- Climate Control
- Multimedia system alerting EVERY text message - iOS 13
- Winterize Help/new to lexus
- Carb compliance for exhaust?
- Lexus IS F Sport Black Line Special Edition Limited to Just 900 Units
- Just a vent - really shocked at a few things stacking against my ownership
- HID high beam getting stuck
- Rubber Hose Replacement?
- Top 5
- Looking for AIR BOX CLEANER for my 14 is250
- 245/40/18 F Sport AWD fitment
- Wheel repair help!
- Exhaust kits
- Anybody have a gun vault?
- Chrome wrap delete tips
- Bluetooth audio issue
- Front splitter Pics
- Tire rotation question..
- BUYER BEWARE - Apexi Midpipe
- Accessory fuse?
- 3rd to 1st Downshifting
- Another spacers thread...for those running 15mm spacers
- Transmission oil change or flush?
- Atomic is350 Wrapped gloss black!
- High pitch ring/dog whistle type sound in cabin
- RSR down spring tire wear?
- Help bolt pattern confusion...
- Coolant top off
- What is this on the intake pipe?
- Nav update
- 2015 Lexus is250 wheels
- Vibration when initially coasting at low speed.
- What should I ask for my 14 IS350 F-Sport?
- Confused as hell about cabin air filter
- 2020 IS300 AWD FSport
- Non ML Rear Door Speaker upgrade
- Squared setup
- Steering Wheel control panel
- Mirror casing gap.
- Jacking Points on Pinch Weld
- 8AR-FTS Exhaust Note vs German Counterparts
- Sound amplifier bad?
- Amber Delete - Front headlight?
- IS350 Carbon Build up
- RPM goes up while braking
- Coolant Flush 2014 IS250 F-Sport 40k Miles Question
- Latest Firmware for IS350 with navigation
- 2019 Oct Bluetooth issue for iOS 13
- Coolant House Leading to nowhere?
- Help Identifying noise
- Transmission and differential oil change intervals?
- New IS?
- News just in: Lexus has no plans for a next-gen IS-F
- Why did they discontinue IS 200T?
- is350 f sport question
- Noise in front end during tight turn at low speed
- Tires: Decisions - Choices - Suggestions
- gas tank lid pops open when locking doors
- Front tires are absolutely worn. Looking to get summer tires for next year.
- How to remote start 2019 Lexus IS 300 without modifications
- Spark plug replacement
- ClubLexus App
- Paint Protector Replacement Instructions
- Blow Off Valve sound increased?
- Good deal?
- Navigation
- replacing just the front tires?
- IS F-Sport Sapphire Crystal Glass Premium Clock Factor
- What did you do to your 3IS today?
- Condensation in passenger headlight
- Your thoughts on e85, ethanol free gas, and e10 gas?
- Headlight shutoff delay timer setting
- Do you guys have aftermarket air intake?
- No Lexus in NFS Heat
- Broken bumber tab IS200t
- What do you have your info Switch Setting set to?
- Alignment settings to avoid inner tire wear issues?
- For high mileage owners (100k+ km), what problems have you encountered with your 3IS?
- Spark plugs swapped 2014 Lexus is350 RWD
- Original no spare tyre kit
- PT206-53171-02 OEM liners
- Performance chip
- Replacing aux/usb port with a Toyota’s port
- IS 200T won't start!?
- Apexi Midpipe vs Invidia Midpipe
- Nyc Tri-state Lexus meet up cars and coffee
- My lease on 2019 IS300 F Sport
- Can't connect to my IS after upgrading to IOS 13
- 16' Car Play options...
- Need help adjusting headlight - no yellow cap
- 200t - Non F Sport Guages
- Preamp signal? Where do I get signal for the LC2i line out converter
- 2019 IS 300 F sport added OEM spoiler and debadged (opinion?)
- 2019 Lexus IS 350 Fsport muffler delete question
- Best Aftermarket F Sport bumper conversion link?
- Backup Camera Stopped Working
- HVAC gremlins when raining
- Thoughts on Door Panel Removal for Tint?
- Threw a Code. P013A.
- Transmission fluid exchange
- Newbie Needs Help
- 2014 AC Issues 160k
- Tires
- Check Hybrid System
- Display, audio, and usb not working in 2014 IS250
- delete
- Needing Reassurance wot Bad News: Friend Slamming Door
- iPhone music bluetooth search
- Rear camera options with tinted windows?
- Strange noise linked to AC
- Hard Downshifting
- F-Sport Gauge Modification?
- Drivers floormat hole
- Lexus is200t side mirror courtesy puddle light
- 2016 is200t turbo replacement help
- Chirping Noise from Engine Bay
- New wheel
- Floor Mat Opinions
- Spark plugs and other maintenance
- No Sound At All, AMP says NCON
- Could use some help please
- '15 IS350 FSport RWD vs '14? Chevrolet Camaro, trim: unknown
- Anyways to Tighten Rear-view Mirror Joint?
- Does 2015 IS have adjustable camber?
- New car 1600km checkin service
- Software updates
- All of the rattles are causing me to grow to resent my 2019 IS
- 2014 IS350 AWD, Got a flat tire, is replacing one tire ok?
