View Full Version : Performance
- gs300 exhasut bulid help
- '01 GS430 exhaust questions
- Non VVTI Gs300 Exhaust
- Non VVT-I Worth Losing Luxuries?
- 2jzgte non vvt-i
- New gs 300
- Need advice on cheap exhaust mods
- Does anyone have this exhaust set up?
- Anyone Tried this?
- GS300 Transmission
- GS300 Resonator and Muffler Delete?
- What mufflers should I go with?
- k&n intake, for gs430?
- Latest news on my SC install
- Intake tube gains without a tune
- Parts # need help
- superchargers?
- GS430 Exhaust questions
- What's the loudest intake for the gs
- Why is the 1UZ limited so low
- New exhaust pics!
- Do we have a newbies FAQ section for performance?
- 550cc USDM Injectors on VVTi GTE
- How many of you are running oil coolers?
- gs 400 resonator removal
- ETCS failure!
- What can be done with the soft transmission?
- Where to buy 2jz
- How do 4.5" x 5" tips look on a GS400?
- desperate need of help code 24 & 31 aristo swap
- Bad cats at what mileage?
- Direct fit y-pipe..Magnaflow 24321?
- Aem 1050 problem
- how to wire in a Titan Stage 2 tranny to a 2jzgte vvti??
- Neo Start Up Throttle questions
- Mustang mufflers on GS?
- V8 headers for 3UZ-FE
- aristo swap not turning over
- Got my 98 GS400 on the dyno
- Need new exhaust setup
- Aristo vvti swap + HKS VPC: Results.
- 98 GS300 Cooling Headaches
- 1/4 mile questions
- Advice
- Need Help! Putting in a TT Carrier in a non LSD Diff
- What is your favorite exhaust system?
- Thinking bout putting a v160 into a 2gs. Any advice?
- beefing up my 93 lexi
- GS400 TRD LSD is there anyone still selling them
- GS430 Supercharger Kit
- what fuel controller would be best
- Shift Solenoid C number?
- 2000 gs400 supercharger kits?
- Why is my GS400 shifting @ 5k rpm?
- Engine mod advice? 2nd gen gs300
- 2jzgte TPS Issues
- Can anybody help?!?!
- 2000 gs400 2jzgte swap?
- 1998 Lexus GS400 Cat Delete
- PPE Headers for GS400 - any vendors?
- VVTi Aristo Swap in Limp Mode
- GS300 Running a little rich - Failing Smog!
- my 2000 gs300 is running bad
- aristo intake question
- 99 GS300 won't idle or run w/o feathering the throttle to keep it running.
- Abflug Induction box and single turbo setup.
- intake for 2000 gs300
- Help with stuck spark plug needed
- GTE Swap Sources Question
- 98 gs300 throttle ploblems. I have to floor it to maintain speed
- BEST Tuner suggestions for my RMM S/C GS4
- Code 1349 Issues
- Megan Racing Downpipe
- Throttle Position Sensor Help!
- stand alone or piggy back what to go with
- Car won't turn on (throttle body sensor issues???)
- Help on which fittings I need for my fuel pump
- Gte auto transmission
- Throttle Body making weird noises.
- 2003 Gs300 Transmission issues
- SRT's ECU kit Question
- Downpipe Reviews
- please help
- Where to by buy Polished Manifold?
- acceleration problems. please help
- Top Speed Exhaust Installed
- Any Custom Made Intakes out there?
- exhaust
- Performance Serpentine Tensioner ?
- Srt ?
- My gas mileage is poor
- Post your Power figures and Mods
- Electrical Prob....
- The Ultimate Transmission FLush Question
- 2JZ-GTE Intake Manifold Q (VVTi vs Non-VVTi)
- Gs430
- 2jzge turbo cost
- Anyone kno what trans the 1000HP GS has? Link inside
- Here is the #1 car on top 10 1/4 doing some work
- Weapon R Secret Weapon Intake on Gs300
- people that have done the gte swap please chim in!!!!!!!!!
- Rockauto Denso O2 sensor
- My GS300 at the FL2K meet.. video inside
- GS 400 Cold Tranny Issue
- Show Your Intake Setup In Your GS!
- 1998 Lexus GS400 P0172, P0130, P0133, P0150, P0153
- AC only blows cold air when on Hot setting
- need help with mpg
- VVTi cam gear/cam seal oil leak
- Next Chapter For My GS - Swap or Bolt-on Turbo?
- Need Advice
- 2001 gs 300
- Exhaust Mods - Regrets?
- code po154
- Took apart console to fix SHIFTER and now my KEY won't come out of ignition!
- Supercharger idea.. Need advice
- gs400 died, tps apps maf?
- Replacing water pump for my GS 300
- worth it to mod a GS300??
- Aristo swap into 98/99 gs300. Did not come with the jumper caps. Please xplain rewire
- transmission tapping sound
- Flowmaster Muffler
- looking for a tuner in DMV
- OBX Headers
- 2jz ecu cap problems
- 2002 Fast Cold and Warm Rough Idle
- Beluga Racing Exhaust for GS 400?
- Ecu Tuning?
- GS300 Fast Cold Idle - Rough Warm Idle
- What will these pipes do?
