- footwell & glove box light bulbs
- LED backup lights for sc430- what fits?
- Rx8 spare donut.what year works sc430
- Coilovers suggestions
- Have a safe Memorial Day weekend.
- I lived!
- Well, that was embarrassing!
- NJ/NYC Pre-Purchase Inspection mechanic?
- Toyota Corona + Lexus SC 400 = Frankenstein Hot Rod
- Steering wheel control in bumpy road
- Crankshaft Position Sensor
- Tire recommendations.. Please help!!
- Thought I would share my extended warranty story
- What's that Blue Connector over the rear wheels?
- Guys, need a little help here. VSC on with overheating
- Update Rear Lights
- fuse box door (drivers) watned/vibration at idle
- Brake pedal travel ???
- Quick question ???
- Passenger Side Speaker Rattle
- Transmission fluid leak
- Timing belt Service 2016
- Garaging advice needed
- Ashtray & Cupholder mod
- Guidance Needed - Suspension Mods
- 1. Slightly lumply idle 2. Slightly impossible part search (Driver's side fuse DOOR)
- where to buy??
- Poor Man's Aux input
- Speakers - Repair or replace?
- spare tire
- FS threads go in the classifieds only
- The Daily Moment of Zen
- Throttle responance ???
- New Member / New Owner
- SC430 with airbag deployed. Should I buy?
- Class Action Lawsuit for 30 select states
- Warning Lights On
- Under Body Cover 2
- Audio Amplifier
- sc430 TOP PARTS LUBE
- 5spd transmission drain & refill
- problem with Battery Tender
- Dvd screen
- My "New" 2006 SC430
- Upgrade a 3.1 nav disc, 2002 430 SC
- Top problems, new owner
- Low miles 2004 opinion request
- 2005 430 light leveling system sensor
- ANY REAR PASSENGERS 2nd Generation SC430?
- Shifting the sc430 trans (new owner)
- Good video for us SC430 owners (Happy Friday)
- Radiator/ Engine Coolant Flush
- Sc430 wheel fitment suggestions
- Warranty for an SC430?
- Navigation is not locked out?
- Headlight bulbs
- OEM Wheel Covers for an 04 SC-430
- Discoloration on nav screen
- Anyone know (?)
- 2006 Toyota crown bumper on a sc430?????
- New guy spare tire question
- Second one
- The number one picked timing belt kit?
- Confirm my 2004 sc430 nav software
- How to change oil control valves
- 2008 Pebble Beach?
- PPE Headers not CARB approved
- Top wear and tear??
- SC430 - VSC and Engine Lights on - Should I purchase?
- MPX-IG fuse keep burning
- New owners nav question
- Detroit Axle Front Suspension vs. SuperPro Polyurethane Parts
- Humming or buzzing from backseat 02 sc430
- Buzzing noise from backseat of my sc430
- Lexus Sc430-Bad Fuel- Not Bad Coils
- "Electronic click" sound upon start
- Broken Latch on Coin Pocket Cover
- Question for members (please)
- will these wheels fit
- Is this a fair deal?
- Check Engine Light with P0440 code
- FYI - Loose lower ball joint bolt
- SC430 Plugs & Coils
- Top will not open
- Squeal from Brake Fluid Reservoir area
- SC430 Exhaust Systems?
- Stock 2004 SC430 Dyno run - 236 HP 278 Ft LBS
- Climate control head unit 2002 sc430
- Hard to find parts diagrams with OEM part numbers...
- Tilt on Nav screen
- IPhone 5S pairing issues
- The scammers emerge on my buddy's sc430 for sale ad....
- SC top failure after accident
- Dents in wheels - constant vibration
- New Rear Brake Pads and Rotors with strange issue
- Ride Quality, 2002 vs 2006
- Tachometer Needle Sticking
- Cranking oddness
- SC430 with 19x11 +15 275/30/19 all around
- 06 Sc430 Intake?
- Led headlight
- Hub Centric Rings
- V vision front bumper needs grill asap
- sc 430 mag and tire size
- Tire wear question
- 2jzgte Motor swap time for the Neiman Marcus sc430
- Air / Blower running more frequently than usual
- Wheel size
- stock wheel paint
- looking for a more modern screen to replace the nav screen
- Wheel pie pans
- Little incandescent bulb in the high beam
- Sub-woofer
- leaking coolant
- Looking to buy Rim center piece for 05
- 2002 sc430 trunk and hardtop issue
- Mark Levinson Speakers
- How-To: Disassemble the Climate Control to clean/Replace the window
- Thinking about going from 18 to 19 rims
- wood dash trim
- Performance tunes
- 3m Bra's for SC430
- recommended pads and rotors please.
