'?
- What should the Lower Chassis Brace bolts be torqued to?
- Suspension Change to fix rough ride?
- Which shocks did you choose and why?
- Bushing help
- DIY Tein V2.0 coilover install????
- Squeaking from front end over dips, help!
- Need suggestions on shocks.
- Squeeking and Rattles
- Brake Pad on stock rotor/clipers..
- anybody has TEIN SS (Super Street)
- 2 piece stock brake rotor
- BBK Swap.... 04 LS430 --> 01 GS430
- HELP:19's with stock sus setup
- Bilstein Shocks and Struss
- Sway bars and Winter weather
- What is the easiest way to adjust coilovers
- Rotora 8 piston 380mm BBK :O
- Has anyone done this Daizen c/arm bushing kit mod?
- Lower chassis braces. Aluminum or Steel?
- Need help with Tein Flex
- Tein Flex Making to Much Noice
- My suspension is sometimes high, and sometimes low. Normal? Shocks/springs.
- Replacement Shocks
- clunking noise
- The New Tein CS
- Help: how to remove the rear rotor?
- DIY Daizen Steering Rack Bushing
- Installed new Goodridge Brake lines today
- Anyone have pics of stock vs. Daizen vs. TRD side by side?
- Urgent help!
- Pics: 2000 GS400: After Brakes and Suspension Work.
- Are the L-Tuned shocks supposed to be stiffer than stock?
- coilovers with drop springs
- Who wants Stronger *ENDLINKS* for the rear sway?
- Brakes rubbing?
- Guys, I need a quick response before I buy these...
- TRD Strut Bar fitment issues (holes not lining up)?
- bilstein struts height ajustable?
- Help with stuck caliper pin
- Changes of Tein Flex
- OEM Brake Rotors Replacement Brembo or Rotora
- Daizen Bushings Squeek.
- high speed vibration
- Large ridges in brake rotor
- Lowered the GS, now I have a question
- Quick question guys.
- question:vsc,vsc off,abs light stay on
- Brake Pad Help
- E-brake light keeps coming on!!!
- A whole lotta shaken going on
- Busted Goodridge Brake Line
- steering wheel shake when brakes applied
- TRD Sways -Yellow???
- Daizen Springs Perform on Mountain Run
- 19" Axis Malano is rubbing my caliper "please help"
- Group Buy... TRD products???
- Cross drilled rotors ques: which side is which?
- Were do i purchase Supra TT calipers?
- Air Runner or Coilovers...?
- Ride Height Setting for TEIN CS V2.
- Low And In The Snow
- Tanabe DF210 Series
- Have you seen this?
- Anybody have pics(or comments) of a Tom's rear lcb and how it bolts up?
- emergency brake stuck
- Rotora Stage 1 upgrade
- Poll: Suspension or Brakes first????
- Brake caliper and bracket compatibility.
- A Thread For Those That Upgraded With Springs/Shocks And Not A Coilover
- Coilovers have a leak. Having a problem putting stock springs and shocks back on?
- Should I put the Daizen Bushings on TRD Sways
- How low do these TEINS drop the car?
- L-Sportline Springs & KYB GR-2- need others input
- ABS VSC Lights on....
- KYB's for only 230?
- What brake pads?
- trimmed the bumpstops???
- Do you have to remove sways to take off coilovers?
- Tein CS question
- missing part
- What is the best ''bang for the buck'' suspension upgrade?
- Supra TT Big Brake install help
- Anybody here do a good "budget" suspension upgrade?
- Tanabe NF210 and Bilstein SP setup