- need some recomendations for exhaust
- 2JZ-GE VVTi Compression question ...
- SRT GS300 Wiring diagram!!
- JeffTsai's 3rd gear sprag
- 1999 LEXUS GS 400 help on picking performance parts?
- How common is swapping in a non vvti ge lower end for boost?
- 1jz vvti timing question.
- Megasquirt
- GS400 ---> Aristo 2JZ.. Worth it?
- timing a VVTI
- aristo swap high stall converter problem
- my tranny is toast gonna do a swap and need help
- GS300 400+ Miles on full tank
- suggested upgrades from stock
- Engine acceleration problem-- HELP
- $20 Low temp thermostat @ enjuku
- Project:99' GS300 Aristo Swap
- Help aftermarket fuel rail n injectors 98 aristo
- Can I run an aristo motor only on stock wire and ecu??
- GTE non-vvti, need to get A/C working!
- Anyone have a DIY torque converter install thread?
- Question on SRT Intake
- Can I use this tuner for my supercharger?
- GS400 Transmission pan
- help
- vafc on gs400 will it work
- Injen cai installed. Now...
- Center muffler replacement
- 1999 Aristo sputters between 2k to 3k rpms
- 2JZ GTE Swap: Single manifold and down pipe
- 100K Service Pricing
- GS300 performance chip
- Lexus Gs 300
- I want to supercharge my gs300
- 02 gs300,Gte swap or built na-t?
- Intake system
- Anyone do a full dual exhaust on a GS4?
- GTE vvt-i Help
- Need help replacing motor mounts on gs430
- COLD Air intake gs300?
- Turbocharger Questions
- Exhaust question
- Exhaust question
- Choosing exhaust system or mufflers for my 2003 GS 300
- Is there a diy way to do a zero point calibration?
- Chip
- Anyone get a defective ECU with SRT intake?
- Megan Racing SC430 downpipe (y-pipe)
- 02 gs feels very sluggish and flat in 1st gear only???
- Have you dyno tested your GS? If so please post your results!
- 2JZ Complete Changeover
- headers asn Y pipe
- I need more boost
- TTE Front Lip Spoiler
- GS300 2jzgte swap temp guage help
- AEM FIC Base Tune Needed (GS300 NA-T)
- 98 gs300 accelerator problems
- possible for a gs400/430 swap into a 300
- V160 swap issues
- Low Idle in Drive HELP!!!! Check the Video
- 2000 gs300 platinum ed manual swap
- Aero Turbine mufflers on a 3UZ finally! 1 of a kind
- 2jzge ?
- Aem F/IC wiring diagram for gte vvti?
- 2JZGTE - Engine dies after MAF is hooked up
- 2jzgte non vvti bottom end w/ 2jzge vvti head
- OBX Racing headers GS
- M2 exhaust installed on a 99 gs300- kind of
- need help: na-t aem ems
- Blitz Nur Spec On Lexus GS400
- Help !!! Gear stuck in park !! Nothing works !!
- ~ Experiences with DriftMotion Wastegates? ~
- 04 gs300 srt intake ecu problem.
- FS goes in classifieds
- GS400 and SRT intake
- Please help...No more Sequential!
- BOV Location on IC piping??
- IYO stock efficiency
- Greetings
- 2jzgte leaking oil in bov help
- 2jzge-t with stock intake. EGT and any lean cylinders?
- 2001 lexus gs300 11225 magnaflow mufflers with resonator deleted?
- magnaflow 11225 mufflers sound good
- VPC with aristo swap, has anyone tried it?
- Gathering some last parts prior to SC install; have a few questions
- SAFC2 install and settings on GS430 2001
- MAP-ECU3 Questions, Concerns, ETC
- 350Z/370z manual conversion
- Swapped in my Boost Logic Trans... now it vibrares
- is it worth it to get this exhaust with stock intake?
- GTE swap help 98gs3
- Aristo swap: making the sport shift work on your GS3
- Going single - what engine management?
- 1998 GS300 P1120 check engine, VSC, VSC off
- New Member with intake question - GS430
- Beck Arnley coil packs are actually OEM Toyota coil packs
- exhaust question
- Blitz Nur Spec: Keep or Sell?
- NA-T Build
- 2JZGTE VVTi Limp Mode Help
- Innovate OT-2 compatible with JDM vvti aristo swap?
- Aristo Fuel Pump
- Useful 2JZGTE VVTi / Non VVti Information {Aristo , Supra}
- Dual pump hanger, what are ya'll using?
- Anyone with a 1 piece driveshaft
- Specs of a stock Fuel pump GS430
- 2jzgte vvti into a 00 lexus gs300 wiring help!!
- O2 SENSOR HELP!! Cant find the answer!!
- 2JZ VVT-i -> GS430 tach signal
- Auto trans A340E question has my mind spinning.
- PPE Header review - 05 GS430
- Oil Catch Can - worth it or not?
- 2.5" piping on a GS430
- Wants to buy Mazzuri Super Header (2jz-ge)
- Dyno Tuning
- What plugs you recommend on a VVTI GTE motor
- 2006 lexus gs300
- Does this look/sound normal?
