View Full Version : Performance
- What plugs you recommend on a VVTI GTE motor
- 2006 lexus gs300
- Does this look/sound normal?
- weapon R intake system
- best exhaust for the money gs430
- Need help with wiring!!!
- ~ Stock Twins Dont Clear ~
- Boso Exhaust.
- 2jzgte swap exhaust questions
- Just had my car tuned and dyno'd
- 3in piping axle back
- Official Upgraded automatic transmission 2jzgte thread
- Intakes - do they exist?
- Tuner for GS400/430??
- RPM Shifting Question
- Best performance exhaust?
- The car just hates cold starts
- JZS161 Aristo VSC TRAC ECU Part #
- Teaser of my new exhaust
- Completed jzs161 conversion, but no reverse?
- please help 2jzgte vvti swap is300
- jdm water pump vs usdm water pump
- Anyone running a GM transmission?
- Exhaust Where to look? what brand?
- Just recieved PPE Headers for 01 GS430 - Unboxing.
- Aem v2 for aristo swap tune issues (stat sync)
- ~ I need help identifying the fuel feed and return lines ~
- 99 GS300 aristo swap, throttle auto shutting down??? Help
- 99 Gs300 with Aristo Swap Standalone ?
- Intake for 99 JZS161 Aristo
- 2UZ-FE swap into a GS400
- Link for bushings and all other gs suspension components
- 2nd gen lexus gs300 mufflers or muffler delete?
- usdm 2jzge vs jdm 2jzge
- K&n fipk cai
- cooling system??? in need of help even the shop didn't take my diagnostic money
- X-pipe 2004 gs430
- GS430 - 250,000 miles
- breaking up on high boost
- solution to jdm twins overboosting with 3" exhaust
- how i made a cheap FCD that retains fuel cut.
- Manual Mode Question
- Aristo trans to GS300 driveshaft...How??? Please help
- need help with camber level on my 98 gs300
- 2JZGTE swap on my 2GS.... in 12 hours!
- Aristo swap cold pipe help needed.
- ***HELP*** In need of RMM SC Kit Install Instructions ***HELP***
- Cost of going NA-T..
- Xpipe/stock resonators/no mufflers
- OBX Headers for GS400 GS430?!?!
- Meineke just tried to sell me exhaust manifold w/ cat for $1350 !!! good deal ??
- Best cabin filters
- Retrofit GS400 intake to LS400?
- transmission question
- Manual boost controller install on JDM twins
- best drop in filter for the gs300
- Y Pipe Rusted Out
- aem v2 jumper harness for 2jzgte vvti please help
- obx header and y pipe need clarification
- 2jz get vvti swap maf sensor problem
- anyone ever try one of these Throttle Controllers?
- building and boost vs jdm aristo tt swap
- transmission options
- Gs300 manual conversion using sc300 stuff
- thinking of turboing my gs300
- Thinking about upgrading turbos on my GTE swap
- please help me!
- is anybody here doin a N/a-T setup?
- my build
- VSC ABS Codes help please
- Hi Flow Cats for 01 GS430 (NEED DETAILS)
- 2jz-gte in 98 gs300 questions looking for some answers
- how much horsepower should I expect from a 2JZGTE VVTi
- GTE swap 65mph cruise control limit...
- GS430 vs. GS400 Differentials... exactly the same or different?
- Need Aristo rear diff
- 99 gs300 SRT intake install HELPP ASAP!
- Peformance Chip
- aristo swap ppl please help
- There is a problem with my Gs 300 99
- My UZ motor has oil in the intake manifold. Sludge everywhere..
- aristo 2jzgte vvti stock intake manifold question
- 11.8 AFR is that normal ???
- r154?
- V8 Turbocharging to gain 100 horsepower
- Where to get an LSD
- need help with electronic throttle by wire
- Possibility of writing up a complete stock GTE swap thread.
- Whats th easiest way to achieve 500HP with the V8?
- ~ 01' GS430 with a 2JZGTE ~
- Lucas Transmission Fix Additive on GS430
- What do you when changing a Water Pump and Timing Belt?
- GS300 and GS400 Tranny interchangeability
- Need help ... Check enginge light
- HOW to swap a 2jzgte in a 98 gs300
- More horsepower
- Has anyone dyno'ed their stock gte vvti?
- Aem fic
- what the **** (finished 2jzgte swap in 03 sport design).
- FS and WTB posts go in the classified forums only
- Greddy EVO2 catback exhaust GS400: warning Dalmatian content.
- 2jzgte vvti Turbo info, help please
- Aristo 4spd trans
- PPE Headers, anywhere cheaper
- Spark plugs?? are they Worth it??
- Help had to abandon the car
- Fuel pump ground?
- AEM EMS V2 Help!
- Help with Idle air/fuel mixture
- DAMN!!! Has anyone been to SRT's website lately?
- 2JZGTE swap in a GS4
- JET performance chip
- TopSpeed Exhaust questions
- Fuel feed line and fuel return line??
- Intake help
- Top Speed mide pipes??
- Borla "Stainless Steel Rear Section"
- exhaust budget
- exhaust budge it.
- 98 gs300 aristo swap!!!!
- Borla Exhaust Mufflers Not Enough
- lightly smoked headlights???????????
- Exhaust help
- anyone tried a is intake on a gs?