- Which year IS 350C
- No digital clock (solution)
- 2017 Lexus IS rear end swap to 2016? Seibon trunk Fitment?
- My iPhone keeps disconnecting
- Voltage Regulator failure?
- Lexus IS250 pre-purchase questions!
- Custom drl power source
- Rev9 Exhaust
- 2014 seibon rear spoiler on 2017 Lexus IS350?
- 2020 3IS Availability
- Could the 4IS draw design cues from this new 2021 Mirai??
- TPMS Sensor Compatibility Questions
- HID Flickering question
- Water behind door 2018 IS300
- Does the F Sport brake pad TSB replace F Sport pads with non-F Sport pads?
- Found oil when changing spark plugs
- Installing RCF exhaust on 2017 Lexus IS350?
- Starting her back up after 3 years
- Concavity on +15 offset vs wider rim?
- Phoenix AZ area
- Claying Car Question
- Tirerack says 18" rims must b staggered
- WTB Obsidian Touchup Paint
- Final coat of the season
- 2014 IS350 No Power
- Looking to getting a IS300 F Sport by leasing
- Lease: 2019 IS300 F Sport
- Winter tire set up for 2016 IS350 F Sport AWD
- RC Axleback exhaust fitment for 2017 and up IS
- Car lost acceleration on steep hill
- Tune or wait for a turbo upgrade?
- 2020 IS....what a dissapointment
- 200t 8AR-FTS Intercooler Coolant
- 2014 Lexus IS250 Aftermarket Stereo Install...?
- Lexus embraces the darkness... new 3IS blackline edition (pics)
- Wheel Bearings
- Screen keeps restarting!!! HELP
- Skip TPMS for winter wheels?
- Bluetooth iPhone Issue
- Winter tire question for 2019 IS300 AWD FSport
- Broken Axle
- Name of this Spoiler
- changing battery - need memory saver?
- Wanting to get a used Lexus questions about reliability
- AWD Tire Specs question
- Seat cooling
- New Supra recall by BMW...you get a new car!
- Looking to purchase
- Safety Connect remedy notice
- Is200T 2017 Fsport new owner
- Exhaust Comparison
- Black Line Edition........not?
- Atomic Silver IS!
- 2014-15 IS350 Luxury package question
- Cyclical front tire noise, very noticeable from 20mph to 30mph, What should I do?
- Music Bluetooth keeps disconnecting after updating iPhone to iOS 13.1
- F-Sport leather seat wrinkles
- Why does this brake noise keeps happening ?
- Check Engine Light - Vacuum Leak or Worse?
- Check Engine Light - Vacuum Leak?
- Trunk liner issue
- 2015 IS 250 with Muffler and Resonator delete
- New or Used IS350?
- Lexus IS Regret?
- Sunroof won’t close?
- Lexus dealer service department change?
- TE37 Fitment. PLEASE HELP!
- Car Won't Start - Ticking Noise Around Instrument Cluster
- My 2014 IS 350 Amplifier is Toast. Does anyone know cheapest place I could buy one?
- Confused with Tires
- Paint TSB/Recall Letter
- 2018 Is F-Sport TRD style front splitter
- Part # for rubber stoppers in center console
- Contact Photos Not apearing in my 2014 Lexus is 300h .
- Lexus is250 f-sport 2015
- Solution to F Sport Tire excessive edge wear
- IS 300 Fsport AWD
- Voice command question - shorten instructions?
- IS350 F-Sport AWD - mismatched tires
- Anyone run 17s for winters on FSport?
- Techstream
- Scraped front bumper?
- Oe wheels
- Anyone try these carbon fiber accents?
- 19s vossen vfs1 19x8.5+32 front 19x10+48 rear lowered on bc racing
- Auto fuel shuts off when not full
- Rear wheel well decal or sticker
- Fog Light Installation in SoCal
- Midpipes
- Need New Battery?
- Found a power-folding mirror kit complete with motors...
- Blank accessory panel buttons
- Lexus IS250 F Sport aired out!
- Transmission and Rear Diff fluid change - '15 IS350 RWD
- help with TRD style parts for 2018 f sport
- Tire setup to kill understeer
- No air in rear vents
- Question for those with RSR HALF DOWN Springs.
- HOWTO: easy dashcam install through dome light cavity
- Project Kics vs Muteki lug nuts vs Whatever else - does it matter?
- Suggestions for a phone holder?
- Latest Lexus Recall
- Canada - IS300 AWD F-Sport 2, compared with 2019
- IS200T Transmission
- New 3IS/IS 250 Owner - What should I expect?
- steering issue
- AC not getting cold in morning but fine in afternoon
- 2014 IS350 - My Stereo Has No Volume
- Lowering Spring estimate crazyness!
- Chrome Chrome Chrome
- Lexus Parts Shortage
- Brake pads 2017 IS200T F sport
- 3rd Gen LSD
- is it bad to fold the side mirrors every day?
- Lexus IS300 OEM Screen Replacement (Knob Control)
- Dual Dash cam install
- Clunking sound when turning right into drive way
- 18' IS 300 getting stuck in 5th gear
- F Sport steering emblem
- 2014 IS350 - How Long Should A Battery Last
- No Siri feedback?
- USB ports not working?
