- SOS - NEED HELP WITH GS400 Problem
- it is possible to swap motor??
- NOS Update GS400
- Best place to purchase a supercharger?
- tc install question??
- Cam gear and Pullie kit question??????
- timing belt
- any recommandation for ecu and intake system
- Good Muffler Shop in Orange County (CA)
- Dragon TC and installation
- TRD LSD Installation
- '99 GS300 Twin Turbo
- GS400 Intake Shootout
- * T P S * Question and fluctuating idleing?
- JDM - NO EGR 2jzge in '95 GS 300?
- Installing ecu?
- ??? transmissions & TC
- tc and lsd question
- sfac
- trouble with low gears
- TRD LSD installation by the dealership
- Pinging
- NOS 2 steps cooler spark plugs
- New Tranny
- Speedometer Check?
- no difference feel
- Headers being made for you guys......
- Anyone have the RMM Intake?
- GS300 TURBO & new IS400?
- Project - SRT Heat Shield Upgrade
- BUCKWILD POST UP .... Tell us about your TURBO GS .... PLZ?!?!?!
- turbo...and yes, i did a search
- Weapon R pic
- weapon r intake
- Japanese Replacement ECU? 2JZ-GTE
- Intakes
- forged pistons
- L-tuned Exhaust
- Ltuned muffler for 400/430?
- Spoke to Precision Industries (Manufacturer for TC's)
- GS Lag After Installing Weapon*R Intake
- Engine Hookups
- Engine Cover!!!!!!!!!!
- Where Can I Get An Engine Cover????
- what bolt size for crank pulley and lower timing belt cog?
- stanky smell...
- Best Torque Converter?
- Header for GS
- Jet ECU Upgrade
- Timing Belt
- Tranny dilemma
- Does anyone have pic's of the Greddy exhaust on their car?
- Wr Cab + Srt Hfi
- V6- V8 engine swap
- Tranny problem?
- Check Engine/VSC Light HELP!!!
- lable on engine says iridium spark plugs only?
- E-Shift Problem
- Pictures of SRT Stage 1 or 2 SC for GS300?
- L Tuned MP3 file:No more MS License Migration Issues
- GS300 2inch egr pipe in intake blocks airflow
- Whining Noise...Any Suggestions?
- 60k service
- Unorthodox cam gear???????
- Greddy Power Extreme Exhaust
- GS400 Headers
- 2002 Won't Start After Installing Weapon*R Intake
- Latest ECU News
- How easy to install l-tuned muflers?
- TRD air filter & Toms air filter
- Lexus Newbie..Recommendations for Air Filters for 98 GS300, please..
- Borla Question
- Plug Change-WOW-HUGE DIFFERENCE
- odd question about the 4.3L...
- Oil gelling covered with 8 year unlimited miles
- Dyno videos
- Whining Noise from engine
- All GS owners Read this!!!!
- Stalled!!!!
- 90miles/3000rpm
- Toms Air filters for a 99 GS300.
- Gs300 Tt??????
- GS4 mods
- Idle RPM
- Weapon/SRT marriage
- Exhaust comparision: Apex vs. Blitz vs. everything else?
- How easy is easy (installations)?
- RPM Shifting problem (?)
- L-Tuned Mufflers Installed - I like 'em!
- Limited slip differential question...
- SRT intake installation / Wiring
- Toyomoto turbo kit?
- TC problem.. i think..
- Need some advise on brake upgrade
- K&N Filter got me 2 more MPG
- Turbo vs Supercharging PRos and Cons?
- WTB: 2 1/2 exhaust (and high flow cat) from headers to canisters!
- can't live without a tach
- 93gs300 minus resonators.......
- Dynoed my 400!
- Remus Quad Tip Exhaust
- question about GS300 bolting on turbo..
- EXHAUST decision....any thought??
- 98 GS engine cover?
- Piggyback ECU for other intakes
- WHERE DO i GET THESE ITEMS
- Which Mod would you do first?
- Supra throttle body
- My TURBO Lexus GS300...
- I need programming instructions for my key HELP......
- Turbo for GS430
- new spark plugs
- are engine swaps legal?
- Still no JET ECU takers yet?
- weapon-r intake
- 6 speed transmisson
- Engine swap question (V300??)
- 5 Flat...
- Toyomoto turbo kit goes 10.2@137mph <for you GS300guys>
- Supercharger for IS & GS 300 from TRD
- GS Products: WeaponR vs. SRT
- Turbo GS 300!!
