- Flashing 3rd Brake Light
- Whooshing sound - mostly 30-45 MPH - help
- Whining sound after engine turned off
- Touch of Class Paint Protectant
- Get to the next light quicker
- CAI 2004 and newer SC430
- How to find where the junction connectors are
- Vacuum Hose Replacements
- End of TPMS issues?
- Cheap bucket seat cover
- Resurrecting 2003 SC430
- Question for those with aftermarket stereos RE: rear speakers
- Default FIGS FIGS Engineering site: https://shopfigs.com/v5/
- Drive Axle (2005 SC430)
- 7,500-10,000 Mile Oil change Schedule?
- Headlight washers
- Running a Lexus SC430 on LPG
- They are going to screw it up!!!!!!
- Battery drained by trunk?
- Front Speaker Replacements
- These cars are just NOT reliable.
- Flip Keys
- Motor Mounts
- Electric antenna
- Front lower ball joints replacement
- Sc430 2002 huge stumble and pulling my hair out.
- Belayed intro
- Exhaust modification
- Bluetooth adapter for an '07 SC430
- SC430 Fog light diagram & parts question
- New purchase 2002 SC 430 with roof issue
- bluetooth adapter
- Tpms
- Is my window moving?
- Help identify
- Front Rotor Replacement Thoughts
- P0974 - Solenoid A?!?!
- 2002 sc430 radio issues
- Smooth coilovers, Not wanting increased NVH.
- The SC history
- 2003 Lexus SC430 Looks Like a Proper Bargain
- Front passenger net pocket
- Length of Windshield Wippers.
- 2005 SC430 On Mecum Auction just now
- Simple aux input for 2003 sc430
- Update DVD Navigation
- Vacuum Hose Diameter
- PLS. ADISE ASAP:check enf. light=failing t-cstlyst--pipe or new/used?
- Front Speakers Direct Swap
- 100 thou maintenance?
- Stereo not working
- 2002 Lexus Magnaflow exhaust
- Windshield Washer button does not work
- Full size spare tire question
- TechStream cable firmware Ver 1.41
- The test drive !
- Sc430 06 need help on ecu compatibility
- Warning Lights
- P0031 is a good DTC?
- Shocks/Struts
- GPS/NAV help needed!!!
- Power steering air control valve
- Looking for Discontinued Part #88650-24340
- Where does one find rear trucnk/boot struts cheap?
- New member
- Wiring Loom Help required
- Front speakers.
- High beam / DRL LED replacement?
- 2002 sc430 no crank no start gateway codes security not detecting key
- Jalopnik Nice Price or No Dice has 430!
- My sometimes headlight and horn
- Alternator Failure 2007 65k miles
- Steering wheel noise
- Plastic Engine Cover
- Bad Amp?
- Knock sensor issue
- weird carfax on sc430 im looking at
- Complete Brake Failure on 2002 SC430
- Since it didn't come with a factory spare, here is a Tire Plug comparison
- Rear Speaker sizing.
- SC430 2005 Front Bumper Washer Nozzle cover
- Lexus SC430 Limited Edition
- SQOD - Stupid Question Of the Day
- ABS relays, fuses and module – SC430 ELECTRICAL HELP
- Bleep sound
- O2 sensor rexset
- Oh my baby !
- Front Shocks for '06
- SC430 trunk spare tire cover!
- Change out radio/gps system??
- Tower brace on 2006
- timing belt replacement
- pebble beach or neiman marcus for sale anywhere?
- Help with headlights
- Finally Sold My 2006 SC430
- Eng lite:Code PO440 evap emission system:
- Leather dye for seats
- Selling my 08 Pebble Beach
- key internal electronic buttons dead..$$?
- Another Shock/Strut Question
- Why is this?
- any way to change blinker volume or lane change threshold indicator
- New guy here with questions
- Purchasing a used ECM
- 2004 SC430 value
- Brakes squeak in reverse
- Anyone with an 08+ -- Headlight Question
- Odd Response From Coolant Temp Gauge
- Cig lighter splitter
- Driver side window switch options
- Drivers Side Door Lock not working
- SC430 UK Meet 2021
- Tinted headlights?
- Window Tint. Easy Removal and tip when installing that may get you a cheaper install
- Remember the Total Brake Failure Discussion?
- Oops
- Can you drive with Passenger Seat removed.