- GS400/430 Test pipes??
- Compression test results...
- Custom Intake Shops?
- 2JZGTE swap in GS400
- HELP A340E wont engage!
- Just ordered my K&N
- Will this work?
- Duplicate thread. Please delete.
- Suggestions for First Mods
- tranny cooler AN fitting question
- SupraStore AEM computer?
- Is this Price fair for a Dyno??
- Weapon r secret intake
- S O B! Crack on BOTH headers. :(
- New guy biting the exhaust bullet for all
- Project beater gs drift *****: 2jzgte, single, r154, shave,flush, you get the picture
- How much money has club Lexus saved you?
- best gs300 intake and header?
- What is this nipple?
- Pic of my Aristo GTE
- VVTi vs. Non-VVTi 2JZGTE
- Full Cat back 2.25" custom Maganflow exhaust installed today.
- 2jz-gte vsv
- Possible Throttle Body Issue
- What to do about GTE Swap heater core clearance?
- GS300 Performance exhaust
- CEL eliminator for offroad exhaust?
- Flange size question?
- Radiator Replacement DIY
- Any one run a OBX Short Ram Air Intake on there 430??
- Quick Q for VVTi guys
- 2001 Gs300 aristo swap info?
- 2JZ-GTE VVT-i Wiring identification needed!!! HELP!!
- Intake
- Question for those who have done 5speed swaps
- 2JZ Swap on a UZS Chassis?
- drop in filter or injen kit?
- Trust or HKS drop in filter?
- K&N "open" air intakes
- K&N "performance intake kit"
- 99 gs300 swap i need help!
- Need Boosted Experts help with issues!!
- Fuel system upgrades for 1000+hp
- 2001 Lexus GS470? Just a thought.
- Newbie Question? Automatic/Manual Mode
- Aristo jzs161 lsd
- Just installed Greddy Evo2 Catback
- Hey piggybackers
- Injen Intake GS430
- Show me your Catch Can setup!!!
- Boosted GS Issues/Questions
- GS400/430 - Megan Mount Kit Petition
- 2jzgte Non-vvti swap in 2gs, don't do it...
- NON VVTI 2jzgte in GS400 swap questions
- GTE vvti swap... motor/trans or front clip...
- Muffler Pipe Diameter; is bigger better?
- Kickdown Question
- 2JZ wont make over 5 psi
- Front muffler pipe
- Help please DIY oxygen sensors gs300
- So hopefully this is my last problem WOT problem in GTE
- LMS supercharger for 430 on a 400??
- 1UZ VVTI Kelford Cams
- 5zigen Megamuffer Exhaust $700
- cam sensor help need them
- What was everyones first impression after doing the GTE swap
- Tunning a turbo gs300
- Question about this setup!
- 2jzgte non-vvti M/T swap
- 01gs300 turbo aem fic help.
- Ignition system questions
- Engine Vibration at Idle Motor Mounts
- turbo vacuum line help
- New cams?
- IPT or level10
- Anyone know this car? 1999 GS300 Turbo
- 01 gs300 turbo
- 01 GS300 Turbo Build
- Who's crazy TT GS is this?
- HELP With Oxygen sensor replacement!! Please!
- 2jz gte stock twins
- V8 Strokers??
- Short Ram Intake 1998-1999 GS300
- Where to buy 5Zigen Fireball Mega Exhaust
- GS400-Exhuast Thread Borla vs Magnaflow
- Whats the Size on the Stock Pipe Exhaust
- Newbie, winter project ideas?
- Just got my straight pipes
- 2JZ VVTI Head Question
- Hard time choosing spark plugs
- Anybody instaled a MKIV supra diff??? (I just did and had a nasty suprise)
- Photos of USDM vs JDM Twin turbos and Twin Turbo schematics with Toyota part #'s
- GS430 Better Tranny shifts just by adjusting dial?
- Looking to do a swap
- 2jzgte VVTI swap and emissions obd2 questions??
- Exhaust Crackling Noise after Driving?
- Reuse TB gasket for Plug Change?
- ISf/GSf rear bumper exhaust cutouts...link inside
- exhaust system
- What are my location options for an Apexi Neo custom mount?
- Questions for guys that ran Nitrous on their GS400 and GS430s...
- Turbo Migraine !!!!!!!!
- Hks evc-s s set up
- i need more opinions
- MrPham's Aristo Swap Parts list
- custom exhaust ?
- 16 obd2 codes on a 2000 gs400...please help!!!!
- GS400 Intake Options....?
- 2jzgte vvti swap wont start
- Yet another GTE swap question into '02
- 99 gs300 throttle
- Car have died for the 4th time.
- GS300 Aristo swap limp mode! Got 6 codes
- PPE Headers are backordered...what are my other options?
- rear diff help
- Wiring Help 2jzgte swap (indepth)
- Tell me if I'm crazy or not...
- Stock NA non-vvti rods worth it?
- Seems like its slipping into 1st gear
- What spark plugs are you guys using lately?
- Bc coilovers and fujitsubo exhaust installed!!
- can I use new ATF fluid on a 99 GS3?
- Where To Buy a 2JZGTE
- Need help with jdm aristo twin turbo
- Transmission Core Market?
- Piston & Rod Weight Comparisons. OEM vs Aftermarket!
