- Lexus IS F LED Steering Wheel Help!
- Enkei nt03 18x9.5 +40 fitment
- Engine bay tapping noise??? Rods?? Knock??
- Taller Tires
- 2008 isf glove compartment door replacement
- Hitting the track next week thoughts?
- 2021 IS F (IS 500) for Real?
- Front or rear cats more restrictive? are they the same? Mufflers a big restriction?
- All FS and WTB threads belong in the marketplace classifieds only
- Calling all paint guys we have another victim
- What do you guys think?
- Interested in purchasing Lexus isf
- IS 250-350 seats
- Performance Chip Advice
- 2008 Rebuilt ISF Thoughts
- Radiator Differences
- 2012 ISF with rear damage in 2014 but has a clean title.
- Replace passenger side direct injector?
- Max wheel/tire combo with OEM offsets?
- How long does it take for rotors an brakes to go bad from sitting outside
- Paint or Powdercoat OEM wheels?
- Headlight washer delete?
- Value of first gen Toms Aero?
- Bad PCV Valve + Upgrade?
- Bilsteins in! Photos and Ride Opinion
- Please place all for sale in marketplace classifieds
- 2011 ISF steering wheel "downgrade"
- Camber correction back to factory spec after lowering
- 2008 listed for sale with 8k miles.
- Header and Starter heat shield question
- Looking for sound clips and previous experience
- Caliper replacement or bleed screw fix
- Changing the shocks - Do really need to detach the knuckle?!
- Fun muffler delete
- Best way to "program out" O2 with no primary cats
- "Oil Catch Can" Topic for IS F
- Anyone Put a Tablet over the Nav Screen area?
- Anybody have pictures of ISF's on HRE Flow Form wheels?
- Seicane Head unit for IS-F
- Need help troubleshooting running lean
- Thank You F Family
- RR-Racing Supercharger Review Video!
- RR Racing Stage 3, Dyno Results, Exhaust Testing
- Custom Steering/Paddle shift set up
- By accident towed lexus isf on truck on D.
- Offset question
- Installed Some Post Deployment Goodies!
- Opinions on this 2011 isf?
- Dipstick tube
- Looking For Isf
- Front sway bar article
- budget for a 2011+ ISF
- UEL vs EL header inquiry upon cylinder ringland failure
- Lexus ISF vs E63 AMG
- Looking for an ISF
- IS F Wheel and Tyre Fitment Database
- Engine cuts out at 6000 rpm
- Low Load Knock on SC motor
- Help on fixing my front end
- Exhaust Sound part 2 Full Bolt- On (FBO)
- First Post! Introduction
- Installed JoeZ exhaust, car is giving a P0420 code (bank 1 cat). Coincidence?
- Coolant leak in transmission. WWYD?
- Lower Rear & Floor Brace Issues With Greddy Ti Exhaust
- Used IS-F Choices: Lightly Modded 08 versus Stock 10/11?
- isf purchase
- looking for a shop that repairs valley plate (socal)
- 1st Annual Austin F's meet - IS F's GALORE
- LEXUS ISF smoke coming from front grill.
- Savage geese review of LC 500 GS F and RC F
- It's been a good 10 years
- Compiled Coilover Information
- How to Remove Toms Diffuser
- Used 08 ISF 44k miles Price
- So who rolled the dice on this one?
- Hoses
- colorado F cruise
- Think Design?
- Carbon Fiber exhaust tip/ Burnt blue Stainless steel (Pictures)
- Hello, any one know of this ISF ? Link inside
- O-Ring for MAF?
- MAF Connector Pin is Cracked. Should I Worry? How Do I best Remove it at this point?
- Error Code after Header install
- Anyone start with a tune?
- Wet bank 2 valve cover. What is sensor between 1st & 2nd coil pack?
- Cig lighter port not working
- Sunroof Vibration when open
- Impressive Powertrain Controller Bandwidth
- Need 100HP - Best Choices?
- Joe Z quad tip exhaust restock?
- Fix for a broken shifter gate cover???
- Header/Exhaust Install Getting check engine and VSC
- Any intrest in doing meet at Lexus Dealership in Westchester County NY
- My new custom spec BBS wheels for the Supra
- OEM Body Parts
- E90 m3
- Mods on the IS F
- Rear Seat delete
- TPMS Not Reading My Summer/OEM Tires After Putting Them Back
- AC issue DTC code 24
- Where's the best place to order OSGiken ?
- Ultrasonic Blue or Pearl White
- Low Coolant affects a/c compressor?
- Manual transmission ISF
- Calling ALL USB ISF’s any years
- 4 Oil jets on the 2UR-GSE?
- Weird noise when braking
- Does anyone make a NOS tune?
- Harbor Freight Jack Stands Recalled for Risk of Collapsing
- Engine mounts
- Single Turbo ISF Build
- Is500...
- ISF Fuel Door Lid Removal?
- IronNam ISF 0-187mph
- Feedback from aftermarket transmission cooler users
- Looking for some parts
- MY2010 vs MY2011
- Squeak sound after PPE Headers install
- Someone give your ISF for Doug DeMuro to review
- ISF vs Boss 302
- Single exhaust tips (pics inside)
- Air lift Kit from RR racing
- Front Driver Side Suspension Noise
- Obd2 codes P1363 and P1365
- F Transmission Temperature at normal operation.
- Isf all vents open issue
- ISF Power Steering Failed
- Found a 2014 ISF - anyone have any info?
- CAT Catalytic Converter Recycling
- Throttle body connector issue
- Does this belong under passenger seat?
