- You Light Up My Life??
- Which rear bumper can accommodate quad exhaust?
- Pics of my SC430...finally with some mods
- Seat bracket?
- Gas Mileage on SC 430
- Warranty Service at Dealer or ?
- SC430 Common Problems, if any?!?
- brake pad spring pic please!
- Some Photos
- Roof bumpstops whats the trick
- Nav Touch Screen not working?
- Washer Fluid dripped in the trunk??
- What do you think of Drill Slot rotors?
- sc430 wheel bolts size
- Metal Shavings
- What springs do you recommend.
- LED Clear Corners & DRL's
- Water Water Everywhere!!
- What kind of lowering springs do you recommend for the SC430
- camber kit??
- Windshield Washer Fluid Tank.. Need some help
- finally got some pics
- Will rims off a Nissan 350Z fit Lexus SC430
- Donz 20 " rims offset ?? Is mt set up OK
- What is the offset for 02 Lexus SC430
- Thoughts on this wheel setup?
- 350Z or G35 exhaust installed on SC430
- Looking for clear bumper lights for SC430
- Trunk Lid Scratches Bumper on Top Down
- A/C Light Flashing... No Cold Air
- Lexus Roadside??
- Which model year of the SC430 do you deem best?
- Can too much air be a bad thing?
- TEIN Flex for the SC430
- Sc430 & Pioneer AVIC-Z3
- The IS Folding Hardtop Convertible is on its way
- Valve Stems for SC430 rims
- Problems w/Iforged wheels ??
- S&S Headers
- To buy or not to buy, . . .
- hit from behind, now roof won't open???
- Need Help! Radio-vol/bass/tre/mid/fad/-will not move.
- Oxygen Sensor Removal
- 2002 sc430 does it have the baby latch system?
- American Specs vs GCC specs
- Blacked-out grill
- Almost finished
- My Best Friend = UPS ! :)
- Houston we have a problem!
- sc430 radio/cd player defect
- For you SC guys...
- Broke the Climate Control Display Cover
- Lights stay on even if car is off
- stock electronics recap
- Painting rims
- Slow dead steering
- 20x9 Front & 20x10 rear Lowenhart BR5's
- Abandon My Lexus? Or Wait?
- Lexus SC430 Print Brochure Archive
- I'm in LA. I'm lowering my car. Can someone recommend a $$$reasonable$$$ place to go?
- Heater sensor 2 band 2
- Levinson CD Changer
- Which wheels do you prefer
- Getting Thirsty??
- Aftermarket Reverse Backup sensor install
- Do you have wear marks on your nav screen?
- Lowering Car need Advice
- Front Suspension Graphic?
- What's the best battery replacement?
- Plugging run-flat tires
- Clear Corners
- 2009 SC Pebble Beach Edition
- Removing the allen bolt from the pie plate wheel cap?
- Synthetic Oil
- P0155 Oxygen Sensor
- ECT- Power or normal
- Drilled/slotted rotors question
- brake clunk specific question.
- Visor Plastic shaft Broken
- Navigation Hood
- Window Problem
- Off Set for Rims SC400 Rim Fit on a SC430
- will these wheels fit?
- stock runflats, any value or just toss them?
- Aftermarket rim suggestions?!
- NorCal SC430 "Drop Da Top" Mini-Meet Poll
- Telescopic steering wheel squeals
- wheel offset 40 vs. 45....any big difference?
- Anyone Want To Swap Their Wood Trim?
- autocouture kit
- pie wheel cover alternatives
- Are there any wrecked SC 430's out there?
- passenger seat won't recline
- Lexus Serivice Day- Post Warranty
- Help with spoiler?
- Long Term Purchase...Good Idea
- stock to drop???
- Digital Gauge Cluster
- Only in Las Vegas (I hope)
- Ride Quality with 20" Wheels
- What shocks for Tein S-Tech springs?
- Rattling or Sloshing?
- Hubcentric Rings
- Extended Warranty Query
- NorCal SC430 Mini-Meet?
- iPod in an '06
- Quad Exhaust Pictures
- New guy has a question.
- New Model
- Rim Rash Fixing - Note to PB Owners!!
- Quarter window mod part deux
- are coilovers an easy install?
- Non runflat tire opinions
- Wood Navigation Cover.
- Job Design Rear Bumper
- Auto Retracto Antenae
- How is the market for sc430 these days?
- Staggered Tires Sizes For The Sc 430
- Automatic Windows
- candy red 05 sc430 with 20" staggered
- Dents in Roof
- Cables/Connectors above front wheels??
- Rim Scuffs-Fixing & Color Matching for PB??
