View Full Version : Performance
- starting my research
- Supercharger vs. Turbocharger
- help! CEL, VSC, VSC OFF lights on! no acceleration...
- Gathering interest on V160 Adapter Kit for GS400/430
- lms supercharger question
- Forged 1uz rods, where.....
- wideband sensor
- 99 GS400 , Need help: Both VSC & CHECK ENGINE LIGHT=ON
- do i need new plugs
- code PO161
- How much Rwhp on your FI/SC/GTE Gs?
- stall rpm
- California emissions and S&S headers
- Long term fuel trim?
- My GS400 Borla exhaust Magnaflo X-pipe *video*
- I know you heard this before but...PO171 CEL
- Where's the Best Deal On Split Second FTC1?
- gs300 with turbo
- CEL reset question
- Torque Master Spark Plug Question
- Where can I find a supercharger for a GS400...new OR used?
- Electronic limit question...
- replacing cats with high flow ones
- Srt Intake Fittment!
- JIC Exhaust??
- Best air intake for 2GS GS3
- Stock GS400 Cams Needed
- Turbo Timer
- cold air intake gs 400
- How often to change DIff fluid
- Koyo racing aluminum radiator
- aftermarket throttle body?
- Cat-Back Exhaust Gs 400
- Hello...new to this forum. Quick mod question.
- "WS" Tranny fluid same as Type IV?
- Should I install Torque Master Plugs!!!!!
- Super Charged or Turbo Charged?
- LS400 engine compatible with GS400???
- ATF Replacement - How much??
- 2003 gs3 srt intake wiring problem
- Need to know the size of this fuel fitting (pic incl)
- 5-Series vs GS
- GS300 Starter Replacement
- LSD for 2001 GS430
- Exhaust System?
- lextreeme or rebuilt TC
- Closed Loop A/F for FI
- Injen intake owners
- How much and how hard to turbo a gs300??
- Timing belt replacement question
- need a heads up on installing TRD LSD...
- Has anyone used this for tuning? CAMCON ECU
- Fuel rail question
- Grinding Sound from underneath the car
- Drivers side has no heat
- E Vap Cannister Replacement
- 2jz-gte w/ 6spd swap in mk2 gs
- Engine Cranking slow but will not start after a timing belt change
- What do you think this is??
- quesiton on transmission flush
- supercharger leakage question
- Starter replacement - Advice needed
- Warning PI converter...
- Thank you SRT for making such a sweet intake!
- Weird smell coming from Borla exhaust.
- Finally Happened to Me, THE DREADED CRACKED HEADER!!
- Trans Cooler Advice?
- X-MAS for a 1998 GS300 under the hood
- Nomura Air Box & Akimoto CAI ???
- Turbo Kit Questions
- Fuel Hanger Twin Walbros
- Supra Block/Aristo ECU?
- Nitrous Questions
- Will Supra TT Fuel Pump fit GS?
- Turbo Kit
- Oil pan sump setups
- Questions about installing rear Borla exhaust
- Toyota Dealership vs. Lexus Dealership
- LMS Exhaust Heat Shield Issue
- 6 Speed with V8?
- Difference in TQ Converters?
- Interesting Engine Swap Possibility?
- Engine Swap
- SAFC II question
- Another Limited Slip Diff Installed...
- cold air intake or short arm intake please help
- GS400 Engine Mount
- Draggy first gear
- GS400 Idle Questions? - if someone can test for me.. please
- GS400 didn't start this morning
- CEL O2 Sensor P0155 Code PN 89465-30440???
- Ignition Help (pictures of spark plugs)
- what's a good price for a starter
- 1uz v8 motor??
- 2nd Gen Exhaust Picture Thread
- Is nitrous express any good or even worth it.
- Wideband O2 Sensor
- Tuning Gurus-HELP
- How was your intercooler mounted?
- Intake temp. on FI, does it matter?
- Turbo shot!!
- gs3 problem starting and wouldn't turn off
- Low idle issue, with a twist
- swap::aristo 2jz ???
- Borla tips
- HKS Hiper GS300
- 1998 Gs300 srt Intake, need manual
- gs400 perfomance potential
- APEXi WS PAns
- 33MPG on highway?!?!
- Borla exhaust question
- Problems with spark plug installation
- Need advice on Diff. oil choices for RMM LSD (3.76)
- Throttle PS/Cable? + BOV Questions
- V8 Turbo Kits?
- TC came in today..
- what year??
- Apexi Ws1 Catback Exhaust
- HELP, opinion needed, FI issues
- What Causes a Stiff Shifter?
- Fuel/Timing Calibrator specifically for the Lexus
- What would you choose: LSD or TC
- WHY do some GS TRANSMISSIONS clunk when engaging?
