- Transmission issue?
- New Here.....
- Mechanic in SoCal?
- Lowering Springs Setup
- Help Identifying These Rims?
- What coil overs are all around the best for the $$
- 2014 350 exhaust sound clip
- Custom Headlights
- New wireless CarPlay/AndroidAuto for oem 10.25 screen
- alignment on lowered cars (rsr downs) - need rear camber kit??
- 2014 3IS Battery Drain
- TOMS Rear Diffuser on 2017 IS 350
- has this ever happened while driving w/windows down?
- Anyone have a rr tuned 2017 IS 300 RWD 2.0L turbo
- enkei rpf1 specs on is200t?
- Enform discontinuation workaround?
- Infotainment Unit not working
- Question about my 2014 lexus IS350 F Sport
- Steering wheel a little off to the side on straight roads - LCA worth replacing?
- Which tire size should i get?
- F sport exhaust + afe takeda pro dry
- Unexpected warning light
- Is350 axleback exhaust sound level close to g37 level
- High pitch sound when braking and car is rolling?
- Lexus IS 200t 2016 issues Pls help!
- Climate Control Not Working During Startup
- BC Coilovers install help!
- Error Code P0348 Camshaft Position Sensor A Circuit High Bank 2
- How does the 3rd gen IS hold up on track?
- Vibration on braking with drilled rotors and pads from eBay
- Excellent PPF and Ceramic Coating Info
- Rust behind license plate
- Any interest attending meet at Lexus dealership in lower Westchester county
- Timken Front Wheel Bearing for RWD
- Injen Intake for IS200T
- Discontinued tires
- can anyone identify this and if its somewhere from an IS or...
- Larger radiator options for ‘14 IS350?
- HELP! Work VS-XX fitment
- Do you these decals are off?
- Wheel fitment
- Help! Work Meister S1 3P
- Is it bad I hope the new IS isn’t super different looking so my ‘18 IS wont be old
- 2021 Lexus IS “June 9th Reveal Event”
- Oil and Oil filter deals & Oil Drain plug gaskets
- 2016 IS300 F-Sport Wheel Rash/Repaint
- Is350 rear tires-excessive wear
- Help! Rear car door won't open after removing panel - part snapped
- No Volume Control
- Prepping to sell my 2015 IS 350 F-Sport RWD - some questions
- Recharging AC?
- Help!! Volk TE37 18x9.5 +38 on 3IS
- Center Console Illumination Lights Not Working
- 2021 TLX Type S... when will the IS step it up?
- 2021 IS spied
- Rear Diff fluid change RWD
- Headlight side marker/amber light question
- New IS350, have some operational questions...
- 2014 IS250 Radio Failure
- Trunk actuator on last leg?
- Need Part Number for Fuel Door
- Battery hold down
- 2021 IS May Receive Last Naturally-Aspirated Lexus V8
- head light templates for protection - film
- IS200T - New Tyres
- 2016 Is200t ELECTRICAL FAILURE??????
- Where to connect Rexing V1 Dashcam using Smart Hardwire Kit
- 265/35/19 Tire fitment
- IS300 - which options worth it?
- 2020 IS350 F Sport
- Rear Deck Grille Broken
- Bluetooth audio playback issue
- IS 350 2015 Fsport - Summer Tire - Quiet
- Jdm headlights on Usdm f sport
- Checking engine oil levels - cold or warm?
- Base model to F Sport bumper conversion
- 3IS tensioner pulley Bearing R&R DIY
- Auto shift knob thread size/fit
- Anyone with an inexpensive splitter
- Remote wire 2019 IS300 Non ML or other source?
- Wheel Fitment
- Less Harsh, yet Still Sporty, Tires?
- IS 2017 F sport conversion parts?
- Front Bumper Damage due to a freeway debris
- 3G NETWORK RETIREMENT Oct 2022
- Will 19x9.5 25mm offset wheels fit?
- Where do you get JDM parts
- ProClip Phone Mount
- Quiet tires?
- Wheel Sizes
- Any bicycle racks recommendations ?
- Why does every reviewer seem to complain about the 3IS being outdated?
- RCF Owner Seeking IS Black Edition For Wife
- NEED 12v POWER in my 3is... what to do with no CIG jack?? 12v inverter
- MV tuning hood wanted
- Some problems came up with 2015 IS 350, can someone give me their 2 cents?
- Brakes locking up simultaneously is350 fsport
- Need some help
- Possible new purchase/lease, need some information...
- Is350 - 0 gladiator -1
- Finished custom F-Sport fog lights (helped by Edwin)
- Deer vs. Is250
- Re-skin center console lid
- 2016 is200t jack points
- Brake rotors for 15 is350
- Selling my IS350, Thoughts/Opinions? (Not a FS post)
- Does the IS350 have a transmission cooler
- Wanted to do something different...
- Torn leather repair?
- Battery Change
- IS350 100K+ Miles / Fuel Pump Recall
- Official Lexus Covid19 cleaning procedures
- Is350 2015 ac problem
- 2015 IS 250 Fsport, rotor replacement.
- Any aftermarket radio for is250 f-sport 2014
- IS250 w/ mods Buying Advice
- Lost SD card for a IS200t
- Ebay parts installed
- Clock project
- Dipping my Base IS300 Grille black
- 3IS Bumper Swap Question
- I sold my 2019 IS today after about 1.5 years of ownership
- Lease Question
- Android Display module
- IS 350 Purchase Advice
- '16 IS 350 rear diffuser install help.
