can you use oem d2s bulb instead of oem d2r bulbs?
I was wondering if you can upgrade my existing oem d2r bulbs with d2s bulbs?
is base size the same for both? what would be the problem if there is any?
I have factory hid with d2r bulbs now.
thanks for any input.
nop they are not the same. they are very similar but one **** at the bottom of the base are different between the two, they are on different side (you will know what i mean if you put two together). however, it's not the end of the world. just use a dremel to cut out the d2r **** position on the d2r and you are good to go
I see, thanks rominl.
I haven't bought the bulbs yet. Do you think its worth it to buy d2s instead of d2r and try to fit? would the d2s have more brighter? thanks
xitr097
03-04-13 03:09 PM
TJW98LS
12
01-10-09 05:25 AM