- Roof maintenance / lubrication
- Rear Hub/Bearing/Rotor
- Air conditioning failure
- SC 430 spacers.
- front brake noise
- Clunk frum under driver side solved!
- stereo/navigation installation
- Trunk release button & top retracting
- Like a mirror
- Timing Belt Replacement Tricks
- Can Nav be updated 07 SC430?
- Interior Swap
- Oil leak, is this rocker cover, camseals or?
- USB/Aux Adapter for 2003 SC430
- Dented oil pan
- Antenna conversion kit
- Used car values
- How to adjust wiper arms?
- Anyone replace the steering box bushings?
- PSAs: spare tires & spark plug replacement
- Sc430 help
- Noises and sources
- Navigation screen cover closing intermittently. Tilt stopped working
- Steering Wheel Vibration (Yes Another One)
- Roof Problem! Help!
- Back from the grave!!!
- AH HA! So this is what a 4 wheel alignment is
- Choosing an ODB cable
- What is the cure throttle lag?
- great price at Cars & Bids
- Blend door motor?
- What hat to wear while driving top down?
- Lexus OEM Remote Starters?
- Computer Issues
- Timing Belt
- "compact spare"?
- Program a key
- DTCs for lean condition (P0171 &174)
- I just dont get it. (rear shock confusion)
- Rear view Mirror (inside car)
- Coilovers...Shociks...Struts 2006 sc430
- Antenna replacement
- VSV attached to air inlet Code P0440
- Paint or replace front bumper cover
- top doesn't finish open process
- Roof issue
- Buying strategies
- My SC430 audio system replacement
- Door speaker plug
- Removing back seat from SC430
- Considering Moving On... Talk me out of it! ;-)
- Anyone else notice this 'problem'?
- What is the mileage of your SC430?
- light new mods
- Converting power antenna to fixed - 2002 SC 430
- Rear emergency trunk release - help with removal?
- Passenger window switch
- Replacement 6x9 speaker
- old nav has lost its way
- 2002 sc430 top question
- Passenger seat occupancy sensor
- Nav Screen door will not close
- rack mod and shocks
- Alternator plug diagram
- Can your SC430 do this?
- Noise undersneath?
- Audio System Makeover
- finding a SC 430
- Did Radio Work - Having blower/AC Issues now.
- The drivers seat belt is twsted
- access point to what?
- Drivers Side water seal being pulled into the door
- SC430 2005 - Dimming Lights Inside Cabin
- SC430 Door Locka
- Roof trouble
- roof won't disengage from header
- General interior cleaning
- Sc430-2007-$16,000
- Battery bracket hold down
- Shifting for quick acceleration
- Paint protection for the hardtop
- TPMS Question
- Rim size and offset HELP!!!!
- quick ship
- Sc430 Rims
- Sc430 Rims
- How long did your battery last ?
- Are Tires in short supply??
- Air Bag recall
- 2002 Nieman Marcus Edition For Sale
- Using U-haul car trailer
- Lazy Windshield Wiper, any ideas? Motor? Switch? Controller?
- Car Completely Dead
- 2007 SC430 Tai light
- Gear Board Shift Cover Lights Turning On and Off
- Got NAViKS- ask any questions here :)
- Mechanical Checklist for Used SC43
- Happy Father Day
- Replaceded Hard Top Package Tray Today
- An Interesting Video about Techstream
- Building techstream system
- Any recommended sc430 shop w.in100mi of Boston
- A fattie or two at the wheel-suspension bottoming
- Sold my SC
- Techstream user’s question.
- Reset vsc
- Awesome Car
- Shift knob?
- Leak above rear alternator plug.
- Center Console repair
- Internal Gages Not Working - SC430 2005
- 15% Off at MEGAZIP
- Transmission Fluid
- Locking the top
- Adding tech
- Diagnose strut/tire/wheel issue.
- Replacing a brake light?
- Fix it?
- Roof
- Instrument Cluster LED upgrade
- Please place FS only in the marketplace
- Manual Roof Opening Help
- Rear chassis braces
- Camber settings
- Very erratic transmission shifting!!
- Ignition coils, replace 1 or all 8?
- Vsc lights
- SC430 AC Head Unit Disassembly and Cleaning
- Road trip
- SC roof mechanism
- I’m Back! 2007 Tiger Eye 60k miles
- 2002 SC430 Top