- red line?
- warning lights coming on-frozen michigan
- boosting gs300
- More Power Out The Gs
- Where can I get intake for GS400 1999
- Help with RMM intake install
- Q about 98-02 GS turbo kits
- LSD: TRD, Supra, Stock
- tunings options
- Check engine and TRAC OFF light stays on
- K&N Air Filter Problems
- L-Tuned exhaust on eBay...
- True Dual Exhaust
- Snow Mode
- Installed GS430 SRT Intake
- GS3 engine noise...plz help!
- Improving MPG and HP
- Help installing SRT
- Lsportline Exhaust
- Air cleaner or Intake upgrade
- Help please
- Trans Fluid of Choice
- Sticking butterfly linkage intake
- unorthodox crank pulley
- Tranny Fluid leak.....help
- ECU reset: remove fuse or disconnect battery?
- APEX exhaust for the GS400
- supra TT torque converter on a gs400
- GS 430 K&N Filter Install
- Custom Exhaust job needed
- Rough tranny shifting?
- Another Oil Question - (Much) Heavier Weight When Hotter?
- RMM EXHAUST, good or bad????
- Anyone with experience with RMM LSD 3.76?? help!!
- What device can change Ignition Time?
- K&N filter charger
- Downsides to an aftermarket torque converter?
- intercooler question?
- Is there a Turbo or supercharger bolt on kit made for the GS?
- Swift intake
- V8 exhaust cams and porting for power.
- TC question???
- Exhaust for 95 GS3
- Newbie on here
- Which Torque Converter to get?
- Lexus upgraded transmission shift control module
- How Often Do You Reset Your ECU?
- question???
- first gen GS300 vs. first gen LS400...which to buy.
- Transmission shifting
- Sound Clips of Different exausts and Intakes???
- ECU and/or SC's survey
- Wanted: Cat-back exhaust system
- Sr Hfi/ecu
- Hopefully someone here has an answer.
- questions for turbo gs owners
- Final: Injen or Weapon R
- Valve Body Upgrade
- NEw MEmber!
- ECU's and superchargers
- Expert Opinions Needed!
- Borla or GReddy?
- New hood for GS400
- Limited Slip.
- what is the best intake for GS430?
- Weapon-R ECU info?
- Has anyone used www.mileageman.com?
- Anyone have the stock dyno #s for the GS400
- Anyone done a GS300 rear-end conversion?
- Sweet A Twin Turbo 98+ Gs300 !pic!
- was the GS300 ever made a manual?
- Lexus 1uz v8 twin turbo Supra=1500 hp!
- Tell me about SRT
- My PermaCool Installed - Pics
- Valve body upgrade
- Twin Turbo GS?
- 2jz-gte 1993 Gs300 can it be done..
- Srt Hfi/ecu
- Borla
- Is that it? Intake for GS430
- converter
- Any Problems Associated with Torque Converter Upgrade?
- Torque Converter vs Limited-Slip 3.76 Rear End
- Another Proof Positive for the SRT TC & HFI
- Slight hesitation???
- engine died AGAIN
- Check engine Light came on
- Tranny cooler....
- l-tuned mufflers
- Any help please...
- Scratchy sounds
- Gs 300 Exhaust
- Steering Ecu
- Turbo, Supercharger, or the Next Generation?
- Help need Gearing info
- engine hesitation on startup
- Kinda a newbie....
- T/C Latest
- unplugging the odometer
- Intake kit for 94 GS300
- 12 secs.?
- RPM question
- Personalized License Plates - Got a Fav?
- which intake?
- Stock 2001 GS 430 mufflers
- Load% on OBD2
- Pictures of a Toyomoto turbo kit on an is300
- ** Gs Trd Lsd In Stock **
- Greedy
- Turbo for GS300
- Transmission slipping?!
- Y2KGS4 E-Shift to First Gear
- Repair Manuals?
- First time Dyno - questions
- Anyone seen this turbo?
- GS300 Exhaust Options
- GS430 T77 Turbo????
- GS400 engine and ES300 tranny?
- Greetings....important questions
- TRD LSD Question for QBranch!
- Help! shaking/misfiring engine '95 GS300
- Rumors about a Twin Turbo LS430 in town
- Help with turbo?
- 01 GS 300, looking for engine mods
- water pump failure
- ok, here are the pictures of the transmission cooler again.
- exhaust for 93 GS300?
- With new TC - Should I get a T Cooler too?