- '02 with Loud Popping Noises and Volume High on Radio
- Ls & Sc Tranny
- Audi or SC? Pls help
- Differential fluid replacement?
- Transmission Shifting Prematurely
- Ebay chrome grille kit
- Little known tips/tricks for the SC430
- big problem help
- Run Flats And Its Options Query
- 2008 Golden Almond SC Rookie Question
- Run Flats Out/Sumitomo In!
- Windshield fog
- Speech Command System & Lexus Link System
- navtool issue big time.
- Sc 430 Driver Seat Problems
- Emergency Tire Inflators/Sealant - Damage TPS sensors?
- Will this spare tire fit my car
- how much should paint protection cost?
- Brake Pads/Serpentine belt DIY
- Visors shake during top down driving
- almost finished
- Roof opening closing problem SC430
- How bright is your Nav & Instrument Display?
- Bluetooth Handsfree Car Kit for 2002 SC430
- interesting scenario
- Miles and Metric in the Maintenance Schedule
- Replaced 2 rear Tires and VSC is Activating!!!
- Door Panel Removal
- 06-08 Wheels
- AC condensation Drain Plugged?
- Eletrical problems?
- Got my Rotora BBK 6/4 pot
- coilcovers
- Conversion from U.S. to Metric (Canada) Options
- ran flat without runflats for two months!
- White car. Black wheels. Thoughts?
- Vertex Digna Kit
- Rusted Rotors
- Trunk Hard to Open - is it the Struts?
- Door windows rub against roof
- Replacing break pads in 04' SC430
- finally
- Where does this go?
- Traded in 05 SC 430 for 08 Corvette
- 20"
- srt
- radio problem (weak signal)
- Need a little help from SC430 owners
- Changing the antenna
- ODB-II connector and protocol
- Update on Replacing SC430 Trunk Lid Closers - Struts
- Are headlights covered under CPO?
- Whats the best deal, 2002 with 65000 or ?
- 30K Fluid flushes on a 05
- 12000k
- NAVTOOL- Did a little searching around.
- 02 SC430 wood kit (CHANGE)
- 4.2 ver navi
- Nav system upgrade.
- Cpo Question
- How Wet is Too Wet?
- Streaks & Squeaks: Window Streaks & Steering Wheel Squeak
- Finally some pics of my SC430 & some other cars.
- SC430 Owners Wheel Size/Offset Roll Call
- A Big Rig Hit me, what to do next? See PICs
- 3rd Annual NASCAL ***CHANNEL ISLAND MEET***
- Only guys read/participate in the forum?
- Hard top wont open
- Good deal on 05 SC in Central Florida
- Traction control automatically turns back on.
- falling apart
- suspension help
- SC430 and California Emissions
- Rear Side Marker Lights
- SC430 wheel spacer/adapter Advice
- Run-flats
- Spare Tire Kit Installation Help
- Removing SC430 Door Panels
- Corner balancing and convertibles
- So I decided to keep my SC430...now what
- What should a alignment cost
- Thoughts on selling my 996 cab and keeping my SC430?
- CD Problems
- Alignments, How often should it be done?
- LED Puddle Light + dome light upgrade!!
- Wheel Dust Covers? anyone have them?
- Pirelli Nero Run Flats -H rated
- SC430 headlight warning light
- Cl500 vs SC430
- New "05" owner with runflat question...
- Need more specific Luxlink help
- Do people still comment on your car?
- Front "Y" pipe...anyone other than Tom's?
- reprogram the ecm?
- Price Advice
- Can just one TPM be registered?
- wheel prices
- Need Help 2002 SC430
- Sirius radio install
- Passenger mirror inop, at times.
- General Question
- $1315.00$ for 60K Mile Service? Good Price????
- will these wheels fit correctly?
- Lambo or Scissor doors for SC430?
- tpms
- Jack and spare tire
- Any ideas on custom stereo systems?
- what do you guys think about this deal
- Luxlink Operating/Install Problems
- Just some new pics
- Does the 02' model year SC430 have any 1st year car bugs?
- Illuminated scuff plates, which model year started having it?
- need help on tire and rim fitting
- Brake Warning Light Comes on
- President's Day Weekend Meet, Sunday, February 17th, 1PM!!!
- stock rim specs? thanks
- Some Simple Luxlink Questions
- New Ipod Option for older SC's
- Camber kit finally out
- iPod Connections
- Air Pressure Sensors and wheel balance
- 2nd Gen GS Coilovers on the SC430?
- 3rd Annual NASCAL SC2.....?
- Kumho Runflats?
- 2002 Struts
- Inexpensive way for new gears w/o LSD?
- Anyone know how to take out the Stock Sterero on SC430?