- 2JZGTE 6 speed in GS300?
- Need Help! I was beat by an 06 ES
- Intake Q
- Changing AT Fluid
- does an intake give better mpg?
- I have Oil Leak HELP
- Turbo for GS300
- Which exhaust do you have?
- fuel rails / throttle body cable / idles
- Where do I buy the supercharger?
- s/c pics i got off my phone
- Supercharger Idle??
- Timing belt and water pump
- Injectors?
- WTF? car won't start?!
- guess the exhaust?
- toyota blew my engine ... never the same again
- Cheap(er) beginning mods
- What to do ??? Engines blown
- Costs of building turbo gs
- Help!!! Starter Problems??!!
- Supercharged! (install)
- Orings for injectors
- 2parter TC/gear launch tech. 60ft. times?
- Wiring Issues
- TC and highway MPG
- Intercooler
- GS400/430 transmission strength
- K&N Filter on SRT Intake
- at what rpm does the 2jz-ge engine bypass the oil filter?
- Wiring guru's...Why can't I get this 2JZ-GTE VVTi to run!!???
- removing SRT ECU?
- Engine noise need help!!!!!!
- Lextreme TC installed. WOW!!!
- Thirteens!!! Woot Woot!!!
- Need Torque Converter Advice
- SAFC Maps?
- wiring diagram?!
- AFC and a wideband
- GS430 2001 headers Question
- Double X-Pipe?
- RMM s/c Questions!?
- POLL: Do you have the JB/S&S HEADERS?
- Rmm Sc / Safc-ii
- RMM SC Pictures?
- help me find this thread!!!
- Dyno'd today
- GS430 Header Installation Help
- Borla Exhaust Tips???
- GS400 Drivebelt
- Changed Spark Plugs
- Uh-Oh.......Exhaust leak in header area
- Help: Post Pics of your Cannons
- valve adjustment on 1UZ-FE?
- 2001 GS430 & Timing Belt Question
- Check Engine, VSC, and VSC Lights
- fuel system help
- IMPORTANT! GS-series V8 Exhausts!!
- Do resonators affect performance?
- FINALLY - Supra LSD/3.76 is in
- GS430 and TC
- Rpm idling question????
- engine ecu
- oil changes
- srt intake of gs 430
- check engine light
- Teaser for you guys
- Urgent Help Needed PI TC question same TC 400 and 430?
- Timing Belt/Water Pump/Tensioner/Acc.Belt replaced!
- SRT intake - help
- Anyone know the going rate for a GS400 long block?
- 2K GS 300 with Tranny Problems
- What exhaust and intake combo do you have?
- Questions about SRT intake for GS4
- 2000 GS400: What other short/long block are the same (SC400, etc?)?
- Why does my idle drops (almost stalls) after starting engine
- Hass Turbo Kit for GS400
- Welded Muffler??????
- Still in need of help!!
- Which Oil Do You Use
- PI Tourque Converter in 2JZ-GTE
- GS300 making a "Unusual Noise" sometimes when accelerating - Anyone have any ideas??
- S-AFC for my car ???
- TRD Headers for GS4's
- k&n filter...did i buy the right one? confused
- DIY GS430 Oil Change question......
- Need Help, Check Engine light
- Rev limit on GS400
- Need Help SRT intake check engine light-0172 code
- 03 and 04 GS TC LSD
- i Need an opinion
- Should I keep these injectors & fuel pump ?
- Motor Building?
- running rich after head job
- Lexus Spark Plugs
- Gs400 owners with SRT intake please read
- Not locking up!!
- Engine bay bling
- TRD Thermostat temp
- Frustrated..lms S/c
- TC and LSD
- Anyone running Emanage Ultimate and ESC1 - single turbo setup...
- What do you call this........?
- Boost GS3 or GS4?
- Anyone run there Gte Gs300 at the track?
- 6 Speed 06 Gs430 In Gs400
- Muffler size?
- Very Frustrated with my '01 GS430
- How do I lower the idle speed?
- driveshaft woes
- srt intake
- 2nd gen fuel system
- Synthetic blend oil anyone using it?
- Came across a BOLT-ON turbo kit for the GS400...
- Would yoube interested in...
- LSD owners... any regrets?
- Question: changing to synthetic oil!?
- what do you lose when you drop a 2jzgte
- people with fi!!!!!!!!
- Noise in power steering adjustment
- diy tc install
- Turbo heat shields/jacket
- Jiffy Lube Transmission Drain & Fill
- Exhaust
- whistle from K&N FIPK
- Im thinking about a turbo?
- Going to install exhaust cutouts