- how will these wheels fit?
- 200t/300 invidia mid pipe owners help
- Wheels to run
- 3IS Fusible Link Replacement
- Best Upgrade So Far
- Anyone works at Lexus dealer here
- Front differential fluid change
- Wheel and Rim Fitment
- exhaust for is350
- Cheap headers???
- Is my shock absorber leaking?
- 2016 Lexus is350 Fsport coilovers
- Analog Clock help
- IS200t Tein Flex Z coil overs 2016-2017
- 2018 IS 300 AWD F-Sport Modification help
- Cutout Cats?
- RSR Downs Rear and Super Down Front?
- Side Mirror Adjustment
- Replacing stock tires
- Third Party Vehicle Service Contract on 2016 IS-350 F-Sport with 94K miles
- Artificial leather cracked at armrest
- Does the Transmission fluid have to be changed?
- AC Vents not moving from side to side. Dealer denied warranty.
- Part number of sticker piece on rear door
- IS200t - Transmission Shifting Question
- 2017+ F Sport- side grill removal
- Goodbye Gen2 hello Gen3
- Ceratec
- For Sale items go in the marketplace only
- Anyone try Rev9? Rev9 Axleback vs Remark Axle
- Grinding noise during start up
- Tsudo axleback for 2016 lexus is300 sound
- stuck gas door --06 is350
- O-h
- Gear issue
- JOE Z Axelback
- IS odometer rev and speed alert
- Question wiring powered sub into ML system
- Rear Wheel Sound in Reverse
- Anyone done a resonator delete?
- TRD Push To Start Button
- Camber help
- Footwell Lights
- OEM springs for 2017 IS200t
- Replacing factory 8" subwoofer
- White IS roof wrap + carbon fiber side mirrors
- Door Speaker - Wiring and Install
- Wrapped grille trim with 3M Gloss Black
- help: OEM Rear Diffuser for OEM Rear Diffuser
- Lexus IS 300/350 carplay?
- Fastest 0-60s and 1/4 Miles in a 2.0L Turbo
- Best wheel size ESR SR12
- leather/nuluxe care
- Who has a2014 Lexus IS250 f sport? I need a VIN #
- 2015 is350 AC compressor clutch not engaging
- can my lexus is200t run R19 8.5j with 225/40 tire and R19 9.5J with 245/40 tire ?
- Alignment pre and post RSR down drop IS 250 AWD. Camber opinions?
- Radio reboot instructions
- Anyone have the ARMYTRIX exhaust?
- Pinion seal leaking
- Oil change
- 2016 Lexus Is200T Fitment help
- 2016 Lexus IS300 FSport - New Fog Light Appearance
- Instrument Cluster - Black Out
- Subwoofer/Amp upgrade recommendations (ML)
- Short Ram/Cold Air Intake Recommendation
- Cup Holder Lids/Covers
- 4x Window Visors installed...few tips
- Infotainment screen, Gauge cluster plastic, and Clock damage...(lots of pics)
- Joystick Control Mouse Pointer Gone after TOUCHPAD update
- Squeaky sound coming from Front tires
- RC-F Shift Knob Install
- Vibration over 70mph
- IS250 Real World Acceleration
- Help with new wheel setup
- Driver's Seat Repair / Replacement
- Stainless vs Burnt Titanium Tips?
- O2 sensor replacement
- First time Lexus owner
- Will these wheels & tires set up work?
- New to the fray but always a fan. New to me.
- Floor Mat Part Number for 2017 IS 200t non F-Sport
- Putting front door handles on rear???
- Lexus IS Black Line Adds Some Welcome Aggression
- Tom's Power Box Help - CEL - Reduced Engine Power
- Any track 3IS 350?
- Ebay 3 piece front spilter
- anyone with 3IS in DFW??
- Any 3is members in CT?
- GPS Splitter
- Black Pearl Emblem
- Tsudo axleback or no
- Thinking about some subtle enhancements
- Raced new 2020 bmw 330i rear wheel drive
- Has Anyone Switched from 0w20 to 0w16 Oil? 2L Turbo
- Painting Calipers Question
- 2016 Is300 RR RaCing tuned 1/4 miles time
- 2015 Lexus IS250 - Invidia catback with resonator delete
- Key Fob Issue
- How to fix rock chips on the front lip?
- Has anyone painted their front grill?
- 3is 2017 rear diffuser with RC Invidia q300 axle back
- Safety Recall Notice
- Best way to secure subwoofer from moving?
- New Member Introduction
- Quad Tips inlet that fit Joe Z axle back????!!!!!
- New lower IS lease specials...
- Flashback Friday: Forum Member's 2016 IS200T F Sport
- Worn shift knob - need replacement
- Most Comfortable Low-Profile Tires
- 2014 IS350 F sport seat swap
- Missing tow hook cover
- IS 300 Grill Swap
- The Straight Pipes Review of the 2020 IS350 F-Sport AWD
- Lexus Canada Fuel Pump Recall
- Swapping winter and summer wheels 2015 is250
- Quad Exhaust Tip help
- f sport grille only out in the market?
- help adding smart cruise control
- Triple Beam swap
- Fuse identification
- Best duckbill for is250 2015?
- Wheel liner bolt missing?