- 2002 sc430 suspension
- techinfo.toyota.com - get it cheaper!
- Engine ECU pin for RPM
- P0125 - low temp issue Sc430
- Convertible top problem
- 2092 instrument panel out
- Tech Stream Software Cable
- In a Quandry: Keep Old Radio/Nav vs. New Radio with Nav, Satellite, etc.
- Stock telephone/mayday reverse engineering.
- 2002 SC430 Gauge / Radio / climate control Backlight Question?
- 2004 SC430 Wheel covers
- One last try before I die
- I've started a Blog
- Unconnected connector
- New Owner 09 SC430
- Siping Michelin Pilot A/S plus (3)
- How many miles is too many?
- Need head lamps and all small out side stuff ...
- Is this a stock Sc or body kit? :)
- Sirius radio
- New member
- Intermittent Beep
- Questions on this vehicle
- Reverse engineering the Newtork Gateway ECU
- My 2006 SC430 was just destroyed
- "Oil Leak" and "Transmission Leak" - How Serious?
- question about windshield
- Gutting the ML sound system...
- Just Purchased 2004 SC430...what next?
- Various ECU Pinouts
- Are there different shades of white different years?
- Any other engineers in here?
- screen saver for nav
- Relatively new member
- Brake squeal
- Suddenly, Airbag light
- Time to say Goodbye SC430 Neiman Marcus Edition
- My review of the SC430 got published
- looking for Lexus mechanic in Culver City area
- ABS Sensor
- Sc430 build ...
- Rear trunk struts
- Lexus LS460 question
- Front Lip
- Happy New Year
- Uhm...what the heck?!!! Power mode is awesome!
- Radio door
- Who has the LOWEST MILEAGE SC?
- New SC430 Owner cosmetic help!!
- Daily Driver Club - SC430
- radio butons stuck
- Odd little problem with pass door
- Tech Stream Software Cable ver 2.0.4
- now what to do shop accident
- TPMS - Any point in keeping it "plugged in" if one sensor battery is dead?
- P0051 together with VSC and VSC Off Lights
- Possible for coolant to leak into the gearbox?
- Where is the TPMS wheel set selector switch on a 2007????????
- After all these years , the SC ...
- Convertible top problem HELP
- Lexus Link Missing
- Screeching noise
- Moisture behind screen, clean???
- cabin filter removal question
- Lumbar seat button
- Odometer Fraud
- Front Lip
- Aux or Bluetooth option?
- stupid question coin pocket
- Overheat problem
- Barret Jackson
- navigation disc stuck
- Guy complaining about no heat
- convertible top question
- Who makes these Chrome Wheels?
- Trunk tool cover
- new owner finally questions
- Navigation system
- New Michelin A/S 3 +
- Wheel Straightening (SC430 OEM Rims)
- Found the good DRL
- New on forum
- Is this a result of dealer overfilling Radiator??
- Question re navigation
- Passenger window control failure
- What scanner to buy
- Back up camera
- Took the SC out for some excercise. Came back with some toys
- Adding audio input and backup cam to 2002 SC: 2016 Advice?
- Knock Sensor Check Engine Light?
- ATL-Georgia Spring Meet
- Putting the HT up/down when out of Park
- Rear window rubber moulding
- Improving the appearance with the top down
- wiper button?
- Aftermarket sub amp problems
- help!!wheel bolt pattern is so stressful.
- Fuel Injector Cleaning on SC430
- CTEK battery maintainer install, and wire routing ideas?
- How to replace the rear brake, signal, and reverse bulbs in the SC 430
- LC500 Soon?
- Paint types
- Replaced Foam on ML speakers
- auto leveling headlights
- Front seat leather replacement
- LH headlight
- sc430 starter noise
- Radiator Leak
- Cup holders
- Local SC430's for Sale
- Let's play the picture game
- Best non RF Tires for SC 430 ?
- Weird Electrical Issues on 2007
- Acceleration Issue? Any thoughts..
- Electrical Modding Tips - get learned here!
- water pump
- Fun Thread? - Pick a (weekend/evening) mod/project for someone else!
- Getting closer - Internet (and vehicle control) in the SC
- sensor questions
- Repair help
- 2002 SC430 Lifter Noise on Startup Goes Away
- wheel size
- thinking of buying an 02 sc430 questions
- Lexus/Toyota Brand Wiper Refills, 05 SC430
- Do your side mirrors automatically retract?
- Ventilation system - Need some help
- Proud owner of black 02 sc430