- Caught a bird inside lower grill
- ISO PPE EL header install wisdom
- 2013 Lexus IS F (USB) Video
- Does your lexus isf sound like diesel engine while still or in P?
- Installed new wheels, now I’m getting this sound
- CEL Code P0157 O2 sensor location
- A different "What's that sound" thread.
- Purchased ISF two weeks ago and this happened
- Low charging Alternator.
- ISF and GSF oem intakes interchangeable ???
- Review: 3D Maxpider Kagu Floor & Trunk Mats
- Aftermarket driver's seat no SRS codes solution
- Full functional IS F front canards
- Would you track 215,000 mile transmission fluid?
- Using water to clean combustion chamber ???!!
- Mechanical Grinding Sound
- does this seem rather cheap or about right?
- ISF header install on front jacks only
- Lexus ISF W/ RCF wheels
- Review: Budget Tire/Wheel Dolly
- Infamous Engine Rattle- significantly quieter
- MIJ Titanium Intake for Lexus IS F Video
- Lexus IS F Buying Guide Points Out Everything to Look For
- Trying to buy this engine
- Let's talk about all suspension bushings
- CF driveshaft install + magnaflow exhaust install
- 2010 Mark Levinson Wiring pin outs for line out converter
- Rrracing supercharger isf crack ringland help
- Hyerflashing stock working signal bulbs
- ISF Powerstop z23 brake pads
- 2008 ISF tachometer intermittently dropping to zero while under load
- Timing Chain DIY with Videos
- Replacement of drive shaft center support bearing???
- Been waiting..dealer not very nice
- Best Recomendation For Brake Pads? I don't go to the track but want good balance
- RR Racing tune or Sector 7?
- Lexus /Toyota Spark plugs on eBay.thoughts?
- Bilstein B6 vs Bc Racing coilovers / Tein Mono Sport (merged threads)
- Austin / central Texas ISFs
- Map light console removal
- Tires for stock wheels
- Detailed Specs of the IS F CCS-R (Specs + pics)
- USB 2014 hardtop 😲
- Noises after coilover install
- Aftermarket steering wheel install: anyone done that?
- Custom all aluminum reservoir.....thoughts?
- Exhaust Leak: Root Cause and How to Fix?
- CARTREATS.COM = SCAMMER - full info in thread
- Lexus ISF Complete owners Guide
- RR Racing "Front" sway bar mod
- So what's the correct spark plug gap?
- Low compression on bank 1
- Tommy at Music Box can fix your cracked header
- ISF on is350
- Anyone has the ML speaker wiring diagram for 2011 IS F?
- Aftermarket Exhaust Hangers
- Seat slider question
- Lifting engine to switch spark plugs
- Will Is300 seat brackets work for the ISF?
- MFR Engineering Full Chassis Mounted Aluminum Splitter Kit Review
- RR Racing COTA Track Day
- Detailing a Lexus ISF Using a Bunch of Store-Bought Product
- RR Racing Stage 3 2012 IS-F, Videos
- Gears & Gasoline ISF detail by Automotive Aesthetic 4k!
- ECU computer reset question.
- Important information to protect 😉😂 all Lexus vehicles especially 3rd Gen and up.
- Social distancing photoshoot - new titanium intake and other goodies
- '08 ISF Oil Replacement 5W30 vs 5W50
- Radio stopped playing cds check disc 1?
- Wheel spec
- 2UR-GSE Oil pump(s?)
- Disassembly of OEM Headlights
- Spacers vs wider wheels - Final Word?
- Coolant Leak
- ISF vs Mustang 5.0 10R80....40 - 180mph
- Valved Exhausts
- Lexus IS F Overtakes Rivals in Today's Market
- Bluetooth Mystery - ML & NAV
- Changing antifreeze for isf
- Exhaust smell
- Yoko ADVAN Apex v601 - new max summer tire on the block
- Common issue with 09 Lexus ISF(MY10)
- Iss forged midpipe
- 1 3/4 vs 1 7/8 header
- 2010 Lexus IS-F
- Navigation, stereo & Apple car play upgrade
- Starter issue?
- Rear 'Lexus' badge & 'IS' badge location measurement
- Advice from Data loggers please
- Pacific Northwest Headers Installer
- F front license plate
- Fuel pump recall
- Confirmed Lexus will not produce ISF in 4th gen all new TNGA platform for IS line
- Strange 20” tire combo thoughts? 255/35 & 265/35
- trustworthy car shipping company?
- UK Blog Article: A Closer Look at the Lexus IS-F V8
- What is the blue color the IS-F uses?
- Ohlins Road & Track damper settings for track
- Quick question: Do the port injectors on the 2UR-GSE use the HPFP?
- backwards compatibility- RCF/GSF engine into ISF
- Transmission mount upgrade (KEIN)
- Wheel Liner plastic "screw" part number
- Thinking of purchasing 2008 ISF
- What is the difference between Canada IS F and US IS F?
- Is this ISF worth the money?
- Isf pro/con?
- Looking to Purchase
- Research: '08-'09 (w/ lsd + suspension) or '10+?
- Anyone replaced their own valve cover gaskets?
- Engine Oil Change
- Lexus isf 2010 transmission probelm i beg the cl comminity for advice !!!!
- High miles ISF
- Lexus 2010 ISF Headlight DIM Relay Location
- isf steering assist location
- Can it be any better than this? Icode Header-Exhaust
- 08 ISF Recent Issues (Bogging / Loss of Power)
- Upgrade in Mufflers & Differential Bushing
- Heater Core Exchange and Struts
- Search has officially begun!!!!
