rx 330 foglights suck
i want to change the bulbs of my rx 330s foglights. they look very obsolete with my HIDs on. why have halogen bulbs in the fogs when you already have HIDs??? anyway, i want to change the foglight bulbs to something to compliment my HIDs. any suggestions or websites anyone can refer me to? thanks!
hey movietime
i got those model 9006 hyper super white bulbs to replace my original foglight bulbs..but then i go into the owners manual and they dont even explain how to change those bulbs. if at all possible, can you let me know how you did yours? i dont want to mess anything up so i would appreciate your advice. thanks in advance!
it is pretty easy. 1st, take the two screws off the wheel well cover. 2nd, you may need to take the "pop in" rivets on the top of the wheel well cover off also. once they are off, you can gain access to the fog light bulb in there. just switch the bulb out and do the same thing to the other side. i was able to gain access to the fog light bulb from the passanger side thru the top of the engine. but i was not able to do that on the driver side. so i did the above procedure on the driver side only.
thanx movietime
actually i put them on this morning before i even got a chance to read your post. i was able to just reach underneath the car and twist off the bulb area...then took the old one out and replaced it with the new one..then reach under, put it back in place and twist it in...i wish they had a little bluer tint though..but still looks way better than the yellowish light it use to emit from the foglight area.
panda_ek9
12-25-08 12:40 AM
